Disc Brake Issue
Bikes: 2004 Cannondale CAAD5 R700 and a 2005 Litespeed Vortex
Disc Brake Issue
I have a a Trek Checkpoint ALR5. It is equipped w/hydraulic disc brakes, Shimano 105 to be exact.
My problem occurs when riding, I spot an unavoidable bump or pothole and I apply the brakes, There is a rather violent vibration in the front brake after hitting the bump/pothole. It's as if the front brake is braking and immediately fading. The vibration continues until i release the front brake. When I engage the front brake again, on smooth road, front braking is normal. I do not have the same problem w/the rear brake.
I am a large rider. I'm 6'4", weighing 200 lbs. I've read that cycling disc brakes are susceptible to fade for large riders, but haven't come across anything like what I'm experiencing. My LBS has checked the front end integrity of the bike with no negative results.
Any thoughts would be appreciated.
Thank you
Thank you
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
The go-to answer for brake hysteresis issues is a glazed or inconsistant spot on the rotor. You may try to scrub the rotor with aluminum oxide sandpaper. A few hundred grit ought to be enough to knock off the contaminants that have glued themselves on.
Another answer is the rotor itself may have worn inconsistantly due to the various cut-outs providing differing surface contact areas. The least surface area parts (either side of the hole in the braking surface) would have worn more than the areas that contact the whole pad. In this case a new rotor (& maybe even pads) would be well worth looking in to.
A good measurement of rotor thickness would tell you a lot.
As a heavier & "confident" rider (200lb) that tends to push things, I'd like to suggest scintered/metallic brake pads. They may be a bit noisier in certain circumstances, but they do tolerate higher heat loads much better than the organic resin type. They also tend to be more fade resistant & tend to not deposit themselves on to the rotor so much.
Car dependency is a tax.
Likes For base2:
Likes For Jack Tone:
Thank you both...Will ask my wrench to address your suggestions.
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Thank you
Thank you
I am potato.
Liked 1,631 Times
https://en.m.wikipedia.org/wiki/Hysteresis
Specificly, it is elastic hysteresis. It's under the "In mechanics" heading. The gist of it is the current state has a direct relationship to the previous state & a feedback loop of some sort is formed. Most people tend to associate it with magnetism or electronics, but the principal is found in many systems. This one example being the friction/force acting on the rotor at a given moment vs the elasticity of the fork. The area in between the curves being the sum of the change of velocity of bike, the bike rider, & some nominal heat gain in the rotor, pads, & elsewhere in the system.
Bikes: Shmikes
Liked 5,873 Times
I am potato.
Liked 1,631 Times
Quoted: 4420 Post(s)
Liked 4,873 Times
Thank you
Thank you
It would also help to know what is actually vibrating? Is it the brake rotor itself or the bike forks? Obviously if something is slightly loose (caliper, rotor, headset, wheel hub etc) that could cause vibration under braking. But you can also get vibration from one of the components resonating. For example I had an old mtb that used to suffer from a really bad rear frame vibration under heavy braking. It was simply down to the resonant frequency of the chainstays, along with worn suspension pivot bearings. Fitted new pivot bearings and the vibration magically disappeared.
The fact that you don't have this problem on smooth roads does point toward something being loose or worn with play. Loose/worn headset would be my first guess. Play in your front wheel hub second. Probably also worth tossing in a new set of front brake pads to see if that makes any difference. Make sure the rotor is clean, running true and not glazed too.
pan y agua
Quoted: 1450 Post(s)
Liked 731 Times
Seems to me it’s likely fork flex. Bigger rider, hard braking, flex in the fork will result in some flex that will be sort of a stuttering that’s consistent with what the OP describes.
Take away, try to brake more smoothly,and if you get some stuttering with hard braking don’t worry about it.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Likes For Bigbus:
I am potato.
Liked 1,631 Times
Anytime. If I need it back I'll know where to go.
Likes For base2:
I have exactly the same problem
Thank you
Thank you
I have changed the disc brakes and pads. This did not fix the problem. I thought maybe there was a problem with the forks. I replaced the forks and again this did not solve the problem. I'm wondering if this is a design problem.
Did you manage to get to the bottom of your problem?
By the way, I am quite a light weight person (70kg). I don't think being heavier is the issue either.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
If you - completely or lightly - release the brake lever before hitting the pothole, what happens? Dumb question, but...
It's clearly no good to brake while hitting a pothole for various reasons. There's already a good amount of force (vertical) being put on the headset when that happens. When you're also braking, there's an additional force (horizontal, for lack of a better word) acting.
Seems like we need a physicist!
Liked 4,873 Times
I've been dealing with a similar problem with my trek checkpoint alr5 for almost a year now. Your description is almost exact to my experience. Going down a hill if I brake and hit a bump in the road while braking, the front wheel goes into considerable vibration and braking power severely impaired until I release the brake and reapply the brake. On smooth roads I never have a problem.
The hard part is finding out what component is actually resonating. It sounds like you’ve changed most of the obvious parts, but what about the front wheel?
You could also try taping a few small lead weights to suspect components like the forks and see if the vibration goes away because of a change in the resonant frequency. Tyre pressure might also have an effect.
As I mentioned much earlier in this thread, I had a mountain bike that was prone to rear brake resonance through the rear chain stays when the pivot bearings were worn. Bumpy descents would trigger the resonance much more than braking on smooth surfaces, which made it a pain to diagnose.
That does sound like a resonance issue. Hitting a bump under braking is probably the trigger for the resonance, which will then tend to amplify until you release the brake and re-apply.
Your idea about attaching weights is a good one - thanks.
If the wheel doesn't fix the problem then I may have to part company with this bike. I don't think anyone would be rushing to buy it off me though . I couldn't in good conscience sell it without disclosing my problem.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 466 Post(s)
Liked 548 Times
I recently had just such a resonance issue that appeared when I put an older tire back on my front wheel and disappeared the next day after I put on a different tire. Little things can change a resonant frequency.
Likes For DangerousDanR:
Very interesting. When I bought the bike I actually requested different tires. Most of my riding is in the road so I chose a narrower road tire. You may have nailed the root cause. Thanks I will try to revert to the original tires!
Quoted: 466 Post(s)
Liked 548 Times
Maquilina:
Please do be careful. My old Peugeot would do this to me almost exactly at 30 MPH if I was pedaling hard to hold the speed, so I got very used to dealing with a resonant wobble. On the Peugeot I could stop the wobble by pressing one leg against the top tube. There may not be anything "wrong" with anything. It may just be that things add up to being unstable when you bump them like that.
The recent incident was on my Lynskey R350 which is not a flexible flyer by any stretch of the imagination. The front wheel is from Light Bicycle and is a 46 mm rim brake wheel built on a Carbon Ti hub. Nothing dodgy in the front end. Cane Creek Headset in good condition. Oh, I was about 245 pounds when this happened.
This wobble started at about 25 MPH. It showed up in a group ride. I am afraid that I scared the <expletive> out of the guys who were riding right behind me. The leg on the top tube worked to damp the wobble; I do that reflexively thanks to my trusty old Reynolds 531 steel frame wet noodle of a Peugeot.
Liked 4,873 Times
Yes I agree with your conclusion. I may need to try to change the wheel. Are there any other components that could also be considered. As I said, I've changed the brakes, the forks, and as you've suggested I could change the wheel. After that I can't think of anything else.
Maquilina:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Back when I ran my first company (locksmithing) we used to train people to look for the obvious stuff first because it inevitably was the solution (eg trying to see if another door was unlocked in locksmithing).
My first thought when reading this was you're loose on the wheel somewhere. Bearings have play, thruaxle or qr aren't tight, rotor isn't tight, caliper isn't tight, headset, etc. Please take the time to eliminate those as causes. It will save you a lot of this stuff ^ and I would lay odds that's actually your problem.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
I'm no expert but there are a ton of possibilities:
1. Wheel. Remember the brakes act on the hub with disc brakes. Spokes might deflect with the extreme force. I've seen a few e-bikes that actually had major spoke issues with heavier riders.
2. I have noticed that center lock rotors tend to get a little play in the splines if not tightened correctly
3. The forks- the rotor is anchored to one side or the other. When braking, the caliper is twisting that leg commensurate with braking force
4. Frame geometry. Basically the rake could cause a different feel.
5. could the brakes possibly need bled. They might act different under the extreme circumstances. Also-could the hydraulic hose cause an issue.
6. Headset, as mentioned above, could cause this as well
As I stated-I'm no expert, just trying to envision possible causes. With rim-brakes, half the possibilities would be removed. I have both types on my bikes-each one has something to offer.
Good Luck
Good Luck
Likes For Bully4:
