Dealing with sand in corners of commute?
Semi new cyclist here.
I just took a nasty fall today due to some fine sand in the bike lane while rounding a corner, trying to keep up with traffic. The sand caused my front wheel to lose traction and I hit the deck pretty hard. What is y'all's technique for dealing with sand and other slippery conditions on road bikes, especially those with clip pedals/fixed gears?
Should I just unclip my foot from the inside pedal to catch myself if sand/water/oil makes my front wheel slide out like they do on dirtbikes(or some equivalent for those on fixies)? Are there tires that better handle sandy roads(like those hybrid mountain bike-esque tires?)?
I just want to prevent this type of accident from happening again any time soon. My bike is okay luckily, but I'm not. What is your slippery road accident avoidance?
Goes to 11.
Bikes: 2015 Soma Double Cross
The best advice I can give is to always look as far ahead as you can. Failing that... How to Crash | Bicycling
Quoted: 539 Post(s)
Liked 44 Times
1. Watch out for it
2. Don't hit it
3. Never prioritize keeping up with traffic over watching for bad stuff like sand on the road
There's just really not way to deal with sand other than avoiding it. You can also try not turning if you're hitting it (the wheel turning makes it worse). I don't usually try to brake beyond lightly braking either.
But it's just a hazard no bike can handle, until you get into fat bike (like a 4" fat tire) tire sizes.
2. Don't hit it
Bikes: Fitz randonneuse, Trek Superfly/AL, Tsunami SS, Bacchetta, HPV Speed Machine, Rans Screamer
Quoted: 100 Post(s)
I have spent much time riding on beach sand over smooth concrete. It is like little ball bearings, and deserves much respect. Practice is your best defense; learn its limits and behavior in a safe place with elbow and knee pads to gain confidence and speed.
On the technique side, I scan ahead for potential problem spots, slow and try to coast through as straight and smoothly as possible, turning more sharply before and after, where the surface is clean.
On the equipment side, I use 42mm tires with a file tread pattern (often worn smooth) at lower pressures. Knobies don't seem to grip any better, but just have poor grip on pavement all the time. The sand only can take so much shear force before it slides and rolls like ball bearings. If you engage twice as much sand with a larger contact patch, you get at least twice as much grip, and the transition to slipping is much slower.
Quoted: 18376 Post(s)
Liked 4,511 Times
I agree with others, don't over-ride the conditions of the road.
What is the source of this sand? I've thought about bringing a broom to sweep some of the glass and debris off of my commute rides
Traction has been hotly debated, and unfortunately, I don't want to force myself into a crash.
My driveway has some fir needles on it. Then when it gets wet, I loose traction for standing hill climbs.
Last winter, I observed that with my mostly bald Origin8 Elimin8er tires (25mm), I would loose a full half pedal stroke whenever I broke the wheel loose. It just would spin.
When I mounted my Schwalbe Marathon Plus (25mm) on the rear of the same bike, I would still break the wheel loose, but I could feel about 50% traction as it would spin.
I attributed the difference to the minimal tread that would get some bite, but perhaps a different rubber too. I'm hoping to do more rigorous testing next winter.
For hill climbing traction, I've also noticed the body position is vital. So, sitting I get more traction as well as a smoother stroke, to the point where I have almost 100% of the weight on the rear wheel.
Practising slides?
Would much rather deal with road rash than that.
Quoted: 800 Post(s)
Liked 218 Times
Semi new cyclist here.... What is y'all's technique for dealing with sand and other slippery conditions on road bikes, especially those with clip pedals/fixed gears?
Should I just unclip my foot from the inside pedal to catch myself if sand/water/oil makes my front wheel slide out like they do on dirtbikes(or some equivalent for those on fixies)?....
1. Watch out for it
2. Don't hit it
2. Don't hit it
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
My best advice is simply to slow down on corners. Keep looking ahead and dial it back if you see sand ahead. Try to avoid braking while on the sand, and use both brakes if you do -- using just the front brake will take you down quicker than anything.
In my 40+ years of road cycling, I have never been hit by a car. But I have crashed from sliding out on corners three times. I treat corners with much respect now, particular when roads are wet, sandy, gravelly, oil and/or very sharp.
