For the love of English 3 speeds...
1960 Royal Enfield Superlight 3 speed anybody?
Love the 3 speed thread: )
Here's my latest Ebay find. A Royal Enfield Superlight Tourist with original 3 speed AG hub dated 1960. 531 main tubed frame is always good?
Note the front hub brake. And Raleigh chain-set with removable rings! New to me. The front lamp is cool too.
These are normally 3 speeds with 26" steel wheels.
Bought it for the frame, but the original paint on this one is possibly worth keeping? (Was intending to powdercoat it: )
I've already stripped it down & rebuilt it with a set of 650Bs from another machine just to try it out. I'm looking at using 700 alloy rims eventually.
Rides like a 3 speed should, but it needs brakes...
Alloy rims = good brakes & this is my other 1955ish RE Superlight frame built up as a Town Bike/Light Tourer with an FM 4 speed hub.
These frames take 700 rims with room for guards, so it is an obvious upgrade. Mainly for good braking, but also lighter: )
Love the 1950s Royal Enfields; ) The above is 26lb as seen & very nice to ride.
I'm keeping a diary of this ones progression on my website if you are interested: Royal Enfield Superlight ? Bicyclz.com
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
With an AW there's no moving the hub left or right on the axle. I imagine the AG is the same way. You can get a right side axle nut that combines, into one piece, the hex nut and the part with the indicator window. That will solve the insufficient threads problem. As for the indicator chain, the length is correct when with it pulled out all the way the rod peeps a little bit over the end of the axle. But a shorter one should work, in my experience. But you lose the handy visual guide to position.
Quoted: 457 Post(s)
Liked 462 Times
I've never put anywhere near that level of stress on an AW but I can tell you this. I think the most likely point of failure would be the splined joint of the cog to the driver. I would stick to 1/8" cogs not the 3/32". Every bit of purchase helps. Also, sometimes the drivers aren't machined perfectly and there can be either too much slop or too tight of a fit so the circlip doesn't fully engage in it's channel. It's rare, but I have run into both of those conditions over the years.
Out of the bike would be more precise, you could make a couple of chunks of 2x4 with a hole drilled in them and cut them in half so you could clamp the steer tube in a vice then work one leg at a time, you could put a long 2x4 between the legs of the fork to pry on the end of one leg with the other end of the 2x4 right up against the fork crown.
Quoted: 331 Post(s)
Liked 332 Times
Hey all,
I've got an issue with axle room on the drive side for the three speed cog. When I place the original washers in their position as found when I disassembled, there isn't enough room for the axle to slide into the drop out with enough leftover for the indicator chain bolt (the name escapes me right now). If I remove spacing washers, the tube is too close to the cog set which results in chain rub. Any thoughts? I'm new to setting these up so it's a bit confusing. Did I somehow move the axle too far toward the non drive side? Photo:
3 speed freewheel on a 1946 SA IGH 4 speed.
Quoted: 331 Post(s)
Liked 332 Times
Hi DQ,
Been anticipating your winter project for a while. Thought maybe your prang was worse than you let on.
Good to see you back. Can't wait to see your latest masterpiece.!
Quoted: 1299 Post(s)
Liked 103 Times
I hadn't considered that being a point of failure, I was figuring that something inside the hub would give first. To shear off 3 of the splines on the cog would really take some torque though, the cog is hardened steel.
Inflate Hard
Inflate Hard
Quoted: 457 Post(s)
Liked 462 Times
They don't sheer off. If there's too much play between the shims and the circlip, the round splines will tip side to side, want to cam up and make a mess of the channels in the driver. Or, if the fit is too tight, it's possible to think the circlip is seated when it isn't fully. There was one other failure I saw from a member on this board. He had a crunched sun gear. No idea what caused it and I have never seen this myself, but I have seen buggered up spline channels on drivers a couple of times. Both from loose fitting cogs I believe and I dont think they were under anything close to the stress you're talking about.
There are certainly other 28 hole AW hubs for sale on Ebay, so worst case scenario if this one fails I can get another.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
I probably have a 28H, as well as 32H and 40H.
Quoted: 457 Post(s)
Liked 462 Times
Ahhh, good to know, I bet there are more than a few lurking in workshops of people that frequent this thread!
Current wheel is 28H so thats what I'd need if this one doesn't survive...
I figure I'll oil it before and during the ride to give it the best chance of making it, and ultimately I've put so many miles on Sturmeys over the years with zero issues that I'd be a little surprised if something actually happens to this one on a long steep ride.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Don't mean to be a contrarian but 32? Pics?
edit. Well, there's a bunch of newer 32 hole SA IGH hubs on ebay, 5-8 speeds, 2 speed kickbacks etc. Who knew?
No AW's though. I'm thinking these new ones are for 130 mm frames.
Liked 2,446 Times
All my stuff is old and I'm pretty sure I have a 32H out in the garage. I'll get pix of the ones I have.
Phyllo-buster
Liked 2,054 Times
Quoted: 350 Post(s)
Liked 24 Times
Pretty good about the adventures of a three-speed Moulton and also some about its human owner.
Liked 2,446 Times
Well, I might have misremembered. I could have sworn I had one of each drilling but could not find a 32H when I looked today. I have a loose 28H, two loose 40H, and I also have two 36H in built wheels. All those in addition to the ones (4 x 36H) that are on bikes. So, I will keep looking but last time I went through this stuff I tried to put all like items together. Sorry for the confusion but we're still at the point where I might or might not have one of the 32H.
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Update on the '52 Sports. WD40 flush of the IGH got things moving again, but I've been unable to hook up and ride, as the front tire has succumbed to dry-rot. Anyone successfully coax a modern 700c wheel with 100mm hub into these forks? I'm not quite strong enough to pry them apart, so I may do a cold set with threaded rod.
Quoted: 457 Post(s)
Liked 462 Times
I'm just posting so I can get to 10 posts so I can post pics.
Quoted: 457 Post(s)
Liked 462 Times
One more post, because I have a couple of sweet Hercules that I want to post pics of in the "H" thread.
Quoted: 457 Post(s)
Liked 462 Times
This is my 10th post, so I can technically post pics now, but, I can only post 5 times in 24 hours soooo, see you guys tomorrow night!
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Liked 2,446 Times
Phyllo-buster
Liked 2,054 Times
Quoted: 66 Post(s)
Liked 185 Times
I got this Hawthorne Hercules about a month ago, the hub is dated 10 of 62 , I don't see any bikes with the Hercules name with this style chain guard did they mix in Raleigh parts on some bikes?
Original Tires?
Original Tires?
Bikes: Some Schwinns, Raleighs, Centurions, Crescent, Bianchi
Quoted: 248 Post(s)
Liked 289 Times
It looks identical to the chainguard on my 63 Armstrong too.
Quoted: 350 Post(s)
Liked 24 Times
No kidding. I really know her just from Help and Bedazzled but I will now try to watch more. The book is self-effacing and very well written, and she hits her stride in the second half with a trip through the Netherlands, which she loves, and a visit to a windmill that is as good as any travel writing I know. Used copies might as well be falling off trees, they're that cheap and easy to find.
Liked 103 Times
It is a Raleigh chainguard. Mudguards too. That is an unusual model. Looks all original. Even the torpedo grips. Odd that they left the Hercules transfer on a bike badged for Monkey Wards. I suppose TI was using up parts from the Birmingham factories after they bought out Raleigh in 1960 and moved all production to Nottingham. Cool bike.
Inflate Hard
Inflate Hard
