Compact crank for classic?
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,860 Times
I am a crumbling relic who, in good weather, creeps about the roads on the beloved custom frame, which carried him to Cat IV glory back in the early 80s. Currently, it has a 7800 group, but experience with a new CX bike this winter has convinced me that I am simply not strong enough for 53/39 and probably never was. Hence I am looking for a modern, 110 mm BCD, crank that will accommodate 50/34.
Aesthetics (hotnesses) are important and I'd really like it non-black. Interoperability with the 10-speed rear is essential and it would also be nice if I could use the present BB. If I'm not mistaken, there's a 9100 item which might work. Cost is not a major object. Any other ideas?
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Bikes: Shmikes
Liked 5,860 Times
Yeah, saw that one and it makes sense. 7800 was NOS in 2014, so the BB has probably held up to my 150 lbs and pathetic output.
Bikes: Shmikes
Liked 5,860 Times
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
https://www.peterwhitecycles.com/carmina.php
Quoted: 3238 Post(s)
Liked 2,085 Times
Pretty sure you can't go lower than a 52 large ring on a 130 BD crank common to 53/39 systems. Maybe your crank is 110 BCD ?.
Thus a new crank and b-bracket (might as well, they are like $25)
Biggest limiting factor though is front derailleur location and can you drop down the derailer to get it into good shifting position for a 50 ring.
Braze-on brackets obviously cause the most headaches, clamp arounds are easy as long as the clamp will clear things like bottle cage bolts. With braze-on it's possible to rat file the slot on the braze on.. As well somebody makes an adapter for a braz-on that allows a lower position for the derailleur.
Quoted: 4717 Post(s)
Liked 1,882 Times
https://www.bike-discount.de/en/buy/...iABEgK4NPD_BwE
Liked 2,085 Times
Shimano made a 130BCD 50T chainring(I own one).
Thx, I never knew that or saw that anywhere. If I can find it it'll work great on my Soma triple.
Quoted: 1609 Post(s)
Liked 2,590 Times
Bikes: Shmikes
Liked 5,860 Times
Liked 2,085 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Shimano makes a 14-28 10-speed cassette. Usually marketed to juniors, but it would whack down the top gear without requiring you to touch the crankset. Probably run smoother, too.
Bikes: Shmikes
Liked 5,860 Times
Liked 2,568 Times
Hmm, maybe I was thinking of 14-25? https://www.universalcycles.com/shopping/product_details.php?id=4468&category=534
Could have sworn there was also a 14-28, but perhaps it was too niche for Shimano to keep it in production. Peter White sells Shimano-compatible TA cassettes in this similar gearing, but they're even more expensive: https://www.peterwhitecycles.com/ta-cassettes.php
RUSA #7498
Originally Posted by noglider
Bikes: Shmikes
Liked 5,860 Times
Quoted: 30 Post(s)
Maybe I'm missing something,but isn't the reason to go compact having lower low gears? The suggestions of changing out the 53 or getting a junior cassette would only lower the high gears. It would be a lot less expensive to just not shift up so high.....
Bikes: Shmikes
Liked 5,860 Times
The big cassette gets me another few teeth on the low end and more useful gears in the big ring, but yeah, it doesn't completely solve the problem. The 50 is less helpful.
Liked 1,882 Times
The OP didn't originally say he needed very low gears to climb, only that he wasn't strong enough for his 53/39.
Bikes: Shmikes
Liked 5,860 Times
Both are true and a smaller big ring would indeed help with the flats.
Quoted: 1528 Post(s)
Liked 718 Times
Don't forget, you can go down to 38t on 130.
If looks are a factor, nothing you replace a FC-7800 with will look as good...
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
See: https://www.bikeforums.net/classic-vintage/1167438-vintage-looking-9-10-11-speed-cranksets.html
Bikes: Shmikes
Liked 5,860 Times
