Addiction LXXVI
#3151
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
#3152
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
edit- just found this
24 cylinders 12 superchargers
#3153
Quoted: 20810 Post(s)
Liked 9,456 Times
try running it on partial choke see if it improves. If it does get better it still ha a blockage.
Also, water is a problem with small engines. Drain the fuel completely. Put it in a glass jar and let it settle. Look at the bottom, it will look like a bubble if there's water in it.
The water settles to the bottom and gets sucked into the pick up, but it's to thick to be drawn into the small diameter holes in the carb. So it will settle in the bowl and fowl things up.
#3154
Should Be More Popular
Quoted: 22599 Post(s)
Liked 8,925 Times
I drained the gas and treated with sea foam (which is supposed to clear out water and crud) but no dice. Sad!
#3155
Liked 9,456 Times
Seems Addiction has morphed from a pills & ills thread to a snowblower support group.
#3156
So it is
Quoted: 11402 Post(s)
Liked 4,759 Times
The nose of that thing reminds me of that clown truck in Maximum Overdrive. One other question.... Why the exhaust stack behind the sleeper?
#3157
So it is
Liked 4,759 Times
Black smoke out the tailpipe equals rich running. Look on Ebay, and grab a 10 dollar carburetor. Sunk float, crud in the needle in seat, ethanol boogered up the innards. Many possible issues.
Likes For LAJ:
#3158
Liked 8,925 Times
#3159
Quoted: 18416 Post(s)
Liked 15,555 Times
It just occurred to me that we are being let go 3 hrs. early. Since I arrived here at 7 a.m. intending to knock of my usual 3 p.m. to beat traffic and find parking at home, I should have left at noon. I am going to march into the president's office and demand 2 hr. of comp time.
#WorkersoftheWorldUnite
Likes For indyfabz:
#3160
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
We had wind and snow overnight. Installed a new o-ring on the snowblower's carb bowl and I got through the driveway and sidewalks, but it's still going through periods of running rough and bogging a bit when moving lots of snow. What gives? Did I just do a **** job of cleaning the carb or should I check elsewhere?
#3161
smelling the roses
Liked 901 Times
90° as I write this. Light wind. I'll be going out shortly
#3162
Bikes: 2 many
Liked 323 Times
One is supposed to drain the gas out before putting it away for the season. Some of the newer needle valves are aluminum instead of brass. They corrode quickly if there is water around. Take it apart and look at the needle valve if you can.
#3163
smelling the roses
Liked 901 Times
But will it prevent daughter one from missing both the parade AND the trip to Spain?
#3164
Liked 8,925 Times
I expect she will still perform. Those marching band kids are scrappy, kinda like cyclists. They will put up with a decent amount of suffering.
#3165
Liked 8,925 Times
#3166
Bikes: Shmikes
Quoted: 10171 Post(s)
Liked 5,864 Times
Likes For MoAlpha:
#3167
Silver Comet Fred
Bikes: 1
Quoted: 8835 Post(s)
Liked 2,986 Times
Took the day off and rode. 72 F but 16 mph winds. Now it's nap time.
#3168
Liked 9,456 Times
Not that I'm aware of.
Choke does the job to get it started, but once it's started, partial choke will kill it.
Yes.
#3169
Administrator
Quoted: 11971 Post(s)
Liked 6,651 Times
That’s the spirit, don’t take no mess from no tools.
#3170
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12775 Post(s)
Liked 7,693 Times
#3171
Bikes: everywhere
Liked 7,693 Times
My mower's running pretty good. Doesn't start as easily as it does when it's really happy, so might need to clean the holes in that little doohickie in the float bowl.
#3172
Coffin Dodger
Quoted: 794 Post(s)
Liked 292 Times
If it starts and runs well for a minute or two, then dies, that is a fuel delivery issue, sticking float or needle. Also check the fuel line for restriction too.
#3173
Bikes: everywhere
Liked 7,693 Times
It runs OK once it starts, just doesn't fire right up like it used to. Have a feeling it's running lean the whole time, thus making starting difficult. Gonna put off work 'til xmas, though. New plug, clean air filter, etc.
#3174
smelling the roses
Liked 901 Times
And a near bonk 18 km in. It's getting to be a wintertime habit. Mild weather, low humidity, tooling along a leisurely pace, and my body becomes salt starved very quickly. I ate a banana as I walked out the door. It happened last Winter. I bought and ate a pack of cookies; then another, and was ready to make the call of shame. Bought a bag of chips and ate it, and rode home feeling good. Today I went for the chips first.
#3175
Bikes: everywhere
Liked 7,693 Times
Man, I wish I coulda made the drive up for some of the Big Boy's snow days...
Likes For LesterOfPuppets:
