For the love of English 3 speeds...
Quoted: 478 Post(s)
Liked 634 Times
I had made a press out of a large C clamp and a socket that worked pretty well for “normal”
situations; I bought a bikesmith press and it worked “better” - ie more easily and with less chance of messing up - but it was not night and day better; it also has trouble with slim cranks as it’s quite a substantial tool.
Quoted: 3810 Post(s)
Liked 6,702 Times
Good price on a matching set of mid-70s Sports in southeastern MA:
https://boston.craigslist.org/gbs/bi...916156615.html
Bikes: '71 Peugeot UO-8, '83 Trek 720, '81 Trek 412, '83 Trek 620, '72 Atala Competizione, '51 Raleigh Sports 'C' Tourist, '58 Raleigh Sports, '91 Bridgestone MB-1, '94 Specialized StumpJumper
Quoted: 45 Post(s)
Liked 64 Times
Some where on this forum there are instructions for making a cotter press from a Harbor Freight chain breaker. I made one a few years ago and have been successful with all of the extractions except one where the crank profile was so slim that there was not enough space to align with the pin.
https://www.bikeforums.net/classic-v...ter-press.html
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
My feeble take: torquing on the crankside makes those a little more harder to drive out. Mine are of the nonR-nut variety. They were also driven in quite deep. The NDS cotter slide right out so I think it had something to do with the placement or torque on the pin. BTW, the tool used was the old Park cotter one and both sides had 2 days of soaking before the operation.
I so wanted to find a sock!
The part number on the crank spindle facing up was just PURE luck!
They're like the Willy Wonka chocolate bars.
Liked 443 Times
I've given some thought to this issue, but I still have more questions than answers. Even in this case, you can see from the picture that unlike aluminum stems and seat posts in steel frames, corrosion wasn't the cause. Even in the LBS where I worked, mechanics in the day would just hammer cotters in. For a long time, I guessed stuck cotters were just the result of being hammered in too hard. But now I wondering if perhaps the alloy they are made from is involved somehow. I've removed many cotters over the years. Probably not enough to be of any real statistical value, but enough to get an impression. I too have noticed that cotters from bikes from the 50s seem to pop out without much fuss and the only time I've had to resort to plan B was on later models. I have also noticed that the alloy of the old cotters...and Bike Smith cotters as well... looks different than more modern cotters. There's no finish on them. They're not very hard and are highly rust resistant. Just a thought.
I suspect the older cotters had some soft lead in them...
Quoted: 1299 Post(s)
Liked 103 Times
I suppose it will remain a mystery. It is an interesting question of why people are sometimes forced into extreme measures to remove cotters when there doesn't seem to be any rusting involved and other times cotters that hold the crank arm on just as securely press out easily. The alloy may be a factor, maybe not, but knowing what I do about Raleighs, it wouldn't surprise me one bit if the bean counters at Nottingham in the 70s could have saved 2 cents by using cheaper cotters, they would have done it.
Inflate Hard
Inflate Hard
Liked 443 Times
A penny saved is a penny earned.
Slacken off the nut a few turns, offer up the frame horizontal and place in the vice. Place one jaw of the vice against the crank opposite the stuck pin, place a socket over the pin top so it clears the pin and presses on the crank body. Place the other jaw directly on the slackened cotter pin nut opposite and press the pin out.
Last edited by Alloyboy; 06-21-19 at 10:08 AM. Reason: I can't spell. I'm such a nut, typed "h" instead of "n" originally.
Quoted: 1858 Post(s)
Liked 664 Times
Little oil, drill, punch and repeat.
All nice and clean!
Still ready to do the job after 40 years!
Success! Fighting all the way but the cotter finally came out. All BB parts shiny and free of wear. I found chunks of old grease and a petrified wasp but no sock. The Teflon spray was helping it but new grease is what it needs.
The drill bit stayed mostly in the pin but towards the bottom drifted out into the crank. I can see a little divot out of the wall. Both openings are still round. I will be getting new pins, most likely from Mark.
I decided the only hope now was to cut out the cotter from the inside - round files. Thin the remaining cotter wall until it was "very" thin, then re-attach NDS arm temporarily and use that leverage to crush the thin-wall cotter. I tried several round mill bastard files, with not much success. What REALLY worked were the various sizes of chain-saw sharpening files - they're also cheap! It still took maybe 10 hours of filing to thin it down, but the strategy worked!
I'm quite disgusted with the whole cotter-removal adventure and intend to ultimately rebuild the Rudge with a TA spindle in the original cups and a vintage TA 5-pin. But I think my first build will be to re-use the original chainset, spindle, and wheels. I now have a lot of hot-rodding parts (alloy rims, an alloy FM, the TA chainset parts, English threaded Berthet pedals), but I'm gonna ride it before I take on the bigger jobs.
