Bike packing bag experiences wanted
Its only pain
Bikes: '18 Salsa Marrakesh, '14 Salsa Colossal, '89 GT Timberline
Quoted: 54 Post(s)
This year I am going to give on-road backpacking a whirl. I have a Salsa Colossal that is a sweet riding bike. I have the Tangle frame bag, but wondering about handlebar and rear bag options. Revelate Design has the remaining bags also (Viscacha, Sweet Roll) but are pretty pricey. Looking for reviews on them and your opinions whether they are worth the $$ or are there less expensive options that work just as well that you use. If this works well for me, I just might sell the LHT and get a fat bike. Thanks!
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
But, yes, bikepacking bags are expensive. They are very well made so they are a good value but the initial cost is high. Look around on Fleabay or Craigslist. You can find used ones occasionally but they are still expensive. There are a number of "make your own" videos out there as well. I'm not sure you'll save much money by making your own however. Sometimes, you just have to bite the bullet.
Finally, why a fat bike? Unless you are planning on doing winter rides, a fat bike is a liability over a mountain bike for off-road riding. A good hardtail mountain bike with a suspension fork will is lighter and easier to ride than a fat bike. Trying to keep knobbed tires rolling is tough enough without making them a whole lot heavier.
Stuart Black
Stuart Black
Quoted: 5888 Post(s)
Liked 3,472 Times
If doing road riding, you could also use a carradice type bag.
I'd stay away from bikepacking front harnesses for the Colossal if you have drop bars. Take a look at the many conventional bar bags out there made by firms like Ortlieb. You might also look at a Carradice saddlebag solution, the Colossal looks made for those. Other bikepacking saddle bags will work as well, but don't get lulled into the "more bags is better" approach that I so often see in bikepacking setups as that can get expensive. Think about what gear you need and buy the appropriate bags. I've never understood why anyone would need a "gastank" for a phone and snacks when jersey pockets and a handlebar bag can carry those things easily. You might just buy a large compression sack and carry your gear in that strapped to the saddle.
https://wheelsofchance.wordpress.com...0/16/bikepack/
A Good number of the Go Fast Guys in this past June's ACA Transcontinental, self contained, Race
used Bike Packin' type Gear .
I waved them off at sunrise, Then went home..
on the ultramarathon section there was tracking links posted ..
Bikes: 2014 Giant Roam
Quoted: 84 Post(s)
I've considered making them. Vinyl's not that expensive and often freely discarded from commercial signs. Some sewing, a drawstring cinch, rolls down and buckles. There aren't even many with zippers and things like that. The back looks fairly complicated but is a hook, stretch cord and solid inner plate.
I used a bikepacking setup for a trip this winter, and it worked great. Kind of limits the amount if gear you can carry, so you have to be careful packing and bring only what you really need. I also went with bikepacking bags and panniers last summer, which also worked well, with the ability to carry more. The Revelate Harness and dry bag is better then the Sweetroll for drop bars, because your width is limited.
Bikes: Nature Boy 853 Disc, Pugsley SS
Quoted: 251 Post(s)
Liked 8 Times
P.S. to the OP, if your ambition is to get a taste of bikepacking and see how it goes, know that it is a slippery slope and pretty soon you just abandon the road altogether.
This past weekend:
The bikepacking bags make the bike handle completely differently from your traditional pannier setup. It really is a treat. I had no trouble this weekend. Despite insanely icy conditions, I stayed upright almost the entire time. My fatbike was out of commission, but I made it out alive!
Here's how I'm carrying everything, but YMMV:
This past weekend:
Also, I'd recommend the Revelate Terrapin and Terrapin dry bag over the other saddle bags. So easy to undo a couple buckles and remove the dry bag to bring in the tent. Also, you can add another small bag on top with straps for that bit of extra gear. The red Revelate straps are worth the money, as well.
They can obviously work with drop bars, but you have to make sure the harness/bag will fit and allow you to be comfortable on the drops, hoods and flats. I found that a few REI compression straps and a Sea to Summit works quite well without the need for the harness if the OP is really looking to save money. Also I take full advantage of rear jersey pockets and put a bottle of soda in the middle one and fruit and snacks on either side. These keep me going up to lunch when I'll usually restock.
Personally I don't use "bike packing bags", but I do go ultralight and follow some of the same conventions.
Rather than use a bar roll I find that a light dry bag and two straps suffices nicely. I do use two short pieces of pvc pipe as standoffs. The straps go through the pvc pipe, around the bar, back through the pipe, and around the bag.
I find that on the rear I can go as light or lighter with a little mini rack and a light dry bag than the bikepacking seat bags. I am am not willing to use frame bags because I prefer to have that space for two bottle cages. and my frame size is too small to use a frame bag with out giving up one or both bottle cages.
I hope to get a frame bag, too, because that feels like a great use of space, but I don't see ditching my rear rack. It's in daily use when I'm commuting, so unless I find myself flying/shipping the bike somewhere where packing the rear rack became a hassle. In that case I may have to try out some seat bag options.
Its only pain
Quoted: 54 Post(s)
This past weekend:
This past weekend:
Its only pain
Quoted: 54 Post(s)
Great info so far. I would like to not use racks since this is a "on road Adventure Bike." I think that is how it was listed on the Salsa site. That way I can ride unencumbered if I choose not to break camp for a day or two and just cruise the area. Again thanks for the info!
old fart
Quoted: 119 Post(s)
Max,
I have seen photos of similar setups posted by you, and always wondered - have you done anything to add or simulate spacers between this harness and the handlebar?
I am not aware of the Oveja Negra harness being offered with such spacers, and am unsure if it has a sufficient length of the h/bar straps to accommodate for spacers...
Please, share.
Please, share.
Quoted: 251 Post(s)
Liked 8 Times
Max,
Please, share.
Please, share.
old fart
Quoted: 119 Post(s)
Re. Oveja Negra harness:
Ha! The mystery finally revealed!
It seems one would be able to use "the tops" hands position with this harness - something that I doubted until now.
Thanks, Max, and apologies to dannwilliams for sidetracking the thread.
Here is a close up of the Revelate Harness with the small bag that clips on the front. If you like riding in the drops, a narrower dry bag would be nice, which just requires a few more folds and more compression. The tops and hoods are completely available. The harness is attached with straps and rubber blocks.
40 yrs bike touring
Bikes: Bruce Gordon Ti Rock N Road [1989], Fat Chance Mountain Tandem [1988], Velo Orange Neutrino (2020)
Quoted: 14 Post(s)
Liked 6 Times
Plus 1 on the Revelate Terrapin Saddle Bag. More convenient to load and unload than the original Viscacha design. Just pull out or insert the dry bag to unload or load.
