Fitting a 23mm tire on rims that came with 28mm tires**********
Hi, My road bike came with 700c 28mm and there not slicks. Do you think I can fit 25mm or better yet 23mm tires on rims that originally came with 28mm tires?
I hope I dont have to buy new rims........
Thanks
Thanks
Do your rims say their size. For example my cross bike came with 700x33 tires but the rim size was 622x17. If you know the rim size there are charts that tell you what size tires it can handle. Sheldon Browns site has a chart like the one I mentioned.
Hey, but my rims dont have a size written on it. The only thing I know is that they are 700c with 28mm tires on.....
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
Got pics. 28mm to 23mm ain't much of a change, so will probably work. I'd just roll 25s or 26s personally.
I know its not a huge difference going down to 23mm, but Im hoping that thinner tires and a higher psi, like maybe 100-120 psi instead 80 currently, and slicks instead of sort of hybrid will roll much better? what do you think?
Any chance that you can find out by looking up your bicycles specifications online. Like through the brands website? Or at the very least you could go to the lbs and have them tell you what size rim you have and also what sizes of tires it will work with.
Bikes: everywhere
Liked 7,695 Times
Pic of rim, instead of tire, would be better, like if you laid down on the floor and aimed camera up at brake caliper.
Do the rims have stickers indicating make and model on 'em?
I took one, let me know if you need a better one.....The bike is not that great, its a ccm presto so the rim basically just has a sticker saying ccm..
I asked a local bike shop and they said 25mm would fit but 23mm there not sure, they would have to try it. However, I wanted to buy tires online instead, so im not sure.
Just a heads up, since you live in the states. Im pretty sure the specifications of this bike are exactly the same as the GMC Denali....
This is for the Denali
The model is a 'ccm presto' and the year of make ill have to get back to you when I find it.
- Rims: Vitesse Alloy black 700CX14GX36H
- Tires: Kenda Black With Grey Band 700X28C
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
What you need to know is the width of the rims.
There is a very strong possibility that a 23c will be fine. To spec a rim on a bike with those caliper that wouldn't accept a 23c tires means it would accept a 38c tire which wouldn't fit under the calipers. That would be incredibly stoopid.
Have another look at the rim and see if you can't find some tiny numbers etched in that stat 622 x ??. It's the second set of numbers that will matter to you.
Bikes: Moots Vamoots, Colnago C60, Santa Cruz Stigmata CC, and too many other bikes I don't ride
Quoted: 152 Post(s)
Liked 7 Times
Just get some 28 slicks and cal, it a day. It will ride better than 23 anyways.
yea i could do that, I may be leaning towards 25mm instead to save me the trouble or new rims or whatever. But why you say 28mm will ride better? wouldnt 25mm or 23mm slicks with a higher psi ride better for speed and performance?
Mostly harmless
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Measure the rim diameter. Inner size wall to wall.
Then take a look:
European Tire and Rim Technical Organization Standards Manual - 2007 [TABLE="width: 500"]
[TR="bgcolor: #CCCCCC"]
[TD="width: 113"]
[/TD]
[TD="colspan: 16"]
[/TR]
[TD="align: center"]Rim width
(mm)[/TD]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[/TR]
[TD]
[TD="bgcolor: #FFFFFF"]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD="bgcolor: #CCCCCC"]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[/TABLE]
Then take a look:
[TD="width: 113"]
[/TD]
[TD="colspan: 16"]
Tire section width
[/TD][/TR]
(mm)[/TD]
[TD="width: 34"]
18
[/TD][TD="width: 34"]
20
23
25
28
32
35
37
40
44
47
50
54
57
60
62
[/TD][/TR]
[TD]
13c
[/TD][TD="bgcolor: #FFFFFF"]
x
x
x
x
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
15c
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
17c
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
19c
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
21c
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
23c
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
25c
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
27c
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
29c
[/TD][TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[/TABLE]
Then take a look:
[TD="width: 113"][/TD]
[TD="colspan: 16"]
[/TR]
(mm)[/TD]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[/TR]
[TD]
[TD="bgcolor: #FFFFFF"][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[/TABLE]
Then take a look:
[TD="colspan: 16"]
Tire section width
[/TD][/TR]
(mm)[/TD]
[TD="width: 34"]
18
20
23
25
28
32
35
37
40
44
47
50
54
57
60
62
[/TD][/TR]
[TD]
13c
x
x
x
x
[/TD][TD="bgcolor: #FFFFFF"][/TD]
[/TR]
[TR]
15c
[/TD][TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
17c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
19c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
21c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
23c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
25c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
27c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
29c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[/TABLE]
Two-Wheeled Aficionado
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
Liked 5 Times
Then take a look:
[TD="colspan: 16"]
[/TR]
(mm)[/TD]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[TD="width: 34"]
[/TR]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
[TD]
[TD]
[TD]
[/TR]
[/TABLE]
Then take a look:
[TD="colspan: 16"]
Tire section width
[/TD][/TR]
(mm)[/TD]
[TD="width: 34"]
18
20
23
25
28
32
35
37
40
44
47
50
54
57
60
62
[/TD][/TR]
[TD]
13c
x
x
x
x
[/TR]
[TR]
15c
[/TD][TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
17c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
19c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
21c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
23c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
25c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
27c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[TR]
29c
[/TD][TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][TD]
x
[/TD][/TR]
[/TABLE]
im not even sure if ill notice a difference with my current 28's that are not slicks vs 25's slicks?
Mostly harmless
Liked 216 Times
Have you got any more up-to-date link? Or are those some exotic rims while the table still being "the rule of thumb"?
If you ride on paved roads, slick tyres will give better traction and less rolling resistance than the same thickness tyres with thread.
23 are more sensitive to bad pavement, potholes etc than 25. 28 are even more durable. With 23s you will have to be careful not to damage rims on potholes.
I ride 37 mm tyres on commuter bicycle and 23 mm tyres on road bike. On 37 mm tyres, I have more problems accelerating, it is harder, but I don't even blink if I hit a big pothole in the dark on the way home.
P.S. You CAN drink and drive with fat tyres!
Thanks for correction. Didn't know that.
Rolling? Fatter tyres will bump on bad pavement less and perhaps even roll better. Thinner tyres hold higher pressure (so might provide less rolling resistance) and will definitely provide less air drag. But nothing revolutionary. What you WILL notice is less weight (and thus less inertia), so you will get up to speed more easily, bike might feel a bit lighter, nippier.
Hey thanks a lot for the detailed response. Basically what I was looking for.
Maybe ill just stick with my current tires for now. one last thing, is there any danger in pumping the max air pressure on a tire. Mine says 85 psi, can I put it to 85? and if I could put it to 85 can you also pump a little more than 85 psi? Are there any risk involved in doing that?
