No more forks out there for me?
Old 09-17-13, 11:24 PM
ed
ed's Avatar
Bikes: Hecklah
I've noticed now that everyone has gone QR15 and Tapered...you just can't find a good deal on an OEM overstock or cheap used fork. I was entertaining the thought of finding a good suspension fork for the Komodo to bring it back up to spec' since I'm down to a rigid on it. Heck man...1-2yrs ago, you could find hordes of used reasonable forks between 140-160mm 1 1/8 straight steerer tube (at least 8" long) with a 20mm thru axle. Now it's all tapered and QR15. Most of the used ones have the steerer too short.
Heck man...I got my Sektor for $215 new. There were a ton of PIKE's out there for less than that lightly used. Domains were still available in the $200 and less range. I got my Domain 318 for $185 as well as my PIKE UT.
Sadness. I may either have to sell the frame and go tapered or bite the bullet and buy the more expensive Lyrik or even a Fox 36.
I'll have to see what Christmas brings in the way of fundage toward something.
ed is offline
Old 09-18-13, 05:40 AM
ColinL
Two-Wheeled Aficionado
ColinL's Avatar
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
Liked 5 Times in 5 Posts
I'd sell it. Have you been riding it much, since you have the Heckler?
ColinL is offline
Old 09-18-13, 06:06 AM
ed
ed's Avatar
Bikes: Hecklah
You can't sell a legend.
Yeah man, I ride it frequently. The geometry of the bike is perfect for a hardtail. Long spacious TT for my long arms, semi slack, beefy. Love it. It just needs to be raised back up to proper ride height via suspension fork. The new version has a tapered HT, but it also has a much shorter TT so I'd have to run a longer stem which I don't like much.
I'll find one. I'm only half serious right now because I don't have money to throw around, but when one pops up, I may have to bite the bullet and jump on it.
ed is offline
Old 09-18-13, 06:17 AM
Dannihilator
Still kicking.
Dannihilator's Avatar
Bikes: Bike Count: Rising.
Quoted: 159 Post(s)
Liked 46 Times in 32 Posts
https://www.jensonusa.com/Bicycle-Sus...TST2-Fork-2009
Appreciate the old bikes more than the new.
Dannihilator is offline
Old 09-18-13, 06:39 AM
unterhausen
Randomhead
Liked 3,699 Times in 2,519 Posts
I don't know how long 20mm forks will be available, but I think I would get one now rather than waiting. Pretty sure 1 1/8" will be available for some time
unterhausen is offline
Old 09-18-13, 07:08 AM
ed
ed's Avatar
Bikes: Hecklah
Oh Snap!
Crap man...may have to get out the credit card. How did I miss that one, Dan? Is it a new listing?
ed is offline
Old 09-18-13, 07:16 AM
ColinL
ColinL's Avatar
Originally Posted by Dannihilator
That looks pretty close to perfect.
ColinL is offline
Old 09-18-13, 07:25 AM
DX-MAN
Yep, longer-travel 1-1/8" forks are getting tougher to find; 20mm is still popular, but tapered is taking over the market. Come February, I'll be investing in one (likely a Sektor w/15mm, since I just bought a 15mm-compatible wheelset), and just roll that until the beloved Kona frame breaks. The Nixon I'm running now was bought in '07 ('05 model on clearance), and has been on 3 bikes now.
I get the reasoning behind the tapered headset/steerer, it's stronger and can take more abuse. I just mourn the passing of the old standard. (BUT, 1" went the same way.....)
DX-MAN is offline
Old 09-18-13, 07:48 AM
Dannihilator
Still kicking.
Quoted: 159 Post(s)
Originally Posted by ed
Oh Snap!
Been there.
Old 09-18-13, 10:09 AM
dminor
Moar cowbell
dminor's Avatar
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times in 5 Posts
I have three non-tapered-steerer, 20mm axle inverted forks I'd let you have cheap. Plus uncut swappable steer tube spares. Except they're all 8"-travel, inverted monsters
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
dminor is offline
Old 09-22-13, 08:14 PM
ed
ed's Avatar
Bikes: Hecklah
I passed it on to my wife. She said maybe between her and her parents, they can swing it for Christmas.
ed is offline
Old 09-25-13, 10:59 AM
Grimlock
Frozen in carbonite
Grimlock's Avatar
Bikes: '85 Full Cycle Cycle.
Is your Komodo internal or external? Why not replace the bottom cup with a 44mm 1.5" and run a tapered fork? You can probably also find lowers cheap if you find an otherwise perfect QR15 fork.
(I'm back.)
Originally Posted by sp00ki
Using a nicer sealed bearing headset vs a $10 set is like throwing a frisbee vs a dodgeball.
Grimlock is offline
Old 09-25-13, 01:19 PM
dminor
Moar cowbell
dminor's Avatar
Quoted: 29 Post(s)
Welcome back, G.
You're right - - his '04 Komodo frame I believe was semi-integrated Zero-Stack, so 44/onepointfive should work in the bottom.
dminor is offline
Old 10-02-13, 09:40 PM
ed
ed's Avatar
Bikes: Hecklah
Yo! My frame is a 2005 so it's all external. The 2004 (as D stated) was 44mm....so it would have worked on that one, but I got rid of the 2004 in favor of the burlier 2005. I love this frame. I'd probably sell all of my other bike stuff before selling this frame.
So I went a different direction. Thanks for the heads up on the Zoke, Dan...but I'm really digging the rigid setup. I rode my local loop the other day again on this bike with the Kona P2 and just had so much freakin fun. My only complaint would be low BB in the chunk and twitchy at speed.
I've already got the Heckler, so something on the other end if the spectrum was what I really wanted...but still strong enough to drop my lines.
