Calories burned
Calories burned
I got some power meter pedals. Now my Wahoo Roam is reporting about 1/2 of the calories burned vs before I had the power meter installed for the same ride. As a guy who'd like to drop a few pounds and is using cycling to do that, I'm perplexed. Which one is the closest to being correct?
Quoted: 6199 Post(s)
Liked 4,816 Times
PM's give a better estimate of Calories burned. Other ways to calculate Calories can vary wildly depending on the person and circumstances. So maybe your Wahoo now uses the PM data in the Calorie figure they report since you've added it to the system.
Or are you just seeing a difference in the Calories and kilojoules that is now displayed by your device?
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 646 Times
https://www.welovecycling.com/wide/2...d-on-the-bike/
if the power meter is able to give 'average wattage'
or
(Avg Watts/per hour) x 3.6 = Kcals
so avg watts of 200 ridden for 45 min x 3.6 = 540 Kcals
average Kcals available in 1 lb. of Human Fat is approx 3500 Kcals
Best way to figure weight loss, take your weight, nude, at same time of day, once or twice a week, compare. I prefer to do this just after waking.
then compare to tape measure reading (using metric tape measure) in key places...
We're all way better at BSing ourselves than actually exercising weight control...
Ride On
Yuri
Quoted: 506 Post(s)
Liked 639 Times
Likes For KerryIrons:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I'm always a bit suspicious of any data put out by a fitness app. I mean, they're very accurate with time and distance, but health and training stats are just estimates.
Garmin tells me my estimated VO2 max is around 45 or 46. I'm like, "Okay, cool!" Then it says I'm in the top 15% for my age and gender, and I think, "Seriously? Me?" It goes one step further and says "Your Fitness Age is that of an excellent 20-year-old." At that point my 53-year-old self says, "No way. They're just trying to keep me using their products."
Quoted: 506 Post(s)
Liked 639 Times
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
The only metric that matters is whether your pants are getting tighter or looser. Rest is "third-hand commentary."
Likes For blacknbluebikes:
Liked 4,816 Times
Don't be fussy about the accuracy of the Calories burned. That number you calculate for food you consume isn't really accurate either. That small 149 gram apple you may have recorded doesn't always contain 78 Calories.
The numbers they provide for Calorie content for produce and other things are just averages. And sometime the products actual Calorie amount varies widely depending on ripeness and other circumstances and conditions.
It should suffice that if you gain or don't lose weight, you either need to do more exercise or eat less. No rocket science and no exact knowledge of Calories needed. Just pick the way to obtain the numbers you want to track and don't get overly concerned why another thing tells you different.
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
Keep the chain tight!
Likes For Trsnrtr:
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,446 Times
Ride On
Yuri
Calories burned, as others have pointed out, is a complex equation. Any equation will be more accurate the more information you give it. Before, whatever thing you were using to figure out the amount of calories burned was making a lot of assumptions. Now it's got one less thing to assume, making it that much more accurate.
So, answer your question, I'd be willing to bet money it's more accurate now than before.
Liked 2,981 Times
Power meter over app calculated numbers.
Are you trying to just lose lbs or fat lbs? If the later, you would need to find out your body fat # pre trying to change it 7 then do periodic body fat # follow-ups.
-Oh Hey!
-Oh Hey!
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
I began cycling, after a 15 year hiatus, about 3 months ago. I've since lost 12 lbs without changing my diet much at all. Course' I never did tend to over eat and my job requires I sit at a computer for most of the day, so I suspect it depends a lot on the circumstances. As always. YMMV
Likes For Broctoon:
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 87 Post(s)
Liked 132 Times
I’m a firm believer in calorie counting for weight loss. 2.5 years nearly 97 pounds as of today, my low was April when I crested 100 lbs…..but that made me sound fat, lol weigh every morning that I can.( if I’m home I weigh myself) I’m 6’1 and 55, my goal is 185. (It was 200) I may re evaluate again and try to be at 180.
you simply can’t out run or out ride a fork. It’s not the calorie itself, the calorie is simply a unit of measurement, and yes you have to burn a few more calories than your body needs to maintain itself.
Likes For Bogey Speedwell:
Liked 2,981 Times
laxatives, kale, eggs, & prune juice. Those calories won't know how to hold on [in] !
-Oh Hey!
-Oh Hey!
Quoted: 505 Post(s)
Liked 638 Times
That's not what I said. Cycling burns approximatelly 400-1200 calories per hour depending on intensity. Excersice is important in order to maintain or loose weight for various reasons, but the actual calories burnt, while certainly part of the equation do not themselves lead to weight loss.
Liked 2,981 Times
having money doesn't automatically make you wealthy.
.02
.02
-Oh Hey!
-Oh Hey!
Quoted: 4420 Post(s)
Liked 4,873 Times
Quoted: 365 Post(s)
Liked 419 Times
I'm no expert, but I think that it doesn't really matter which is more "accurate". What matters is that you have a consistent way to measure your calorie expenditures so that you can determine empirically the effects of any changes that you make (in diet, duration of exercise, intensity of exercise, amount of sleep, etc.) on your weight change.
Short term, that can help you to determine what works and what doesn't, and to determine how much change (broadly speaking) you can expect. Long term, of course, everything changes. Your body adapts, seasons change, you get older, and so on. Again, though, having a consistent measure can help you spot those changes as well, and you can take them into account.
Quoted: 185 Post(s)
Liked 36 Times
Power Meters Generally....
Likes For wheelreason:
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
Believe the PM. It is giving you a real measurement of the amount of work performed on the ride. The only uncertainty in estimating the number of calories consumed to perform that work is the efficiency with which your muscles convert chemical to mechanical energy and that doesn't vary much across healthy people. The fitness app is just guessing, based on numerous assumptions.
