How ugly is this?
Quoted: 3811 Post(s)
Liked 6,716 Times
How ugly is this?
In a different thread, I showed this trash-picked, little, and heavy Bianchi that came my way over the weekend:
In my stash I had an equally low-end fork that had the right sized steerer and compatible threading with the Tange headset I had in the bin. Took a little straightening in my jig, but should be good to go:
So how ugly is this orange in contrast to the Celeste? Should I respray it dark blue to match the lettering? Black? Decoupage?
Likes For nlerner:
Likes For rando_couche:
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
Character!
Paint the rear triangle orange. (or at least the dropouts and "socks.")
Brent
Brent
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Since it's going to be a Frankenbike, why not let it look like a Frankenbike? (And I use the term affectionately.)
Likes For bikingshearer:
Likes For Roger M:
Those lugs make me think this was originally a mountain bike frame, correct? Never seen lugs like that for a steel bike.....usually seen lugs like that for a Carbon/Steel or early aluminum frames in the 1980's when they bonded tubes together (see Raleigh Tecnium 400 series bikes).
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,099 Times
It’s OK if you accessorize with one of these
Likes For Spaghetti Legs:
Quoted: 3241 Post(s)
Liked 2,512 Times
St. Patrick's Day bike?
Liked 6,716 Times
Yeah, the lug work is similar to Kabuki/Bridgestone/C.Itoh and other Japanese-made bonded steel frames. Kind of a surprise that Bianchi did this, too (it has a Made in Italy sticker). The wheels you see fitted are 700c, so I don't think it was intended as an MTB.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
That is clearly exactly a Bridgestone/C.Itoh/Kabuki and was given Celeste paint and decals, nothing makes me think this ever was a legit Bianchi. If in doubt, tell us the serial number. Depending on the original model if this is a "Submariner" it could have stainless steel tubes, but those "lugs" are cast aluminum.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,841 Times
There's ugly (which I know firsthand) and then there is needlessly ugly.
At least find some chrome paint for the fork, so as not to insult celeste too much.
But it is your free frameset.
Liked 6,716 Times
Likes For nlerner:
The lugs were injection cast around stainless steel tubes.
Bikes: yes
Quoted: 14 Post(s)
Liked 10 Times
I'm with unworthy1. I have a Kabuki with exactly those "lugs" even the little fitting on the BB.
A magnet will tell you what's aluminum and not, eg. my "Superlight" has alum. lugs, top and down tube, stays,
but steel seat tube, and a steel threaded insert in the alum. BB.
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 348 Times
Is it just me? Does that fork look bent to anyone else?
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
Bikes: Bianchi Nyala, Bianchi Volpe, Bianchi Campione D'Italia, Trek 640, Luxus folding bike, Schwinn Speedster, Bianchi Torino, KHS Aero Sport, probably something else around here somewhere
Quoted: 117 Post(s)
Liked 198 Times
I'm with the group saying it's not a Bianchi. I've never seen any Bianchi, road or mountain, lugged like that. I'm also in the group that thinks that fork may be bent.
Quoted: 3015 Post(s)
Liked 3,804 Times
Did you get a free bowl of soup with that? Looks good on you though.
Liked 6,716 Times
That would have been nice. I did come with a set of SR bars and stem, Weinmann brake levers, and SunTour stem shifters. I might have preferred the soup.
On the fork, yeah, steerer might need some tweaking still.
On the tubing, it's not a Submariner. The tubes are solid gas pipe, not SS. Kabuki made a bunch of other models with those lugs, and this might be one of them.
Edit: Looks like the Skyway model might be the most likely candidate.
If not going to dedicate it as a fixed frame MTB, then I would throw on either (a) path-racer style bars or (b) flat bars with some bar end extensions for more aggressive riding
Likes For Het Volk:
