What chainring do I need????
I'm trying to change my front chainring. It's a Shimano and says 50-F on it. I can find a 50-T on Amazon. Will this do? The gears are Shimano Sora 9 speed.
Cheers.
Cheers.
You need to know what the BCD (bolt circle diameter) is of the Shimano Sora crankset (assuming that is what you have). A quick look on Google suggests the BCD is 110 mm. So, many chainrings should be available to fit this crank.
Quoted: 702 Post(s)
Liked 672 Times
is this your crank?...
SPECIFICATIONS
- Pedal Spindle: 9/16"
- BB Included: No
- Chainring BCD: 74 Shimano Asymmetric , 110 Shimano Asymmetric
- Color: Gray
- Defined Color: Gray
- Crank Intended Use: Road
- Number of Chainrings: Triple
- Crank Length (mm): 170 mm
- Rings: 50/39/30
- Drivetrain Speeds: 9
- Spindle Interface Type: Shimano Hollowtech II
- Chainline/Hub Compatibility: 130 Hubs , 135/142 Road Disc Hubs > 415 mm Chainstay
Nice one, thanks. The BCD is indeed 110mm so I've ordered it. Thanks for your help.
Quoted: 1438 Post(s)
Liked 1,092 Times
I see absolutely no point in these asymmetrical bolt patterns except to restrict choice of chainrings. Stupid and unnecessary.
Quoted: 702 Post(s)
Liked 672 Times
I guess we'll never know if the crank I posted is the one in question or not.
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
Hopefully OP will let us know if what he ordered turns out to be correct. Plenty of ways to go wrong, even if it's Shimano. Fingers crossed
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
But this brings up another point for the OP to consider. Besides bold-circle diameter (BCD), mounting bolts must also match what the crank arm will accept.
Liked 1,092 Times
For indexed shifting systems, they force you to install the rings in the proper orientation for the ramps and pins to be effective in facilitating shifts.
Quoted: 350 Post(s)
Liked 122 Times
I thought the newer 4 bolt asymmetric chainrings have a little curved tab on one of the flanges to force you into one position only so that it's not possible to install it 180 degrees rotated.
