need a short schrader cap for suspension fork -- where?
Old 02-16-12, 09:56 AM
ColinL
Two-Wheeled Aficionado
ColinL's Avatar
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
Liked 5 Times in 5 Posts
Hey all, I wasn't sure if to post this here or in MTB.
I have a magura/cannondale headshok fork and I've misplaced the cap for the air valve. It's a schrader valve, but the original cap has a flat top and threads less than your ordinary schrader valve cap. I have a standard cap on there now, but the valve is in the crown of the fork and a standard cap sticks out a lot. The original cap wasn't flush-- it protruded as well, but less.
Where can I find a short valve cap? Thanks in advance!
ColinL is offline
Old 02-16-12, 10:02 AM
cbchess
Map maker
cbchess's Avatar
Bikes: Ventana El Ciclon, Walt Works 29er, Specialized Enduro (fixed up for my son).
Did you check an auto parts store? you might also find a metal one there. you could then file down the cap to the size you need.
cbchess is offline
Old 02-16-12, 10:05 AM
ColinL
ColinL's Avatar
Actually, no. Great ideas!
I was hoping someone would answer "oh, yep, here are the short plastic caps made just for that" but I might be able to make that work.
ColinL is offline
Old 02-16-12, 10:26 AM
kageones
prying open my third eye
kageones's Avatar
Bikes: yes
Chess is right, a TPMS metal cap will work and are cheap enough at an auto parts store, but you will have to file it. I would contact Magura https://www.magura.com/en/service/con...ntactform.html ,get what is supposed to be there, no modding needed. Also check air conditioning caps, they are short and you can get them with o rings in them that rarely leak air out and keep dirt out. https://www.amazon.com/Santech-Air-Co...9410055&sr=8-7
kageones is offline
Old 02-16-12, 10:46 AM
DCB0
Bikes: CCM Torino 76
You probably have a short schreader cap hiding at the end of a long schreader cap... but you need to cut the bottom off the long schreader cap to reveal the short one underneath.
DCB0 is offline
Old 02-16-12, 10:59 AM
ColinL
ColinL's Avatar
That looks pretty damn good. I emailed Magura anyway, but I doubt I'll do a lot better than $8.
ColinL is offline
RockiesDad
General Cycling Discussion
378
05-19-21 01:00 PM
the_don
Road Cycling
195
01-17-12 08:50 PM
Old Yeller
Classic & Vintage
4
10-01-10 07:11 AM
Old Yeller
Mountain Biking
1
09-30-10 02:35 PM
ddez
Bicycle Mechanics
30
02-24-10 10:01 AM
