Handle bar and brake options
Quoted: 7 Post(s)
Right this is probably a post that's been done before but maybe not so I'll try anyway...
I have a canondale badboy which I love but I want to have at least one more hand position, only thing is I am not a fan of bar ends because my hands are too far from the brakes so I am wondering if there is any sort of setup that will allow me to have brakes only handlebars and on the bar ends (or similar, like a cyclo-cross handlebar set up with 2 sets of levers) without 1. Costing a bomb and being a waste of time and 2. Being impractical.
I know a drop bar Conversion is both of those things so any options other than buying a cyclo-cross bike would be appreciated.
Thank you in advance for any advice
Regards
Woody
Regards
Woody
Quoted: 4239 Post(s)
Liked 3,976 Times
There are bar ends which are shaped in the form of a drop bar's outer section.
Also brake cables can be run through a lever and continue to another lever, much like top mount levers are done. Andy
the tube standard in drop (other than center bulge) Straight /MTB 7/8" , road 15/16"..
so the levers off straight bars don't transfer.. you have to replace everything.. to put drop Bars On
I have adopted Figure 8 bend trekking bars, more hand positions, still keep the MTB type brake levers..
An Example: off the web..
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
Reverse levers on a bullhorn bar with interrupter levers on the flats, maybe? It would be pretty similar to running bar ends with levers both at the end and the flats.
If your existing shifters aren't integrated with brake levers, you'd be able to keep using them. You'd just need to buy the handlebar and brake levers (total around $70) plus consumables like bar tape and brake cables. When shopping, pay attention to bar and stem/shifter/lever clamp diameters to make sure your stuff matches.
Bikes: '74 Raleigh International utility; '98 Moser Forma road; '92 Viner Pro CX upright
Quoted: 939 Post(s)
Liked 5 Times
Reverse levers look cool, but I think they're begging to hook something.
Quoted: 239 Post(s)
Liked 7 Times
OP's text was hard to follow
But I think he is asking, how to have brakes on both the handlebar flats, as well as on the bar ends.
something like this?
https://www.flickr.com/photos/xenologer/3754510464/
Ignore the fact that it's a trekking bar, look at the levers, same positions as flatbar with bar ends
Quoted: 7 Post(s)
Yeah that's the sort of thing I'm looking for, what are these magical contraptions called? 😉
Quoted: 634 Post(s)
Liked 13 Times
Dia Compe Guidonnet Brake Levers
Quoted: 239 Post(s)
Liked 7 Times
no one makes them anymore, but ebay probably has some left over
various brands
(checking)
aside from the 100$+ Paul ChimChims extenders
this thing showed up in the results: MTB,FIXIE BRAKE LEVER W/BAR END EXTENSION GREAT INVENTION FOR ANY BIKE WITH BAR | eBay
But thats for Canti brakes, and your disk brakes are probably Linear Pull, so not compatible
and stay off the 'guidonnet' brake levers
those are for retro french city bikes and whatnot, you know, like on grandma's 3 speed
(also, likely not compatible with your disks)
Quoted: 239 Post(s)
Liked 7 Times
various brands
(checking ebay):
But that's for Canti brakes, and your disk brakes are probably Linear Pull, so not compatible
(also, not compatible with your disks)
Best,
Chuta
Liked 3,976 Times
https://jtekengineering.com/wp-conten...5/06/36472.jpg
Not exactly the same but close. Adding common bar ends that point forward will get much the same. Andy (taking a couple of minutes of image searching)
