Within reach commuting bag options
Quoted: 20 Post(s)
As much as I love my panniers and rack, they are a pain when I just want to grab my wallet or phone (I don't like to have too much in my pockets when I ride).
What do people like to use as a "within-reach" commuting bag? Ideally big enough to hold a rain jacket as well as my wallet and phone.
I'm leaning towards one of the bike-packing frame bags that are becoming more mainstream now (Topeak seem to have released a reasonably priced one) but because these things don't seem to be widely stocked in physical shops it would be a bit of a leap in the dark to order one.
I'm not sure I'd get along with a handlebar bag because I always get bothered by random objects around the front of the bike - willing to reconsider if they are far and away the best solution.
OK, you eliminated my suggestion, a handlebar bag that opens away from you.
to fit a rain jacket it probably has to be somewhat large..
how about a custom sewed frame bag.. since no clue to that shape, so draw an outline and find someone with a sewing machine.
Otherwise
rather than disappointing an expectation for it to be stocked, call the shop and see if they can add one to their next wholesaler order..
Otherwise
If duffel bag makers included side loops on their bags, that would be ideal.
I just don't like having straps or bungees tying the whole bag down. They get in the way when you need to get something quickly. Hence the side loops.
After looking and experimenting for two years, I'm using an Arkel pannier with backpack straps. Still not ideal but good enough.
Quoted: 4560 Post(s)
Liked 2,802 Times
There really isn't anything other than a handlebar bag that meets those criteria. Years ago I used a Kirtland Tour Pak handlebar bag, with the big ol' metal support that hung off the step. Worked great, wish I'd kept it.
Now I use an Agu Qyoto 820KF
with KlickFix mount (Nashbar occasionally has 'em on sale for $40, including the KlickFix mount, so it's a bargain). In some ways it's even better than the Kirtland was. Simple hinged lid that opens away from me while I'm on the bike, and the lid is secured by two small bungee loops with leather tabs and brass pins as holders. The lid is a friction fit, like a well fitted gift box. Easy to access stuff quickly, even while riding.
There's an inner drawstring bag closure for more security. No padding but it's shaped identically to my old Beseler canteen style camera bag, so I swap the same padded floor and compartmented liner to the Agu bag when I'm toting camera gear. If I'm not carrying anything fragile I omit the padding.
There's a traditional map pocket secured to the top via Velcro. It's touch sensitive so a phone or small tablet can be protected there, visible and accessible while riding for folks who use GPS navigation aids.
In winter, it holds my windbreaker or even my heavier Shimano Storm Jacket, extra gloves, etc. Compact camera, snacks, whatever I need that day. I can reach everything quickly without dismounting. I can safely reach some items while riding, due to the well designed lid.
Reportedly all Agu bags are weatherproof (they're made in the Netherlands). So far I've been only in light misting rain, which most bags can handle. The Agu outer shell feels plasticky, like waterproofed ballistic nylon, so it may indeed be rainproof.
And if you don't like that particular model you can order the more current Agu bags direct from Europe. Easier than ever now especially with favorable exchange rates.
A few nits to pick:
A few nits to pick:
- On really rough roads the bag will pivot toward me, around the Klickfix mount, which could spill the contents if the lid was unsecured. But nothing was dumped when I had the lid secured by the little bungee loops. I fixed the problem with a short, thin bungee cord hooked through the bag's strap attachments and around the handlebar stem.
- The bag sits up pretty high, higher than the Kirtland Tour Pak did which put the lid at handlebar height. Just the nature of the KlickFix mount design. It can interfere with headlights so I mount my light around the head tube under the bag. Works fine that way.
- The zippered side pouches aren't very useful. The zippers are unusually thin and fragile and one of 'em stopped securing properly almost immediately. I only use the side pouches to hold inconsequential stuff like snack bars, empty ziplock bags in case it rains, etc. Anything important goes inside the main bag.
Quoted: 7353 Post(s)
Liked 2,483 Times
Handlebar bags really are da bomb.
I like this Jandd frame bag on a road bike. Well made and thoughtfully designed.
This bag top section is big enough to hold your wallet, phone and rain jacket and if you extend it (that zipper on the orange section, even more stuff). It uses a double zipper so you can have it open by your left or right side near your back. Simply twist around and pull the zipper away from you to open it. The panniers are expandable if you need even more room.
handlebar bag. However, I've carried a light rain coat, phone, and wallet in my jersey pockets. Don't you stop to use any one of those items anyway? I don't ride and talk on the phone. I'm not coordinated or confident to put my rain jacket on while riding. Not sure what I'd need my wallet for while on the bike???
