How do you position your bar ends?
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
I've seen a couple of the bus-n-bikers have their bar ends straight up. Saw another guy at school that mounted his pointed straight back (towards the saddle). I've got mine pointed out and angled back just a little (basically trying to mimic the hoods on a drop bar).
Just curious.
Just curious.
Community guidelines
ride for a change
Bikes: Surly Cross-check & Moonlander, Pivot Mach 429, Ted Wojcik Sof-Trac, Ridley Orion. Santa Cruz Stigmata
The abuse of bar ends seems to be one of cycling's great plagues. What was invented to aid and make up for the limitations of flat bars for mountain biking about 20 years ago now seems to be mainly used by heel pedalers to make up for criminally poor bike fit. It's sad really.
it's easy if you let it.
^ What he said. I know a girl who seems to ride by holding on to the tips of the bar ends, which are pointed up. Makes no sense to me, but I feel the same way about bar ends in general. Flats, horns, or drops--pick one.
Location: Central Coast NSW Australia 33°26'16.05"S 151°20'39.43"E ish
I think you've got it right. Aren't they designed to help in hill climbing, you get a better grip without putting stress on your wrists on the flat bar. Anyway, mine are set at about 30 degrees.
Gutter Bunny
Quoted: 16 Post(s)
ARRRRGHH!!!! This winds me up so much I actually go up and tell people to lower their bar ends if I see them up.
The only function for having them straight up is to cut the blood supply to the hands, prevent you operating the brakes and increase the likelihood of impaling yourself if you go over the handle bars. if I go over the bars I don't want to catch the bars with my stomach and take the bike with me too. I want a clean exit!
I've used bar ends on mountain bikes for years, if set right, (low so you can hit the brake and shifters with the top finger), they make a a really comfortable cruising riding position and obviously give another 2 hand positions that helps with the limitations of a flat or riser bar. I also can't stand MB snobs who don't think they have a place on MB bars.
They help with climbing too obviously.
Bikes: Schwinn Ranger
I've seen people position their bar ends in the craziest ways and I just don't understand it. Well... scratch that, I understand that they're probably using the bar ends to help compensate for a bike that they haven't been properly fitted to and might otherwise find uncomfortable. Whatever the case is, it makes me a little sad every time I see it.
I have my bar ends almost horizontal at maybe 20 degrees.
Bikes: 2008 Surly LHT, 2008 Trek 7.2fx
Well, I was going to reply I just leave them where they were when I dismounted the bike and asked why it mattered, but then I realized you weren't talking about shifters.
Quoted: 239 Post(s)
Liked 7 Times
Reversed left/right and facing backwards, angled upwards to near vertical. With bar tape on them.
The ends curve sligtly inwards, so it's a comfy near vertical hand position. Kinda like holding drop bars, but with a raise instead of a drop.
I use them for cruising on long flat areas where it's nice to have the more upright position(and I'm not braking much anyway). For speed or rough places I default back to the lower MTB flat bar.
On my new under-construction bike, I'm putting the bar ends about 2/3 of the way inwards on the flat bars, angled upwards for a vertical hand position. With the brake levers attached to them also vertically.
Kinda like those aero brake levers/grips, but made of MTB parts and raised instead of lowered.
Rabbit Habbit!
Bikes: Specialized Sirrus 08
Damn, I thought the roadies were the only "bike police"!
I have them anyhow I feel like it!
Jerry
Jerry
Didn't make it
Bar ends helped on my mtb as I bashed trees and such. I replaced the stock bar ends on my
commuter as an idea to place my mirrors. I raised them higher than I care to, for the mirrors
to work. I figure the shape could help protect my fingers after I got doored last spring.
Bikes: '86 Koga Miyata Randonneur
-Jon
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I put mine in a box as soon as I got my bike home the first day, that seemed to be the best position for them.
Work: the 8 hours that separates bike rides.
