Addiction 2021.1
#1751
Bikes: Shmikes
Quoted: 10182 Post(s)
Liked 5,885 Times
I have a glove liner mitten combo, I may give that a try to see if I can actually shift. My hands and feet get really cold in the 20s. My New Year’s Day ride I ended up with numb feet about 10 miles in and they never warmed up over the final 30 miles. Same with my hands.
#1752
Quoted: 9656 Post(s)
Liked 6,366 Times
#1753
Liked 6,366 Times
I have a PI Amfib jacket that I find to be warm in our "cold." Sometimes too warm. But, that's in the 40s, and not 30s or below.
#1754
Mostly Harmless
Bikes: Have two wheels
Quoted: 13731 Post(s)
Liked 4,542 Times
I just use a mid-weight Windstopper fleece glove from OR. It's also my everyday glove for not-super-cold conditions. It works fine most of the time. When it doesn't (teens) I add a merino glove liner.
#1755
Bikes: Shmikes
Liked 5,885 Times
This year, I have also been using short sleeve, skintight, high quality, synthetic base layers under my long sleeve wool base layer. Hasn’t gotten really cold yet, but I’ve noticed a big increase in comfort and moisture management. Less stink and more rides per wash for the outer layers too.
#1756
Quoted: 3369 Post(s)
Liked 3,676 Times
#1757
Quoted: 20810 Post(s)
Liked 9,456 Times
I still haven't found gloves that are very good. I do believe that you need to go two or more sizes up for road cycling. I find that gloves that fit properly under normal conditions are too short and tight when gripping the bars - that compresses the insulation, particularly in the fingertips, and it all goes to ****. My current Dakine ski/snowboard gloves, that come with additional liners, are at least two sizes "too big," but they've been good for an hour at 20° or so, which is as harsh as I've ridden in this year. They're bulky and actuating the little shift lever is hit or miss, but they've been as good as I've experienced, so far.
#1758
Liked 9,456 Times
#1759
Liked 3,676 Times
It's not the first time it's happened, I lost about 15 minutes of a workout last week as well. Not too concerned about something like that since I'm not exactly tracking things super closely, but if I work out for an hour and it only gives me credit for less than a minute, well that's a bunch of bull.
For indoor workouts I'm not going to care all that much. Thankfully no problems with real rides yet.
#1760
Quoted: 10246 Post(s)
Liked 5,203 Times
Abshipp. Had a ground speed of 600 this morning.
#1761
Liked 3,676 Times
#1762
Liked 5,203 Times
#1763
Liked 3,676 Times
#1764
Klaatu..Verata..Necktie?
Quoted: 10471 Post(s)
Liked 11,983 Times
#1765
Should Be More Popular
Quoted: 22642 Post(s)
Liked 8,953 Times
#1766
Liked 8,953 Times
#1767
Liked 3,676 Times
#1768
Fat n slow
Quoted: 3260 Post(s)
Liked 2,086 Times
My Rapha Core Winter Jacket is warm enough in any conditions that I'd like to ride in. Down to the upper 20s, I'll wear a single base layer. Two layers will take me in to the teens. Oh, and I always have a merino neck warmer/gaiter - it really helps a lot.
I think I need to figure out the feet and hands the most. I have neoprene covers with warm socks, not sure what else I can do
#1769
Quoted: 8321 Post(s)
Liked 9,127 Times
Took the Covid test Wednesday and got results just now. Test came back negative. This means one of two things; false negative or some other bug has invaded me. Since I am usually the recipient of multiple viral illnesses every year I'll go with the latter for now.
Likes For big john:
#1770
Liked 9,127 Times
I've used chemical warmers stuffed inside the neoprene toe covers. Worked great in the low 20s while climbing and descending. Pcad told me.
#1771
Liked 9,127 Times
I lived in a rental house with friends and my friend who did the mowing was allergic so I would wake to the sound of the mower with him sneezing loudly several times per minute.
#1772
Liked 6,366 Times
Which test did you get? The one they shove way up your nose or the one where they swab your mouth?
#1773
Silver Comet Fred
Bikes: 1
Quoted: 8863 Post(s)
Liked 3,012 Times
#1774
Liked 6,366 Times
I mow our yard, and let the yard service go when Covid hit my business. Fortunately, it's a small yard, and only takes about an hour to do it right - mow, trim, edge, blow.
#1775
Liked 6,366 Times
Likes For Mojo31:
