Kickstand?
#76
Who would have thought that Kickstands would have created such an active thread????
I have enjoyed it. Thanks for sharing ideas and pics for both not having a kickstand and for kickstand options. Both have been very helpful to me.
#77
Bikes: 2011 Fuji Absolute 3.0 -- 1997 Trek 830 (modified to hybrid)
Quoted: 79 Post(s)
Liked 548 Times
I understand the issues involved with kickstands on bikes set up for touring with panniers or for trail use on mountain bikes. But I have two hybrid bikes, both equipped with racks and rack bags, and I have a combined 3,000 miles on them and neither has ever fallen from the kickstand even ONCE. I use them every time I ride, including every water break or stop I make, which is usually at least one per ride, or sometimes as many as three or more quick breaks if I'm doing a 20+ mile ride.
Yes, there are times that it takes me an extra 5-to-15 seconds for some kind of quick adjustment if I'm not on level ground, or for some other contingency. I'm guessing that if I weren't willing to adjust the orientation of the bike to the terrain or the specific situation (there goes THAT 10 seconds I'll never get back again! darn!) that I would have probably experienced some falls from the kickstand... also, I don't ride trails or with panniers, so there's that to consider.
I do usually have 2-3 water bottles (1 or 2 in bottle holders) and probably an average of 1 to 4 pounds of stuff in the rack bag, depending on situation and length of ride: extra water bottle, lock or locks/cable, patch kit, keys, spare tail light, spare head light, cell phone, etc.
To each their own. Whatever works for you. Kickstands work for me, big time. YMMV.
Likes For Rje58:
#78
Bikes: Giant ARX2...
I agree, stands are handy in some riding situations. Though they do give a false sense of proper bike etiquette, that is easily challenged by a strong wind or rogue passerby.
For the kind of riding I do, I dn't have a great need for one. I usually rest it against some immovable object. You could carry a soft towel or shop rag to rest between the ground and the bike in some out of the way spot. Perfect to have for when you change a flat or perform some other roadside maintenance.
#79
Quoted: 18415 Post(s)
Liked 15,543 Times
#80
Liked 15,543 Times
#81
Likes For wobrien:
#82
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,529 Times
I have a similar issue as the OP but for a different reason; my vintage steel mtb. doesn't have a plate, so the standard Greenfield kickstand doesn't fit. I like my kickstands; I've always had them, and they've never been a problem. If the ground won't allow for the stand, I can lean it on something. Having to always find something to lean my Princess on is proving problematic, and no, I won't lay her on the ground, I like her bits as they are. Also, my mirror sticks out too far. I've thought about a chainstay mounted one, but the husbeast is concerned about possibly crushing the stay. He's a worrier.
Any ideas, kickstand fans?
Likes For Korina:
Likes For BCDrums:
#84
Happy banana slug
Liked 1,529 Times
#85
Quoted: 195 Post(s)
Liked 207 Times
I agree. There's always something. I've seen too much damage caused by them. I had one on a touring bike that needed a brace brased across the two bottom tubes anyway but I avoid them.
#86
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
https://www.bikeforums.net/general-c...cool-what.html
Likes For ksryder:
#87
Bikes: Devinci Millenium, Gary Fisher Joshua
Quoted: 73 Post(s)
Liked 29 Times
Hi,
Many years ago I was at a bike shop when the topic of kickstands came up.
One of the guys said (basically) "Keep your money, just get a heavy elastic band like they wrap veges in and put it on the bar.
When you want to park, just put it around the brake lever.
Whichever wheel you lock will not budge. You can lean it against a lamp post or touching a wall and it will not move. For the real trump card put one on each bar." If it isn't strong enough wrap a single wrap around the bar to shorten it or double it around the brake handle.
It is amazing simple cheap and uber light and won't damage the bike paint job. I thought he was joking but it is awesome!!!!
#88
Quoted: 73 Post(s)
Liked 29 Times
The other thing is that in my garage I do some woodworking and the bike gets in the way.
Also it is visible to thieves, so I went to a hardware store and bought two large rubber coated hooks, screwed them into the ceiling rafters and just throw my bike up and hook the wheels on the hooks.
It's partially hidden from passerbys because it is up out of view and a bit difficult for someone to just grab, so it is a bit safer. My neighbourhood is pretty safe anyways. Very cheap answer.
I have seen some setups where the person put one heavy coated hook on the wall and then puts the front wheel on it. Not sure how that works out but it would save some space.
#89
Cycleway town
Yeah, i notice they don't show it with the panniers on, full of stuff... no good for me.
But there's a similar type where just a rear section of the rack works like that, and that's probably the best stand design i've seen. Would be ugly without a rack to hide it against, though.
#90
Quoted: 1062 Post(s)
Liked 665 Times
#91
Quoted: 73 Post(s)
Liked 29 Times
Another thing I forgot to mention about my setup is that you do have to be a bit careful when taking the bike off my hooks because once I was in a bit of a rush and the spoke got hooked in the hook and broke the spoke fitting by twisting the spoke, and I spent awhile with no bike trying to fix it. I have 2000 vintage Mavic Cosmic rims which are somewhat aero and great wheels, but parts are a tad expensive, so I was in a pickle till someone suggested using a washer as a spoke fitting. worked perfect.
My ceiling is quite high so it makes a nice little stretch at the end of the ride to put the bike up. : )
#92
Quoted: 1027 Post(s)
Liked 325 Times
My road bikes do not have a kickstand. What's the point of spending a bunch of money to make a bike light, and then adding unnecessary weight back on?
My winter commuter/utility bike does have a kickstand. For that bike, it's pretty handy.
#93
Liked 15,543 Times
Likes For indyfabz:
#94
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Excellent idea as long as you put a hook on the end of it so the bike doesn't slide off.
I did lag bolt a 2x4 to the wall rather than use inserts into my cinder block wall. I have two 8’ long 2x4s lagged to the wall to accommodate all of my bikes. There are 4 and 5 bikes hanging on each one (mountain bike handlebars take up a lot of room). Here’s what it all looks like
Untitled by Stuart Black, on Flickr
I’ve never had a bike fall off the hooks nor damaged a bike in any way.
Stuart Black
Stuart Black
Likes For cyccommute:
Likes For woodcraft:
#97
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
https://surlybikes.com/parts/kickstand_plate
#98
I found a way to reliably lean my bike against anything without it falling or sliding down the wall/window/telephone pole/etc. I have a strap of velcro that I set one of the brake levers with. With one wheel locked like that the bike won't roll forward/backward and fall.
#99
Happy banana slug
Liked 1,529 Times
Or maybe I should just admit reality and live without a kickstand.
#100
Liked 4,218 Times
There are 9 in the picture (my wife is riding to work today). All but 2 of them are mine.
Stuart Black
Stuart Black
