Sexiest toeclip pedals?
Quoted: 4806 Post(s)
Liked 3,929 Times
Yeah.
There's 2 popular choices...
1. Clipless pedals + shoes
2. Flat pedals with pins + flat shoes with grippy rubber (five tens are the most common)
Toeclips have drawbacks worse than the other options and lack advantages to make up for it.
- For getting your foot out in a emergency it's worse than either clipless or flats
- Getting in and out of the pedal every time your stop is a pain as you have to flip the pedal right side up.
- For convenience you can't beat flats
- The "look"...well...it just sortalost it's "cool" appeal when they stopped using it in racing if you want the racer look it's clipless
- For getting your foot out in a emergency it's worse than either clipless or flats - pedaling 200 rpm and having one foot come off the pedal and getting your ankle struck from behind by that pedal is an emergency that dwarfs the consequences of going down strapped in. I haven't done it yet but that remains one of my nightmares and keeps me on toeclips with quality straps.
- Getting in and out of the pedal every time your stop is a pain as you have to flip the pedal right side up. - yeah, but you get over it.
- For convenience you can't beat flats - see the 1st response, Theat lifelong injury wouldn't be "convenient".
- The "look"...well...it just sortalost it's "cool" appeal when they stopped using it in racing if you want the racer look it's clipless - they are still considered a good track pedal and still show up at velodromes.
I don't have those pedals for their looks. I put big steel tabs on them for quick pickup, then add heavy washers to the toeclip bolts to pull the toe down, offset the tab weight and add a touch of inertia to the pedal rotation. All this makes for an easy pickup.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
I've not seen every GB stem, but don't recall ever having seen one with a wedge rather than a cyclindrical expansion nut. Here are a couple (Raleigh used them on a lot of bikes). Two different styles. The bog standard was on a Super Course, the one labeled "forged" on a late 70s Grand Prix.
Quoted: 539 Post(s)
Liked 44 Times
But, if you are riding the street (and hills) fix gear, those Shimanos have real value especially because of their toestraps . Point by point:
Likes For PaulRivers:
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
Don't track racers still use clips and straps? Or do they actually nowadays use clipless, reinforced with straps?
Quoted: 7348 Post(s)
Liked 2,470 Times
It's a mixed bag now. I plan to visit the Velodrome soon, so I'll take a look.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
I have an image in my head of the track racers on their bikes being held up by their trainers as they crank down two straps per foot to get them ready to go
Liked 2,470 Times
It sometimes happens even these days, depending on the type of the race. Most of the races, though, start at the rail. The riders line up in single file and hold the rail. Since this places them in a random order, they get a free lap before the race starts, and the race starts with the bikes in motion. There are, however, some races that start at the line.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
Right, but before the riders get sent to the rail they need a helper to affix their feet to the pedals. Kind of like in Breaking Away where the cutters have to attach whatsisface's broken foot to a pedal with a bunch of wraps of tape.
Liked 2,470 Times
Well, I raced at Kissena in 2014, and I don't remember that happening. The rail is on the right, and it's not hard to reach your left foot in that position. It's a little harder to reach your left foot, but you could cinch your right foot before getting moving. I don't remember what the toe strap folks did, but I'm pretty sure no one received help at the rail.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
I couldn't (quickly) find a utub showing getting straps setup before a track race, but these guys pretty clearly have straps
Liked 2,470 Times
Yes, some track racers still use straps.
Likes For noglider:
Quoted: 1529 Post(s)
Liked 718 Times
I appreciate the OP's passion for clips, but not the ones in the picture! I had them on one of my bikes, but they definitely didn't feel as good underfoot as more traditional pedals and clips (see below). Something about the shape didn't support my foot well either, and it was uncomfortable.
As a matter of fact, I just removed a set of Shimano 600's like the ones the OP has
Actually, these are just lowly PD-A550s (RX100). The rear plate is part of the pedal body instead of a bit of chromed steel bolted on, and the spindle is retained differently. I've modified the pair on the TCR by shaving the rear plate a few mm and removing the vertical part of the front plate (this setup is actually designed for a special cleat). It's much flatter and a fair bit more comfortable, but the main aim was to reduce rocking torque (Imagine pedaling with big blocks of wood under your feet). Although it's a bit slippy now, so I've been meaning to get around to applying some skateboard grip tape.
Normal:
Modified:
Here are the cleats:
Liked 718 Times
By the way, if anybody's keen on those cleats, https://www.ebay.com.au/itm/163118872271
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Liked 718 Times
With 105 and above, it wouldn't be too hard to make your own rear plates. Same with the front plates.
Intrepid Bicycle Commuter
Bikes: 1976 Motobecane Grand Jubile, Austro Daimler 'Ultima', 2012 Salsa Vaya, 2009 Trek 4300, Fyxation Eastside, State Matte Black 6, '97 Trek 930 SHX, '93 Specialized Rockhopper, 1990 Trek 950
Quoted: 76 Post(s)
Liked 94 Times
In truth, most of my decisions in life are made with a modicum of convenience in mind, and clipless just isn't convenient for me at all. Toeclips are convenient as all get-up, and are frankly easier to get into than my nylon platform straps. I can be wearing my Chuck Taylors and a pair of running shorts, and be riding in 30 seconds.
mosquito rancher
MKS makes the "Ezy Superior" platform pedal, designed for street shoes, with a giant kick-up claw, designed for use with toeclips. They also make amazing (and spendy) toe clips made of stainless rod, so there are no sharp edges to mar your street shoes.
Adam Rice
Adam Rice
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
What were the "fixie peeps" doing that was worth deeply appreciating? Good riddance to that "craze."
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
This is what I use
MKS Half Cage on SR SP-11 pedals (the latter are original to my 1985 Trek 720).
Don't complain about the weather and cower in fear. It's all good weather. Just different.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
I don't know if these are sexy. But they're much better for tennis shoes with flexible soles than are the kind with cages or quills or teeth. I'd maybe like them even a little wider for my Neanderthal feet.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
For me, the problem with toe clips is the awful scraping sound they make for the first 10-20 pedal stokes as I kick at one of the pedals trying to get my foot into the clip.
I somehow missed the toe clip era the first time around. I grew up in that era, but my bikes were too cheap for fancy pedals like that. I used toe clips for the first time last year preparing for L'Eroica California. After a few weeks I got to the point where I could use them with only minimal embarrassment. The worst part is that I couldn't find clips that my regular street shoes fit into, so the toe clips don't even save me having to change shoes.
Those half clips that revcp showed might work for me, but do they actually provide any significant foot retention? The problem I have with bare platform pedals is that my foot is constantly sliding off the pedal because I've become so accustomed to clipless.
My Bikes
My Bikes
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Honestly I love the look of toe clips and ride strapless ones on my bike. I don't know the brand of mine, got them at a local shop and they weren't branded so...
Best image i have of them at the moment.