Adding to the above advice, try to ride straight through sand, even in a corner. Also, getting your weight as far back as possible may keep the front wheel from digging in and may allow it to float over the sand somewhat (with the emphasis on "may"). Wider tires can help. I was recently riding a fully loaded tourer on hard packed sand slowly and straight, and as soon as I hit softer sand, the front wheel dug in and I went down. No harm done and I was anticipating it, but even then, sometimes there is no way to avoid falling, other than stopping and putting your foot down.
Bikes: Trek Mtn Bike
Quoted: 282 Post(s)
Liked 2,644 Times
My technique is to watch for patches of debri. Avoid if possible. Slow down before you hit it. If possible straighten out your line. Blind corners should be approached with caution.
For those times I am caught unawares. Slow down by stopping pedaling. Straighten my line. If you lose traction you're not going to continue the curve anyway. Either prepare for the crash or look for a way out.
My technique may not be the best. Liked the link above about how to crash.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Well, if it is on your commute, you will quickly learn the personality of the terrain you are riding and what to watch for. If not, the best advice is to watch the terrain and slow down if you are unsure.
I don't know what kind of tires you are using, but a cyclocross type tire is 10 times better than a rounded road tire. I just did a mixed route home last night on a road tire that is bigger than my cyclocross type tire, and it was a hand full on the soft sections.
1. Watch out for it
2. Don't hit it
2. Don't hit it
I've had the front wheel slide in such situations, both on bicycle and motorcycle, but only been down as a result once, when there was actually ice all over the corner. And I don't think much would have kept me upright in that particular situation.
To the above, I would add:
4. Brake before the turn, not through/during it. You need all the traction for steering at that point, don't waste any of it on braking.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
You should be constantly alternately scanning the traffic all around you, and the ground far enough ahead of you to stop in time. Just go around the sand. Stop and wait for traffic to clear if needed, or do whatever is needed to avoid it.
Bikes: A bunch of junkers and a gem or two.
Quoted: 11 Post(s)
Glad you're ok. Falling is bad. Falling in traffic can be catastrophic. That is one of the reasons I ride a more upright bike, to be better able to see whats coming.
I used to ride a kind of hybridish tire, the WTB Nano Comp. Once I wore them out, and had a really good idea of what my commute entailed, the most "road" type of tire I use is the schwalbe big apple. Even that tire is slick enough I had to get used to lower traction again.
I know a lot of people really like them, and get great results with them, but my own personal opinion is that true road or race bikes do not make for good commuter bikes. Especially if that bike still has the road or track tires.
Bikes: 2014 Cannondale Synapse Carbon 4 Rival; 2014 Cannondale Trail 7 29; 1972 Schwinn Suburban, 1996 Proflex 756, 1987(?) Peugeot, Dahon Speed P8; 1979 Raleigh Competition GS; 1995 Stumpjumper M2 FS, 1978 Raleigh Sports, Schwinn Prologue
Quoted: 213 Post(s)
Approach it like you would if driving on snow and hitting an icy patch, or if you have no experience with that, than as you would if you were hydroplaning. Ride through it, straight and with no added speed or applying of the brake. Don't focus so much on keeping up with traffic until you have achieved good bike handling skills. Traffic will go around you. Of course, avoiding sand all together is preferable.
Experience: Columbia and Lexington, SC are full of sand deposits that can be unavoidable.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Slow down.
Ride slower than you think you need to until you know your route.
I dropped my bike on some loose sand a few years ago. Every time I take that corner, I take it very slowly and mostly upright.
Don't worry about the cars, let them worry about themselves. Going down in traffic is THE WORST possible thing that can happen. Anything that you have to do to avoid that is prudent.
Work: the 8 hours that separates bike rides.
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
I assume that every corner is going to be sandy/slick/a danger spot so I ride accordingly. The closer you are to the curb, the greater the chance that you will lose traction taking that corner. If possible, I will take the entire lane to make a turn onto a side street. Trying to ride where car tires go decreases the chance that there will be debris in that path, to include sand/dirt.
Bikes: '93 911 Turbo 3.6
Quoted: 109 Post(s)
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Sorry about your wreck. Don't corner through sand with slicks.
Genesis 49:16-17
Genesis 49:16-17
FoxMulder
General Cycling Discussion
13
07-02-18 01:33 PM
Coltons09
30
09-05-16 09:21 AM