Bikes: Fuji Absolute 3.0
I have a hybrid, and got these fantastic grips -- the Ergon grips with built in bar-ends; they aren't too long like MTB bar ends and are relatively ergonomic. I set them about 45 degrees, and I love them because they do give me several different hand positions to help prevent numbness. For some reason, I have tried everything and I still get numbness in just my right hand (got great Izumi gloves, keep adjusting handlebar height and grip angle...).
That said, I totally agree that bar ends are overused, and seem to be part of the overall issue of too many people buying MTB's that really don't need them, since they're just riding roads and paths.
Gutter Bunny
Quoted: 16 Post(s)
People buy MTBs as they are still the most popular type of bike and the first thing most people see when going in a bike shop. They have advantages to road bikes as they sit you upright. The handle bars feel easier to use on MTBs, as it has been said here before you tend to steer more with the bars on a MTB compared to using body weight to lean into a corner like you do with roadbikes. Wheels are smaller and again feel safer, not as high up.
If I'm going out in mega high winds, up to and sometimes in galeforce, for my commute I'll leave my crossbike at home and take one of my mountain bikes. It feels more secure.
Didn't make it
I don't remember seeing drop bar ends..mebbe you can post a picture?
I don't grip my bar ends as much as I lay my hand flat along the rise of the bar.
born again cyclist
i've got some ergon GC3's on my hybrid, and i have bar ends pretty close to flat, maybe a 3 degree rise or so.
i've got hydraulic disc brakes on my hybrid, and it can only have flat bars beause no one make hydraulic levers that will fit drop bar diameter. but the one hand position of the flat bar is not enough for me, so using bar ends to get more hand positions is a no-brainer for the solution.
EDIT: just realized that i'm responding to a post made over 3 years ago............. oops.
born again cyclist
^ don't fret, that pic is from the summer when the bike was brand new. after 5 months of commuting, it's much, MUCH dirtier now.
You gonna eat that?
I'm with Dan, Ergon GC 3,
but they're on my Brompton, to fold the bike and have the riser, snap in the catch,
I loosen the clamp bolt. it misses by just an inch, If I don't..
shorter Bar end, and that is unnecessary..
Still spinnin'.....
Bikes: Fisher Opie freeride/urban assault MTB, Redline Monocog 29er MTB, Serrota T-Max Commuter, Klein Rascal SS, Salsa Campion Road bike, Pake Rum Runner FG/SS Road bike, Cannondale Synapse Road bike, Santana Arriva Road Tandem, and others....
Each of my mountain bikes that get a lot of road use have barends, including my commuter and urban assault bikes (both of which often see 40-60 mile days). My 29er SS however seldom gets many road miles and is often used in tight wooded sections, and it has no barends. If I still rode CA fireroads and arroyo single tracks it would get barends too.
As for the average neighborhood cruisers having their barend pointed straight up or even backwards, think about how many "road bikes" you see with their drop bar upside down. It looks stupid as hell to you and I, but its their bike and they want a more upright seating position and barends are the simplest and cheapest way to achieve that. Whatever floats their boat.....
Old, but not really wise
Bikes: 2010 Kona Dew Drop (the daily driver),'07 Specialized Roubaix (the sports car), '99 ish Kona NuNu MTB (the SUV), Schwinn High Plains (circa 1992?) (the beater)
Re: Drop bar ends.
I had these on my prior, flat bar, steed. Simulated drops, but no real 'hood' position. I liked the options they gave me for commuting.
Registered User
Bikes: 5 Colnago, 2 Olmo, Bianchi, 4 Austro-Daimler, Merlin, Fisher Tandem, John Waite track tandem, Schwinns, Steyrs, Bill Holland Ti path racer, Chinese prototype FS
Around these parts the only people who have MTB bar extensions pointing backward or straight up are Freds and bums weaving unsteadily down the road or sidewalk on under inflated knobby tires and saddles too low with knees hitting chins, often salmoning upstream where they will spawn and hopefully die.
