Seatpost setback question
I currently have a 2012 CAAD10 and I was wondering if anyone had any suggestions if my seat is currently in the middle of the rails, after my fitting was done, should I get a 0sb or a 20mm sb seatpost. I would assume 0 but the factory post looks as though its setback a bit but I can't find any technical data about it.
Another seat post like Thomson's a zero setback design, is a good choice..
premium quality and made in many diameters in and other than 27.2.
I cannot see the fit, on your bike, of you, remotely..
good luck.
You could always collect that yourself with a meter stick/tape measure.
good luck.
I currently have a 2012 CAAD10... assume 0 but the factory post looks as though its setback a bit but I can't find any technical data about it.
Quoted: 4210 Post(s)
Liked 3,875 Times
Did I read right that after your fitting the seat post is centered on the rails? If so then I consider this to be the best situation to end up with. You know, photos help explain things words don't. Andy.
Measure the setback of your current post. It's just the dictance from the center of the post to the center of the seat rail clamp. Why do you need a different post?
I usually recommend again a zero setback. There are few road bike frames where the seat tube angle is slack enough for a zero to be appropriate.
From the description why do you want to change it? Sounds like all is good with what you have now.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Quoted: 5793 Post(s)
Liked 2,584 Times
If your saddle is centered on top of a zero setback post after a professional fitting, and the fit feels comfortable for you, then you'll want to replace the post with one of similar setback. (if there's a reason to replace the post at all, but that's up to you)
FB
Chain-L site
FB
Chain-L site
