how do you use this valve?
https://www.bytrade.com/factory-1/sup...tire-valve.htm
Like the description says, I have 20 x 1.5 tubes for my trailer and it came with this type of valve, someone newb me please.
Bikes: 1992 Trek 800 Antelope, 1971 Triumph
That's a Dunlop valve. What do you mean by use? How do you pump it up? Attach it to a wheel? Expand on "use" please...
Josh
Josh
They are also 3000$ a set... if you didn't already know that. What are you using it for?
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,538 Times
It is the standard valve found on bicycles sold in Germany, The Netherlands and perhaps other countries. A pump that works on presta valve will work. Screw on adapters are available will fit standard automobile pumps.
Quoted: 239 Post(s)
Liked 7 Times
The usual way I use them is,
unscrew the plastic cap, then the large nut just below it(holds the valve core in place). this lets all the air out.
next unscrew any nut at the base of the valve; so you can push it out of the rim.
dismount tire, pull the inner tube out.
toss it in the trash.
reinstall and reinflate tire with a shraeder valve tube.
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
(please note!)
- Wil
Quoted: 70 Post(s)
Liked 15 Times
You're missing out a step! In order to fit a Schrader valve you will need to drill the rim hole wider to accommodate the thicker valve stem. Isn't it curious, I do the exact opposite of you, and fit a sleeve or rubber grommet to accommodate the thinner stem of the Presta valve! it is generally recognized that Presta valves are far superior to Schrader valves!
(please note!)
- Wil
(please note!)
- Wil
Aaron
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,538 Times
A 50¢ adapter can be screwed on (and left on) that allows any Dunlop valve to be filled with an auto/bike pump that is fitted for an automobile/schrader valve.
Last edited by I-Like-To-Bike; 03-10-13 at 11:42 AM. Reason: Add pictures of adapter
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,538 Times
Or fancy pants roadies who buy into all the Kool Aid Brand "Truths" spouted out by the "experts."
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,538 Times
commu*ist spy
those things exist? I thought they were an urban legend. And who in the hell would by 5000 of them? nobody uses this thing!
Quoted: 70 Post(s)
Liked 15 Times
Three of those bikes came from either Germany or Denmark. The other is a vintage Raleigh roadster.
Aaron
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
You are quite a bit behind the times on pumps too. Every pump I have bought in the last 25 years has had the ability to pump up either presta or schrader by simply reversing the grommet in the pump head. You'd have to go out of your way to find a pump without that feature. I'm sure having the ability to do either presta or schrader adds significantly to the cost of the pump...like 15 cents or so. Oh, the humanity.
Stuart Black
Stuart Black
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,538 Times
Urban legend if your only exposure to European bicycling is the TDF.
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,538 Times
Sure, just let me walk the 15 miles to the gas station and use a compressor that is meant to pump up a 30 psi car tire. That'll be useful.
Not everybody buys their bicycle pumps or bike accessories at an LBS. The big box stores, the stores that sell the majority of bikes in the U.S., have lots of pumps on for sale that do NOT have any way to pump up a Presta valved tube.
Quoted: 70 Post(s)
Liked 15 Times
Aaron
If it 'twere me, I'd simply replace the tubes to match the valves on my bikes. That way, no fiddling with adapters.
commu*ist spy
Duh what's the sense in investing in a market that doesn't even really exist? Who would use a valve that provides no special advantage to the other two, but requires a special adapter? But I guess I'm not familiar with what bikers in Europe use, so to each his own...
Been Around Awhile
Quoted: 12 Post(s)
Liked 1,538 Times
I believe bikes in India also use Dunlop valves, but I am not sure of that. Anyone know what kind of tube valves are found on bikes sold in India or China?
Bikes: 2012 Specialized Sirrus
Quoted: 8 Post(s)
When I rode bikes in India, I wasn't aware that there were different types of valves at all Never owned a pump in India - just went to the neighborhood repair shop. Remembering over the years, I think there were 6 bike repair shops in a 1 km radius around my house - and this was true pretty much anywhere I rode. Tried to find the info off a local manufacturer's website, but no luck.
