Addiction LXXVII
#6901
Quoted: 20810 Post(s)
Liked 9,456 Times
Better quality tires, even in the same size, will help, too. But yeah, moving to 28/30 and being able to lower my pressure to ~70psi made a huge difference. Also, while 80 psi might feel sketchy and wrong on 25s, 60-70psi feels awesome 28/30.
#6902
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
#6903
Quoted: 3361 Post(s)
Liked 3,638 Times
Speaking of, I need to figure out what the hell is going on with my wrists. They are consistently painful during and immediately after I ride, even with 38mm tires at 45-50 psi and a big flexy steel frame.
They also pop constantly. The pain seems to be worse this year than it was last year, which is worrisome given that I want to do a lot more riding this year than I did last year.
I've got a very relaxed position on the bike with as little weight as possible on my hands, so there's not much more improvement I can make there.
#6904
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,531 Times
#6905
Liked 9,456 Times
#6906
Liked 3,638 Times
#6907
So it is
Quoted: 11402 Post(s)
Liked 4,760 Times
#6908
Liked 9,456 Times
#6909
Quoted: 10237 Post(s)
Liked 5,185 Times
#6910
Liked 5,185 Times
Good question? I actually don’t know know if it can. I don’t remember seeing an obvious clearance issue but I’ll do research before I commit to anything.
In my area craiglist is always scarce on bike parts, but it’s never short on road tires. Kind of weird.
#6911
Liked 8,927 Times
#6912
Liked 9,456 Times
I would skip CL for tires - good ones are cheap to come by (well, unless you're running tubeless) and are the BF-approved Best BFTB.
#6913
Liked 5,185 Times
Clearances were kinda tight in that time period - slightly large 25s might be the best that you can do, but yeah - look at the frame and brake caliper clearances.
So to determine clearance is it best to measure, or try and hunt down old bike information.......
#6914
Liked 9,456 Times
Measure.... kinda. 4mm is pretty much the industry accepted clearance, so I'd take a 4mm Allen wrench and use it as a spacer to eyeball all of the tight spots (top and sides of the tire) and get an idea of how much more it's got to give. You can go a little tighter than that 4mm if you have to, but I wouldn't go too much tighter - you want debris clearance and things can flex when riding.
#6915
Quoted: 18420 Post(s)
Liked 15,564 Times
Hit 10,004 miles on the Forester yesterday. Not bad for about 44 months.
Likes For indyfabz:
#6916
Liked 5,185 Times
#6917
Liked 5,185 Times
#6918
Administrator
Quoted: 11971 Post(s)
Liked 6,654 Times
I’m pretty certain that was the prevailing opinion at the time, although finding many of those folks to confirm today would be impossible.
#6919
Mostly Harmless
Liked 4,531 Times
#6920
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
#6921
Liked 15,564 Times
My ac compressor died after about 2 years. Glad it was still under warranty. The driver's seatbelt cover split open, the battery died prematurely, and not long after I bought it I got a recall notice. Seems the lazy Japanese robot that built the thing may not have added enough transmission fluid at the factory. Recently got another recall notice. Seems there is a corrosion problem in the wires for the front passenger sensor. No solution yet. Subaru's workaround for now: Limit the use of the front passenger seat.
#6922
Liked 15,564 Times
Speaking of cars, a Facebook friend reposted this long list of things that you should do to protect your from the beer virus. One was using a barrier when you pump gas. I commented that I buy my gas in New Jersey, so that's not an issue for me.
#6923
Liked 3,638 Times
When I bought my truck about 4 years ago it had around 50k miles.
Only a few months into owning it it threw a check engine light for the camshaft position sensor. I got it replaced under the factory powertrain warranty, but then a few weeks later it threw the same code again.
I took it to the dealership again and after a day they told me that they called GM and they recommended a complete engine replacement due to excessive crankshaft endplay.
The powertrain warranty had about 2 weeks to go before it expired
#6924
Administrator
Liked 6,654 Times
Oh pulleeze, he’s still a pup for crying out loud. There’s no way in the world anyone 30-anything should have aches and pains outside of injury. Aches and pains only become routine after 50 . . . . . . . there’s a whole sub forum here to testify to that.
Likes For BillyD:
#6925
Liked 3,638 Times
