Disc brake pad replacement. Metal/Resin?
I have a Giant Defy Advanced 0 with Shimano hydraulic RS785 brakes. This is my first disc bike. I have put in a ton of miles in the past few months so I decided the to replace the pads. I bought what I thought was the correct pads, see photo. They are "metal" Shimano JO4C. Well, when I took out the old pads they are marked JO2a Resin. The rotors are not marked "resin only". The rotors have no markings except size, 140mm. So, should I replace with resin only pads? Or can some rotors take either metal or resin? I would imagine you don't want to put metal pads on a "resin only" rotor, but since there is no marking on the rotor, is it possible to put metal pads these rotors. Please advise.
Quoted: 184 Post(s)
Liked 67 Times
If the rotor doesn't have 'resin pads only' stamped on it, the rotor can use either pad type.
The 'resin pads only' rotors will wear much quicker with metal pads.
I used Resin/organic pads from Kool Stop in my BB7, better than stock ..
use: transportation, all weather, modest speed ..
Quoted: 2026 Post(s)
Liked 1,096 Times
As a general rule, metallic pads last longer but tend to be noisy. Resin pads wear out faster but are quieter.
Regardless of if the rotor is rated for metal or not, you still move some of the wear from the pads to the rotor.
Use resin pads and replace those more often, or use metal pads and replace those less often, but replace the rotor more often.
Edit: what really would help install larger rotors. 140 mm is very small. Minimum 160 mm or even 180 mm. Better cooling (temperature fatigues everything, more dangerous than friction itself) and more braking power. At least on the front you should consider that.
Since you have shimano brakes, use the rotor in that groupset. Can't go wrong with that. You may need an adapter from your fork holes to use the larger rotor (I'm not 100% sure on that, though.... but often going larger requires that... someone smarter than me can advise on that)
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
RS785 calipers will accept the following pads:
G02A - resin, without fins
G03S - metal, without fins
J04A - resin, with fins
J02C - metal, with fins
The front adapter for 160 mm rotors is SM-MA-F160P/D. The rear adapter for 160 mm rotors is SM-MA-R160P/D.
Reference https://si.shimano.com/pdfs/ev/EV-BR-RS785-3743D.pdf. This document has all the part numbers.
Shimano Ice Tech are great rotors, especially if your hubs accept centerlock rotors.
-Tim-
-Tim-
Go to 160mm rotors for sure, especially if you are 200lbs.
For pads I prefer semi metallic because they last much longer in my opinion. Resin pads are a little quieter and have slightly better feel at the lever to me but wear faster. Also, riding resin pads in wet, dirty conditions will wear them out REALLY fast.
Quoted: 19 Post(s)
I have Hydraulic Shimano Disc brakes on my Cannondale Synapse
I run the metal pads on the rear ( stock ones so far) and I replaced the front pads with
Swiss Stop Organic pads...the stock ones were makeing some noise. I like the organic pads....a lot quieter and on the front I think I will get some good wear out of them them.
