For the love of English 3 speeds...
Quoted: 1299 Post(s)
Liked 103 Times
Barred @ Velocipedesalon
? Year: Raleigh Brake pad/holder
These pads (and other parts) came off of a Raleigh '40s Sports Tourist (actual year/model unknown). I'm trying to determine if this pad holder style had a definite start/stop year in order to limit the range of years that it may have been manufactured. I'm very dubious about the serial number (indicates early '30s, 1933) as a reasonably accurate indicator of year. It seems that everything on this bike indicates a very late '30s-mid '40s: "no date" AW rear hub ('41-'42), GC3 bar mounted shifter ('38-'47), Dynohub and Dynohub Headlight ('36-late '40s). It seems odd that everything would have been removed from an early frame to be replaced by components from about 10 years later, thus my feeling that this is a 1940s bike. I do not know if the Dynohub is 12, 8, or 6 volt (no image match to any model); which would help with the year range, no photographic evidence to match my Dynohub to a known year/model. I hope the brakes changed enough to allow for a more accurate dating of this bike. Also, I'm curious as to the BB size/threads. My Hercules has a 68 mm shell and I believe 24tpi, but I believe this BB is wider (not measured yet) with a different thread pitch (71 mm, 26tpi?). Is this the same BB that would be in my 1970 Raleigh Sports?
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Quoted: 515 Post(s)
Liked 167 Times
Hercules Head Badge Year(s)
I'm trying to determine the range of years that this head badge was used. I believe it to be earlier than 1948 since I've seen models from '48 and later with the green "shield" style badge. Seems like I've also seen a similar style used on much later models ('70s/'80s ?). Any feedback is as usual greatly appreciated. Thanks all!
Liked 443 Times
While the badge itself is metal, the centre medallian is some sort
of plastic that doesn't seem to age well
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
The badges and chainrings on Hercules went back and forth a couple of times depending on the market. I have a prewar Herc with the circular H badge as well as a 40's model with the same but a Hercules chainring (not the H).
From the '37 Catalogue
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
Liked 443 Times
Quoted: 350 Post(s)
Liked 24 Times
Likes For paulb_in_bkln:
Bikes: Santana Sovereign Tandem, Five Rings Carbon, Lemond Alpe d'Huez, Miele Latina, Hercules Tourist, Mercian Super Tourist Tandem, Birdy BD-1, Duell Solo, Jack Taylor Marathon Tandem, Raleigh RSW-16, DL-1, and Superbe
Quoted: 97 Post(s)
Liked 240 Times
1954 Hercules Tourist Headbadge
And this from velobase:
Thanks again; new frame "Krapf" coming soon, but not this forum.
Liked 443 Times
Thanks for the input and examples! Definitely the original badge for the frame based on the rivets looking old and unmolested. Managed to find some paint missing that shows the original black. I had tried Velobase, but it was down at the time. Seems like the waters are pretty muddy regarding head badges and dates of use. I'm just going to build it as best as I can, hopefully finding "period" parts or good substitutes.
The ability to use parts spanning several decades.
The ability to restore/rebuild with what you have available.
A period correct restoration is desirable but can also be very expensive
and time consuming.
I see nothing wrong with taking a 50's frame adding a wheelset from
the 60's and some calipers from the 70's.
I have a 1930 Hercules that I re did last year.
The frame, seat post and brake linkage are original to the bike
everything else has been replaced with more modern components.
In this case, 1970 is considered modern...
This bike is still not actually 'finished"..
That's one of the the things I really like about these bikes.
and time consuming.
In this case, 1970 is considered modern...This bike is still not actually 'finished"..
and time consuming.
Liked 443 Times
Fully agree gster, nice build. I have a couple of '50s Italian racers that, with the exception of putting carbon parts and maybe indexed shifting, look just fine with '70s/'80s components. It seems, with rare exception, that none of my bikes are really finished; even when "finished". I think I have the same problem with relationships, I think I can always make it better even when it's well enough left alone. Always appreciating your comments and insight; as long as you guys don't distract me with over the knee boots and blonde hair; now making me want to watch some classic British telly. Is there a Doctor in the House?
Some Mothers' Do 'ave em....
Quoted: 515 Post(s)
Liked 167 Times
Only silly not to ask. I'm new to this "Dynohub" scene; I've yet to test mine, but being that it has two terminals (I assume isolated from "chassis ground"), you would have to test for polarity (have not looked at terminals for +/- marks) and connect a "grounding lead" to the frame for whichever polarity you desire, and/or connect to the accessory using proper polarity. Sorry for my relative ignorance in this matter, but I have bigger fish to fry on the bike mechanically; I was mostly using as a dating reference based on the model/voltage. That being said, when I do test it, and if it functions; I'll know its polarity and voltage, and thus it's model and tangentially my bike's approximate date of manufacture if it, as I now assume, is original to the bike. I'm sure we'll both be educated by someone here who already has extensive experience with this system.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
Quoted: 515 Post(s)
Liked 167 Times
Quoted: 887 Post(s)
Liked 335 Times
Columbia 3- Speed
I picked up a Columbia 3 speed this morning for cheap. I have already stripped it of usable parts and will donate the remainder through my LBS to the local coop. I ended up with two decent steel wheels (Sturmey AW hub, shifter, and ribbed cable housing), Weinmann sidepull brakes and levers, grips, and a Cyclepro vinyl saddle in great condition. It also had some decent fenders and a Wald basket that was bent a bit, but I have not seen too many baskets that were pristine.
The front wheel spokes are nice, the rear wheel spokes are nasty so we'll see when they are clean.
I rode the bike before I stripped the parts. My take is that:
The bike works and rides well
I would keep it if I didn't have too many bikes already
The frame is dead and heavy
The Columbia headbadge is nice - Westfield, Mass
I think they made better headbadges than bikes.
Likes For AL NZ:
Liked 103 Times
Likes For BigChief:
