Is there a way to run flat mount (road) disc brakes on an IS mount bike
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
Quoted: 70 Post(s)
Liked 6 Times
Pretty much as the title reads, can a frame/fork with IS mounts be made to fit a flat mount caliper through adapters?
Quoted: 263 Post(s)
Liked 9 Times
I would have said that all of the disk brake calipers I've seen are post mount and all IS mounts require an adapter? I'm only familiar with MTB setups so maybe road is different.
All the calipers are made pretty much the same, then either bolt to the posts direct or use the adapters to use ISO standard tabs
the same ISO Adapter fits 1 size disc smaller when on the rear 160/140 , 180/160 . 210/180 .
so if You use the same size disc F &R the adapters you get will be different, from each Other
Quoted: 70 Post(s)
Liked 6 Times
Quoted: 714 Post(s)
Liked 800 Times
It will probably depend on whether the brake is mounted on the seatstay or chainstay. An adapter could be made to adapt a flat mount caliper to an IS mount, but the caliper would not fit in the space between the seatstay and chainstay with the adapter attached. It just doesn't make any sense to try to make a flat mount caliper work on an IS frame.
Quoted: 70 Post(s)
Liked 6 Times
Quoted: 184 Post(s)
Liked 67 Times
A front 160mm / rear 140mm / 0mm post mount to IS adapter does not increase the rotor size of the IS mounts when attaching a post mount caliper (140mm IS mount = 140mm rotor and 160mm IS mount = 160mm rotor).
If the flat mount to post mount adapter does not increase the rotor size of the post mounts (140mm post mount = 140mm rotor and 160mm post mount = 160mm rotor) then it could be bolted onto a post mount to IS adapter and work the same way.
Look at the Avid 0mm IS adapter, Shimano SM-MA-F160P/S adapter or a Shimano SM-MA-R140P/S
* All 3 of those adapters do exactly the same thing.
Quoted: 70 Post(s)
Liked 6 Times
From SRAM Flat Mount brakes are here - BikeRadar USA that article, in the first (non bold) paragraph, it states
"While Flat Mount frames can mount standard brakes with adapters, Flat Mount calipers are not backwards compatible with existing IS and post-mount frames."
So... I checked with competitive cyclist, and was told, indeed, it is not possible. Unless someone knows of a version of the road hydro's that are not flat mount, I am out of luck.
Shimano RS685 Hydraulic STI Levers & Disc Brake Calipers Set | Competitive Cyclist
Quoted: 184 Post(s)
Liked 67 Times
It would be easier to just get a post mount caliper and use a PM to IS adapter.
https://productinfo.shimano.com/#/spe...isc%20brake%29
Quoted: 1074 Post(s)
Liked 295 Times
Yay, another standard!
I can't believe how I survived the wait!
I was beginning to worry about when to get my next fix, now when when the latest rush of almost-identical press fit BB standards began to taper off.
Lucky me that Shimano thought of us standard junkies and is launching a new round of redesigns.
What's the claimed advantage THIS time?
Weight?
Clearance?
Heat transfer?
Frame/fork stiffness?
Really, If I were announced Supreme Ruler of the World for one day, I'd put a ban on the introduction of new standards unless they came with easily determined (user) advantages.
And order a round of public humiliation for all who've willingly supported or encouraged the development of these standards with no immediate advantage to either function or production.
What's next, maybe a full line of road-specific brake pads?
Just dissimilar enough that anyone with both MTBs and roadbikes under no conditions can use the same consumables for both.
Maybe a "road" line of hydraulic fluid?
Perhaps with cunningly engineered seals and gaskets to make self-destruction an immediate consequence of cross-use?
The mix & match ability of Shimano's road and mtb families for personal adaptation used to be one of their strong points, why are they giving that up?
I miss that.
Weight?
Clearance?
Heat transfer?
I miss that.
Quoted: 714 Post(s)
Liked 800 Times
There is no real "user" advantage to flat mount. It seems that it was intended to make it easier for carbon frame manufacturers to mold the mounts into carbon chainstays.
Quoted: 70 Post(s)
Liked 6 Times
Weight?
Clearance?
Heat transfer?
I miss that.
Weight?
Clearance?
Heat transfer?
I miss that.
The above perfectly embodies the bike industry.
Basically, the anti-disc mafia is to blame. They complained loudly that disc brakes were big, heavy and ugly. So Shimano designed a new mount to make them smaller, lighter and more discreet.
The answer is no.
Quoted: 2026 Post(s)
Liked 1,096 Times
That's probably your only practical choice if you want to stay with flat mount brakes. It sounds like you don't have the frame yet so you aren't out anything at this point.
OK looked it up further.. Yup, time to go shopping for a different kit..
you have a packaged deal unless you replace the stock, road flat mount caliper, on the end of the hose.. *
of course not the latest Wallet draining stuff, but the TRP Hy Rd, gives you a hydraulic caliper.. operated from a cable Brifter..
https://www.trpcycling.com/product/hyrd/ that is made in flat mount too.. https://www.trpcycling.com/product/hyrd-flat-mount/
to see the difference.
*have I done it myself? Nope, if risk averse, save your money. stay out of the high end gear.
If you're doing Shimano, you can pair new Ultegra and Dura Ace with either the old road calipers Shimano mountain calipers, like XTR race. You should be able to find the levers for sale without calipers.
I know too much about it because I would really like to build up the new Velo Orange Polyvalent (which has IS mounts) with Campagnolo hydraulic discs, which sadly only come in flat mount. I think that they may work with Magura calipers (they use the same fluid, at the least, and Magura was an initial design and current manufacturing partner) , but I haven't seen any information that tests this. Oh well.
