Huge Discrepancy in Elevation Gain between Wahoo and Strava iOS Apps
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,474 Times
Does anyone know why there is such a huge discrepancy in elevation gain between the Yahoo and Strava iOS apps? (Please note I am just asking about these apps, not about an altitude difference between GPS and barometer.)
I use the Wahoo app to record my rides, then export the data to the Strava app afterwards. For my most recent ride, Wahoo shows an elevation gain of 2,555 ft. while Strava shows only 1,616 ft., but the two apps agree about the ride distance (to within 0.01 mile). Which elevation gain number is more accurate?
Quoted: 3957 Post(s)
Liked 7,310 Times
Did you finish the ride where you started? If so, did the Wahoo give you the same number for ascending as descending?
Liked 1,474 Times
Yes, on my driveway right outside my garage.
No. According to the Wahoo app I finished my last ride mid-air 82 ft. above where I started.
Quoted: 20810 Post(s)
Liked 9,456 Times
One of the apps is likely referencing their own elevation model. Strava certainly has this option available, as evidenced by their elevation 'correction' option on the desktop site.
Likes For WhyFi:
Expired Member
Quoted: 3677 Post(s)
Liked 5,441 Times
I let Strava "correct" the elevation. It's always a couple of hundred feet more than Wahoo.
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Buddy of mine has an Wahoo computer (not sure which) and he almost always shows 10-20 feet of elevation gain, even in courses with 5000. Not sure what the cause is.
Quoted: 6198 Post(s)
Liked 4,814 Times
Because they don't figure up the data the same way. And they might not use the same data sources.
Remember that thing about a man with two watches?
Liked 1,474 Times
Liked 4,814 Times
Just pick a site and use the data you think is more accurate. Over the course of many rides, it might average out to being close with either site. To take one ride and compare it on multiple sites is just as crazy to me as assuming your device is even correct about the elevation gain and loss you had.
Accuracy really isn't as important as just knowing one route is more climbing than another. And you can figure out that by adding and averaging out the rides of the same route. Throw away what looks like outlier data for any one ride.
Likes For Iride01:
Bikes: yes, i have one
Quoted: 1139 Post(s)
Liked 1,182 Times
the data source *is* the same. the difference is that Strava post processes it and might make corrections. GPS elevation data is not as good as barometric elevation data. Strava knows the difference and adds correction as needed.
Likes For spelger:
Quoted: 18883 Post(s)
Liked 10,646 Times
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
I don't use any of the recording devices nor software mentioned to workup my ride-routes/tracks, however I have stayed at Holiday Inn Express & did a fair amount of mapping and map-data manipulation in a former life. When you talk about "ride data" and recording ride data and having various sources workup that ride data you need to really understand what all that means. It may well be that the ride data, in terms of the track that was followed, is simply the gps track itself. "Tracks" and "Routes" are nothing more than a large collection of latitude/longitude pairs. Even if you're transferring ride data that contains elevation, or other associated data, the destination software may only use the lat-lon data(plus time meta data) and then use their own data(sources) to work up other metrics as needed. While the lat/lon points(+time) are unique and transferrable, the remaining output can & will vary depending on data sources, assumptions made, and software(algorithm) processing. Mapping data sources are somewhat a commodity and they do vary.
As mentioned above.."The man with two watches doesn't know what time it is".
Likes For fishboat:
Liked 10,646 Times
A man with two watches needs to know how to spell.
Maybe somebody at Wahoo or Garmin missed that left turn in ABQ?
Liked 1,474 Times
The man with two watches knows it is time to shop for a third watch.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
"Always choose the device that indicates the greatest elevation gain."
need to add that to The Rules.
https://www.velominati.com/comment-page-8/
Likes For tyrion:
Quoted: 759 Post(s)
Liked 810 Times
Liked 1,474 Times
Liked 1,474 Times
A single watch is for telling time.
A second watch may give you a better estimate of time to the extent it is more accurate than the first and you have both watches side-by-side.
A third watch, even if it provides an extra data point, does not instantaneously -- and this is the crux -- give you a better estimate of time, because it takes longer to average three data points than two.
Thus, the third and any additional watches are not for improving one's estimate of time, but to collect for admiration, decoration, projecting wealth, signaling taste and/or restraint, and god forbid (for us cyclists), fall detection (Apple Watch).
It is largely analogous to the N+1 rule I often hear about on BF.
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
I thought Strava elevation correction was based on the map datum and threw out the altimeter readings, which are always crap.
Likes For MoAlpha:
Liked 9,456 Times
With a dedicated bike computer, Strava will take whatever elevation data it is given. It will only correct with their own data if you select that option for a given ride. I don't know how it works for the phone app.
Bikes: Shmikes
Liked 5,873 Times
Liked 10,646 Times
Likes For Seattle Forrest:
Liked 1,474 Times
Liked 10,646 Times
Liked 1,474 Times
Thanks, I now realize that. There is a new route I want to explore which starts with a long climb (partly on a major road) so a more accurate estimate of my elevation gain would be helpful.
