Campy hub bearings
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
Campy hub bearings
Can anyone conclusively state what size and quantity of balls should be in 93-95 Chorus hubs?
Yes, I could measure what came out of the hub but I had them serviced by an LBS around four years ago and I don't trust that they did it right.
Quoted: 4205 Post(s)
Liked 3,863 Times
So what is happening that makes you doubt what the shop did? Have you ridden the bike since? Andy
AndrewRStewart
AndrewRStewart
I thought they were 5/32 both front and rear, could be wrong, so I'd double check. What is it doing that makes you think it isn't right, if you rode it for 4 years might have finished it off?
I believe that they used 7/32 balls for the front and 1/4 for the rear.
https://bike.bikegremlin.com/2255/st...ng-ball-sizes/
According to campy's spare parts manuals for 1994 & 1995.
https://www.campagnolo.com/media/fil...994_part_C.pdf
https://www.campagnolo.com/media/fil...995_part_C.pdf
They use FH-RE006 (1/4") on the non-drive side and FH-RE004 (7/32") on the freehub side for the rear.
And if the drawings are accurate 9 and 10 respectively.
Front uses HB-CH002 (3/16") 9 per side. Again if the drawings are accurate. 3/16" doesn't sound right to me. But that's what my search came up with.
Measure what's in there to make sure.
