Pre-Waxed Chains?
Quoted: 457 Post(s)
Liked 112 Times
Pre-Waxed Chains?
Even though I work in a bike shop I still get surprised!
A few days a guy buys 2 11 speed chains for a bike we are servicing. He wants to take them home and wax them and then return them for use to finish the service. So yesterday he comes in to return the chains as he bought a Silca prewaxed chain @ $100!
I wax all my chains at home but apparently the Silca chain "special" wax.
Wow $100 chain.
Wow $100 chain.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I might go $100 on a lubed for life chain.
But a waxed chain lasts me 4-6 weeks and needs another dip.
Barry
Barry
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Silca does an excellent job of separating people from money.
Stuart Black
Stuart Black
Likes For cyccommute:
I certainly wouldn’t pay it because I like to do things myself and have the time, but I understand that if you have enough money and value your time more than the dollar cost of about $50 on top of the chain itself, it’s a perfectly good option.
Likes For NumbersGuy:
Clark W. Griswold
Quoted: 4371 Post(s)
Liked 4,011 Times
Silca does some neat products but the pre-worn waxed chains are a little bit much for me and I think CeramicSpeed or one of those others also does it. I get the marginal gains crap it is boring but helps people win but for the average person I think just buy a normal chain and wax yourself or ask your shop to do it and leave the ultra fancy stuff for the sponsored pros.
Likes For 50PlusCycling:
Quoted: 18432 Post(s)
Liked 15,587 Times
You can order almost the entire menu at Taco Bell for $20. Of course, you’ll need money for Pepto afterwards. 🤮
Likes For indyfabz:
"You can order almost the entire menu at Taco Bell for $20. Of course, you’ll need money for Pepto afterwards."
Hence the nickname "Taco Hell".
Liked 15,587 Times
Quoted: 569 Post(s)
Liked 590 Times
My daughter's shop in Portland charged her $50 for a CN-HG901 and if they cleaned and wax at their hourly rate the Silca would be cost effective.
Quoted: 2700 Post(s)
Liked 486 Times
So let’s say you get one of those pre-waxed chains, how long does it last before you need to use more lube? Is it similar to the chains lubed at the factory on a new bike?
when it does wear out, can you just put oil on it like a normal chain, or does the residual wax mess this up?
Liked 15,587 Times
Quoted: 4806 Post(s)
Liked 3,933 Times
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 133 Post(s)
Liked 304 Times
Wow $100 chain.
Wow $100 chain.
https://www.sram.com/en/sram/models/cn-eagl-xx1-a2
Suppose it begins with "what chain?" since I'd be happy to kick in $8 and skip the degreasing, de-watering, heat and dunk process for that.
Still, "I can remember a day" when $8 bought a nice name-brand fresh chain.
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
I wouldn't pay a lot more for it, but it would be nice if someone sold chains not coated with "Cosmoline" for those of us who use PTFE or other oleophobic lubricants.
Likes For MoAlpha:
Liked 4,222 Times
The "Cosmoline" on the chain is a wax. It's a soft wax but a wax nevertheless. It is not incompatible with oil or the hard wax that is currently in vogue. It doesn't really need to be cleaned off the way that people seem to think it needs to be. It's certainly not "Cosmoline" which was a mixture of wax and oil. Even that mixture were still being used is not incompatible with any bicycle chain lubricant.
Stuart Black
Stuart Black
Um...what "oleophobic lubricants" are you trying to use? Polytetrafluoroethylene is phobic to everything. Something that is oleophobic or hydrophobic doesn't mix with oils or water, respectively. PTFE mixes with neither. You can suspend it for a bit in either oils or water but not for long. In bicycle lubrication applications, the PTFE is mixed with an oil or similar carrier (wax is a similar carrier) and there is nothing in the factory coating that is incompatible with either oil or wax.
The reason it's recommended to strip off the factory lube is that it collects all the dirt, dust, and road grime that creates the nasty black mess that waxing mostly eliminates. Now that I use wax, my cassette and jockey wheels stay clean and a simply microfiber wipe down of the chain cleans off the tiny bit of dirt/dust on the surface. I can touch these parts after a couple hundred miles without any gritty black mess on my hands. While mixing wax with factory lube might perform just fine from a lubrication standpoint, I would think the resulting mix would end up retaining some of the undesirable properties which cause factory chains to quickly develop that lovely black gritty mess that gets onto the rest of the drivetrain.
