I suck at wrapping handlebars.
#76
Quoted: 4560 Post(s)
Liked 2,802 Times
Excellent wraps, @SurferRosa. Is that colored electrical tape or something else?
Reminds me, don't cheap out on electrical tape. There's a huge difference between the dollar store stuff and 3M. I finally ponied up for the good stuff this year. Much nicer.
Also, another plug for Arundel Synth Gecko, at least for practice wraps or folks with joint pain. It's pricey but good stuff and easily reusable.
I'm redoing my '93 Trek 5900, from 140mm titanium stem and conventional crit style drops to 90mm aluminum FSA stem and compact FSA Omega drops. Just waiting for delivery of the shim I need for the 1" head tube to fit the 1-1/8" stem. My neck will thank me.
And I can reuse the same Arundel Synth Gecko wrap again. That'll be the fourth time since April I've reused the same Arundel wrap, since I keep experimenting with handlebars. So it's turned out to be more cost effective than four packs of $10 bar wrap.
#77
Liked 2,802 Times
There were two correct ways to wrap bars when cotton was king, depending on whether or not the bike had brake hoods. Later on, there was a third correct way to wrap that we learned for Bike Ribbon - bottom up. Normally I'm all for doing things correctly, but in this case what is correct is dependent on period, location, material and context. That said, I'm curious as to what @hobbs1951 considers to be the correct method.
At any rate I've given up on the modern correct way of wrapping, and have gone back to wrapping top down -- like in the old days. Works better for me, and doesn't require some ugly tape at the top, or twee twine that comes undone.
If I used a single wrap of cloth or cello tape it'd be easier to hide. I did that back in the 1970s, but I didn't have a bum neck and shoulder to deal with back then. It was easy to hide the tape edge and stuff it into the bar ends with plugs.
#78
Quoted: 1609 Post(s)
Liked 2,590 Times
Just in case you couldn't decide which way to go...
#79
How do you handle the raw tape edge at the bar ends with top-down wraps? I've done it a few times to quickly rewrap over cheap foam tape, using Arundel Synth Gecko silicone rubber wrap. But there's always that raw edge. Only drawback to fat cushy wrap.
With Fizik tape and the old Bike Ribbon, I wrap just past the end of the bar, then cut off the excess tape with scissors about 1/4" to 3/8" past the end, parallel to the bar end. Tuck this in just like cotton or plastic tape. It's a little fiddly, but not too bad. I haven't tried silicone tape, but I'd imagine the same technique will work fine.
Fat cushy wrap is going to be unfriendly to this method. I don't use cork tape myself, don't like the edges, but I have wrapped top down once or twice with it. Giant PITA. I'd definitely recommend the now standard wrap bottom up method. It's just too thick to tuck in. Might work with those old school chromed spring steel bar end plugs, but no one sells those anymore.
#80
Indeed. Nice job on those.
I always needed to use glue or shellac to keep twined termination from loosening up over time.
Partly I like 70s top down style because I prefer the look of no termination at the top. Also it holds up slightly better for me. I think I tend to pull back on the bars slightly when climbing, so the whole shingle analogy is bassackwards.
Figures. At any rate if you look at old race pictures, say from the 70s, you'll see that most bikes are cotton tape, wrapped top down. A few, notably Eddy Merckx, were wrapped bottom up. It could be argued that there was never a right way, but IMO it would be more accurate to say that Eddy wrapped his the wrong way, because he preferred it. Eventually that became the 'correct' way.
a similar comment was made in this thread https://www.bikeforums.net/classic-v...nish-tape.html
but many requests were made then of the holy grail method, but all were ignored.
#81
Liked 2,802 Times
Yeah, Eddy Merckx was more influential than most cyclists. He was fastidious about how his bikes were set up, even supervising his mechanics in saddle adjustments. There's a scene in one documentary where he uses a level to check a saddle just set up by a team mechanic. And there are scenes showing Merckx and Hinault doing some of their own bike assembly and maintenance.
And, arguably, Merckx revolutionized the team approach to races, with a more organized and demanding training schedule than most GC contenders had done before.
So it wouldn't surprise me if some of our persistent notions about how bikes *should* be set up can be traced back to Merckx. If for no better reason than because his career was so thoroughly documented and filmed.