One of the bigger jobs is to get a granny capability. The stumbling block is to maintain chain tension. Chain alignment may be an issue as well. It is theoretically possible to shim the Raleigh BB cups to jink a TA double chainset to the right, but I have no clue if such shims (properly fitting) are available. this relationship is generally (I assume) the responsibility of the bike manufacturer, and we owner/tinkerers are left with the "simple" task of managing chainline and chain selection.
I may go to a rear derailleur of the era. There are a few out there designed for owner installation, but I'm not sure I see yet if a claw under the wheel attachment bolt can well-secure a rear mech and allow the indicator window to be used.
So my first shot is going to be to clean out all of the bearings (the original AW seems to be in pretty decent shape), dabble in touching up some of the rust, and see how she pedals!
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
Bikes: Miele Latina, Worksman INB, Rapido Eska Folder, Raleigh Superbe, Raleigh Sprite, Soma Stanyan 650b, VeloSolex 3800, Raleigh Competition GS, CTC Supercycle, Raleigh Sports
Quoted: 25 Post(s)
Liked 9 Times
The modified Harbor Freight chain breaker does work. I used it to remove and replace the existing cotters on 3 bikes so far. A worthwhile addition is a brass screw inserted into the end of the press to prevent scoring marks on the ends of the cotters.
Liked 103 Times
I had to use a similar method of last resort on my Rudge. The Mark press took out the non-drive cotter instantly, like butter. I don't know how they were doing things in 1952! The drive-side was rather narrow and the Mark press did not squarely hit the threaded end, so it bent. I pushed it back up straight to try hammering with a drift, but that just collapsed the stud and it broke off. I then tried driving it with a Ľ punch, which only deformed and expanded the end, tightening the fit - made it worse. I then took a pin punch, located a drilling point and started with a pilot drilling. Progressively going through my drills, I cut out the inside of the cotter until I felt I could not control the cutting so as to protect the spindle and the chainset. But still no budging of the pin!
Inflate Hard
Inflate Hard
Liked 664 Times
And my plan is to build initially with the original parts.
Before teardown.
Liked 443 Times
Good News
The Toronto Vintage Bicycle Show has been approved by the City!
All Systems are Go!
All Systems are Go!
Liked 443 Times
It's not the Red Hand of Ulster, sorry! The bike is a 1952 Rudge Aero Special, clone of the Raleigh Super Lenton of the same year. Raleigh used a more plain chainset on the Raleigh, Rudge, and Humber siblings. Previous years used chainsets with brand insignia, but not in 1952 on the 27, 127, and 327. The Rudge is Model 127.
Before teardown.
Before teardown.
Liked 443 Times
OT
A friend of mine is looking for another bike.
She already has a nice 3 speed Hercules that I
gave her as a gift last year.
This German Hercules Estrella is for sale up the street.
It's a good lookin' bike but I don't know
much about them.
much about them.
Liked 103 Times
Sure is. These bikes have always been sort of a Grail to me. In all my years of bike hunting, I have yet to find a neglected club machine that needed rescue. I still have time left in me. Maybe it will come along. This story does put a hole in my older cotters theory. Still, I think the answer to removing a cotter once it bends is to center punch, drill down until you have a centered counter sink, support the crank and drive with a punch. I think supporting the crank is crucial.
Inflate Hard
Inflate Hard
Liked 664 Times
Quoted: 457 Post(s)
Liked 462 Times
I've swung hammers for so long that hitting the frame wouldn't be the slightest concern to me, same should be true of anyone doing it for a decade or more.
Liked 664 Times
Great! I don't use them very much. Besides, now the cotters are out.
"When I nod my head hit it."
I went through three blacksmiths before they gave me a job in the welding shop. Giggle.
Likes For Alloyboy:
First peek. Fresh off the truck. The guy got it from his aunt, didn’t want it. I went to look at it at an asked price of 50. After explaining about English 3 speeds, Phillips history and particulars to watch out for he stops me and says i’m The man for this bike. I made him take 20.
1967 8. Phillips Summer of Love, baby!
Likes For 3speedslow:
Rust has started to take hold but not too much on most surfaces. The worse area is on the handle bars and test removal with brass brush gets most of it gone. I’m confident the chrome will come out shiny. The paint is solid but rough. Seems to have bumps all over it. Polish and wax will see.
Tires hold air, gears shift through all 3 and the crank turns freely. Brakes grab hard. It’s all only gonna get better as the love goes back into this bike...Groovy man!
I like the chrome on the fork crown. Fenders and bell and carrier. Twenty bucks! You are my kind of shopper.