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
If you want to take a cheap run at a frame bag
go to Amazon and pick up an Ibera. For what you are wanting to do they are adequate. At $15 give or take you can guess wrong on the size and then up size or down size without breaking the bank. You could even send the original back for an exchange. But here's my caveat: don't be stupid and try to put on or take off a jacket while on the bike and moving. Last week while getting my teeth cleaned my dentist told me about a patient whose jacket got caught in the spokes and is now paying for her daughter's tuition.
Quoted: 185 Post(s)
Liked 36 Times
I was contemplating something similar to what you're looking for - frame bag, but I needed it to carry a cable lock and U lock, and none of the frame bags that would accommodate the U lock would actually fit my frame size. So FYI for that feature. I ended up going with the banjo brothers handlebar bag with tie downs, which definitely fits all of your stuff very easily.
Quoted: 5224 Post(s)
Liked 3,585 Times
I have a handy small bento bag (as well as the run of the mil rear rack & trunk). don't know why they are called bento. it's not a brand it's a style. it sits on top of the top tube at the stem. mine is small, just right for a snack & cell phone
like this one
if you need a rain jacket - you're gonna have to stop to put it on, right? so maybe it doesn't needs to be within reach? all our bikes have rear rack trunks. simple, cheap & easy
like this one
like this one
like this one
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 3,585 Times
oh sorry, that's not me or anyone I know, just some random image found via a google search. when I bike to work there aren't any other ppl going my way. I have no idea how my speed compares. but rear trunks have less wind resistance that panniers, right? that anonymous woman has a decent saddle bag, but I doubt she's got a rain jacket in there. this is the trunk I use
it moves from bike to bike. I think the zipper broke on my bento bag so I have to replace it
it is waterproof & insulated & can double as a cooler & it came with a rain (& snow) cover. sorry about the snow fellas. was practically the last time I went for a freakin bike ride :/
Liked 2,483 Times
Please no pictures of snow this month. Thank you.
Bikes: 2016 Felt Z85 105, 2016 GT Grade Sora
Quoted: 117 Post(s)
what about a larger top tube bag like this one?
Transit Escape DX II Top Tube Bag
not the prettiest thing to look at but if your rain jacket is small enough, this might do it.
other, my suggestion would be to get a small rack trunk bag if it doesn't impact the mounting and removal of your pannier set up. i was looking at the ortlieb one a few days ago - its pretty big and of course waterproof and all that. wasn't great for carrying through, you use the roll top as a handle. i've seen some topeak trunk bags that are small, and have organizers and pockets and the like for you if you just wanted to carry some essentials.
good luck.
good luck.
Heck on Wheels
Bikes: In Signature
Quoted: 206 Post(s)
Go Hipster:
"I had a great ride this morning, except for that part about winding up at work."
Bikes so far: 2011 Felt Z85, 80's Raleigh Sovereign (USA), 91 Bianchi Peregrine, 91 Austro-Daimler Pathfinder, 90's Trek 730 Multitrack, STOLEN: 80 Schwinn Voyageur (Japan)
Quoted: 20 Post(s)
Thanks for all the feedback so far.
I was passing a bike shop today and had a look at what they had in stock. They actually had one of the Blackburn frame bags and although there is a lot of neat design in it, I realised that the fact it is "permanently" connected to the bike would rule it out for use around town.
They also had some handlebar bags and the one that was nominally 7 litres took the jacket comfortably, and the one that was 5 litres just about took the jacket as well. I was impressed.
I hadn't thought of a trunk pack, maybe I will take a look at how easy they are to open if I just twist around on the saddle.
Someone mentioned how you don't need your phone and wallet on the move... I agree... it's just that I like to be "organised" and I end up having to dig around in the pannier a bit more often than I want... first world problems
When I had a Long Rural Commute I had a Zzipper Aero Fairing in the front, and hung a canvas musette bag behind it..
Quoted: 1952 Post(s)
Liked 2,014 Times
Consider a Carradice saddle bag. I buckle mine to the loops in my saddle, but they have quick release things that may work for you.
If you love your pannier, keep using them. Put your rain gear at the top on one side and put your wallet, phone and other small personal stuff in a small funny pack and put it at the top of the other side. Either will be within easy and fast reach when needed and you don't have to spend money on another bag.
There's a Motobecane on eBay right now with a Vintage 70s bike that has what appears to be a big leather dopp kit for it's handlebar bag. Props for improvisation.
Quoted: 18382 Post(s)
Liked 4,515 Times
The local department stores have small zipper phone packs.
https://www.target.com/p/bell-stowaw...g/-/A-16602290
I found this rain jacket a few days ago that came with a small stuff sack. Apparently an older style, but perhaps one could find a similar one, or perhaps a small jacket that stuffs into its pocket. Or, with some luck, a lightweight bike jacket would stuff into a small stuff sack.
There is also lightweight emergency use (single use) rain gear that one might consider.
Anyway, one could likely pack one's phone, jacket, and wallet all into a small top tube bag.