#82
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
The red one is. I have used blue, yellow, and white before. I normally just use black. For me, it has to be 9-10mm wide to look perfect. A couple of those above use embroidery thread.
Thanks. I'm done with twine. (Went through that phase.) But on the rare occasion I still use embroidery thread, I will keep it in place with clear nail polish.
#83
Quoted: 195 Post(s)
Liked 207 Times
Anyone remember the loop around the brake lever method that used to be used when many levers did not come with hoods? It was sort of a variation of the figure 8 method, and it also worked well with mafac half hoods. It's been so long I've forgotten how to do it. I remember some people hilariously still trying to wrap bars that way when thicker tape came out.
These days I always use cut strips for the gap, and don't bother with a figure 8. It's not needed if you're careful. Besides, there isn't enough tape on a velox roll to do a Cinelli #66 bar if you do that extra loop.
BTW, yeah it's true. In vintage days many bikes were sold brand new with no brake hoods at all.
#85
No one cares
wrapping bars is a lot like wrapping other things.
Just roll it on and get to pumping until you get to the end of the bar. Then shellac everything. Twine is optional.
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
#86
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
I used it on my Univega. For being a relatively soft rubber tape, it's not stretchy at all...it was hard to get a really tight wrap. Hard, but possible. It took a lot of work, but the end result was good.
#88
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 984 Post(s)
Liked 634 Times
Anyway, I just finished wrapping bars, eh, five minutes ago. I had run into a problem that I never had with Tressostar years ago, that had edge-to-edge adhesive on the back. With modern squishy tape and no adhesive (I just used Cinelli but another brand I just removed), when wrapping top-down, the exposed edge at the overlaps faces up; specifically at the first curve in the bars out from the center (where I ride a lot), I was getting roll-back and separation between the wraps. Did I used to much or too little stretch? I don't think so). So, I just did bottom up and used the supplied "finishing tape" at the top despite the aesthetic compromise.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
#89
A couple of days later, haven't even ridden the bike yet, and the black short adhesive strips that came with the Cinelli tape would not hold; started unraveling. So, I broke out electrical tape (3M's #700 Commercial Grade), used that, I have hopes that it will hold.
#90
Liked 2,802 Times
One trick I learned from watching YouTube tutorials by pros, including mechanics for pros, is to avoid stretching the electrical tape too much, and to avoid stretching it at all on the final wrap. It's less likely to pull away.
So when I wrapped my bars a few months ago I stretched the first two wraps just a little, and the third and final wrap without stretching. It held perfectly. When I had to remove the wrap from one bar the other day the Scotch 33+ was clinging so tenaciously it pulled the cork/foam bar wrap apart, yet the Scotch tape itself didn't tear, didn't leave any residue, and could actually be reused. So I reused it to hold the cables to the bar under the fresh wrap. A little more economical.
#91
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
Small bit of progress today. Managed to wrap the bars on my Frejus. I fudged a bit in a couple ways. One, I reused the blue tape which came on the bike. I liked the color and am a bit of a CSOB. I'd long ago washed it, then wrapped it today to expose the previously covered part. Two, I didn't see any way to get the Cinelli end caps over the tape, so I used some blue electrical tape an declared victory. Finally, since the old tape (must be 30 years old) had no adhesive left, I sprayed the bar tops and ramps with Scotch 77 adhesive. I've yet to find any suitable hoods (@iab gave me a lone reproduction Vittoria hood - anyone got its mate?)
I still haven't tried the Griffon's bar again. I'm still weighing my bar options. I might switch to a Giro d'Italia.
#92
Liked 2,590 Times
#93
Quoted: 984 Post(s)
Liked 634 Times
Thanks. So far, what I did w/3M tape is holding.
#94
Bikes: many
Liked 1,392 Times
When all else fails, blame the bars. I replaced the Campione del Mondo bars with Nitto Grand Bois Maes Parallel bars (25.4 ø). Et voila...
Regulatori
Singlespeed & Fixed Gear
9
10-10-15 12:43 PM
RoadTire
Bicycle Mechanics
2
08-27-13 03:13 AM