I decided to go with the Identiti Rebate XL 465mm a2c rigid burly jump fork. The frame was designed around 120-150mm fork. Factoring in the average of the two heights plus 30% sag, you get a 470mm axle to crown height. I got an FSA Hammer headset with it, so it raises it another 5mm...giving me exactly 470mm A2C. Perfect. It carves just like it did with the PIKE except with the rigid simplicity, nostalgia and efficiency that I wanted.
ed is offline
Old 10-02-13, 09:43 PM
ed
ed's Avatar
Bikes: Hecklah
ed is offline
Old 10-03-13, 07:08 AM
ColinL
ColinL's Avatar
I can't go back to rigid on any terrain more chunky than a fireroad or dirtjump park. My wrists and elbows just can't do it.
Not that we needed further proof, but you're a better man than me. Have fun!
ColinL is offline
Old 10-03-13, 07:46 PM
ed
ed's Avatar
Bikes: Hecklah
Lovin crap! This thing is fun!
Now I gotta find a QR disc front wheel so I can have a front brake.
ed is offline
Old 10-03-13, 08:31 PM
Dannihilator
Still kicking.
Quoted: 159 Post(s)
Identiti Rebate huh...
I'm a little familiar with that fork. Not the XL but the small A-C Rebate Dirt fork.
DX-MAN
Chain Reaction Cycle sells single wheels, as does BikeIsland.
DX-MAN is offline
Old 10-03-13, 10:25 PM
ed
ed's Avatar
Bikes: Hecklah
It's going to be quite the punisher for sure. Super stout and strong equates to no flex in the chop. I'll have to combat that with tire pressure.
ed is offline
Old 10-03-13, 10:27 PM
ed
ed's Avatar
Bikes: Hecklah
Good call. Been looking there. Got a guy somewhere round here that had an XT 6 bolt/mavic something he said he'd sell me for $20. I just need to find an opportunity to hook up and get it.
Kinda funny...the wheel that's on it is an STX-RC/Sun CR 18 from my 1998 Cannondale Super-V 900 Comp. I changed over to XT x517's on that bike and this wheel has followed me around for 15 years on various secondary builds. It's a good strong wheel though. It's gone off many 2.5-4 foot-to-flat concrete drops over the years.
ed is offline
Old 10-06-13, 04:04 PM
ed
ed's Avatar
Bikes: Hecklah
So I finally met up with the local guy with the XT disc Mavic wheel that he let me have for $20. Straight and true. Even tension. Awesome. My local bike shop hooked me up with a donated 160mm rotor for free.
I got the Juicy's for $40 from another local.
So I got the fork, headset,.brakes, front wheel, and rotor for $160 total.
STOKE!
ed is offline
Old 10-06-13, 05:13 PM
trekker pete
pedalphile
Bikes: trek 1200, 520, Giant ATX 970, Raleigh Talon
Quoted: 5 Post(s)
I'm a mtb noob. Got my feet wet this summer on a $20 old rigid raleigh I found on CL. What an absolute blast that thing was to ride on slower sections. Trouble is going fast over bumps is kinda fun too and I quickly found out that 50 year old clydes, fast bumps and a rigid bike is not a good combo.
So, now I am on an old C-dale Jekyll. I realize the headshock doesn't have a lot of travel, but, what it does have is very nice. And that Headshock is very stout. Has an almost rigid feel to it, control-wise. I am tempted to try a chromoly 29er rigid. I think that with reasonably fat front tire, it might be plush enough.
Anyone out there on such a bike?
trekker pete is offline
Old 10-06-13, 06:59 PM
seat_boy
Bikes: Serial bike flipper
Quoted: 94 Post(s)
Liked 116 Times in 73 Posts
A rigid steel 29er is my basic go-to bike. I've had a few of them over the years.
seat_boy is offline
Old 10-06-13, 08:13 PM
ed
ed's Avatar
Bikes: Hecklah
Seat_boy...nice blog, man. Digg it.
Well y'all...I just got back from the trail and I'm really satisfied. It performed as expected in some ways and totally surprised me in others.
1. Super Chunk: boulder drops, ledges, trials'y hop-up's...etc... this thing likes to wheelie so much better now with a taller fork. Wheelie drops off ledges, manuals off ledges, bunnyhops over logs, Monster Trucking! This thug will buss a cap on the Super Chunk.
2. The Chop: baby heads, big gravel, rock gardens...etc... As expected...the big steel tubes don't flex like the old spindly Kona Project 2 fork legs...not terribly compliant...but a tad more forgiving than aluminum. As expected...I gotta pick my lines, but the thing handles so well that picking lines is simple.
3. The Flow: winding singletrack, fast high-gear pedaly, smooth flowy...etc... This surprised me. The beginning of this trail is hard pack winding fast stuff. This rigid Freeride / All Mountain bike is 28.1#...I don't expect it to feel like my old rigid '98 Easton RAD tubed 22# singlespeed rocket. I expected it to be slightly quicker than my 28# 10oz Heckler, but this thing motors, man! It is situated such that standing for long periods is easy and asks me to pick a bigger gear and motor. It flows around corners well and just feels plain fun.
I'm really happy with it. It's a fantastic contrast to the Heckler. I wish I had one more identical, but with a 4XWC or something light/tough to fill out my garage. This will be my go-to bike for my "on-the-way-home-from-work" trail rides. Throw it on the rack and motor.
ed is offline
SeraphimF
General Cycling Discussion
14
05-09-18 06:59 PM
cncwhiz
Classic & Vintage
23
10-11-15 01:51 AM
AST236
Bicycle Mechanics
6
07-02-14 01:27 PM
steve-in-kville
Commuting
9
10-07-12 11:03 PM
Bike Gremlin
Bicycle Mechanics
9
09-28-11 11:16 PM
