Just bought a Giant Revel Aluxx 6000 series bike
Old 07-12-19, 02:19 PM
Joshman380
Just bought a Giant Revel Aluxx 6000 series bike, and so far I like it. I bought it used for $100. Needs some new tires and a new cable for the front derailleur, and maybe a slight adjustment for the rear, but otherwise rides real nice and smooth..no chain skipping like my other purchases.
My question is, the bike came with v-brakes. I'm wondering if this bike can be converted to disc brake easily?
Joshman380 is offline
Old 07-12-19, 03:00 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
What do you think?
trailangel is offline
Old 07-12-19, 03:44 PM
Joshman380
Originally Posted by trailangel
What do you think?
If I knew the answer do you think I'd be asking? Wow.
Old 07-12-19, 04:30 PM
Bigbus
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times in 244 Posts
Yeah, that was kind of rude... At any rate, if you simply look at what is involved on a bike with disc brakes you'll quickly figure out that there's a little more to it than simply super gluing a disc on the hubs. Caliper mounts, hub swaps, and you can see already it's not going to be simple or cheap. If even possible. HTH
Bigbus is offline
Old 07-12-19, 05:02 PM
carlosponti
Bikes: '90 Raleigh Technium Prestige, '90 Fuji Thrill - Gone, '18 Fuji Nevada 1.7 29er, '19 Fezzari Abajo Peak
Quoted: 38 Post(s)
Liked 34 Times in 23 Posts
cant tell by the picture but you have the mount on the frame for a rear disk brake caliper. if you dont have the mount for the caliper on the front fork you have to replace the front fork with a newer fork. hubs have a disk mount for disk brakes which you probably dont have on those hubs. new wheelset or hubs is needed possible new fork and a brakeset talking probably another 200 or more. to be honest if you change the pads on the brakes you have and ride it on cross country trails it'll be a fine bike as it is.
carlosponti is offline
Old 07-12-19, 06:29 PM
Joshman380
Thanks for the constructive help, guys. Here's a closer pic of the fork. Honestly I just like the idea of disc brakes more than the v-brakes.
If it's too much I'll forget about it and ride it as is
Old 07-12-19, 10:38 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
Nice find, fork doesn't look like it's disc compatible. V- brakes are perfectly serviceable. A still have a few with them and they stop great. Unless you are riding a lot of downhills V's are just fine.
A new fork,brakes and new wheels which take discs are not worth the effort and cost.
qclabrat is offline
Old 07-13-19, 07:55 AM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Liked 24 Times in 21 Posts
Just calipers, rotors and wheels are going to be 3x what you spent on the bike. IMHO - fix it up either tires/cable/adjustments and ride it.
grubetown is offline
Old 07-13-19, 10:02 AM
Joshman380
Again, thanks for the input.
I found this bike locally, of course, through Facebook Marketplace. I find the pricing there is a LOT more reasonable than used bikes on CL for some odd reason.
So, I suppose I'll just stick with what I have. I like the bike, it rides smooth..that's all that matters.
The fork suspension seems a little squishy but it doesn't bottom out. I think that can be adjusted...
Old 07-16-19, 09:56 PM
Joshman380
By the way, can anybody ID which Revel model this is (Revel 0,1,2,3,etc)? Not even sure which year it is. Trying to match it up with Google pics but it's not helping.
Old 07-17-19, 07:47 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
take pics of the other side with parts clearly shown, harder to tell from the non-drive side
qclabrat is offline
Old 07-17-19, 09:33 AM
carlosponti
Quoted: 38 Post(s)
most likely its a revel 3 from 2014 https://www.bicyclebluebook.com/Sear...spx?id=3051104
Old 07-17-19, 02:34 PM
Joshman380
Yeah, it's a 2014 Revel 3. Confirmed it with the original owner. Thanks! Now I know what to look for when I want original replacement parts.
Old 07-17-19, 02:45 PM
Joshman380
Well.. according to this it looks like I might want to get a better fork anyway..I have the SR Suntour m3010..suggestions?
EDIT: Checking my serial number and it starts at 13, so it doesn't fall within the recalled serial numbers..I still wonder if it should be replaced anyway....
https://www.bicycleretailer.com/reca...s#.XS-HvWRlAew
Old 07-17-19, 05:40 PM
HerrKaLeun
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 900 Post(s)
Liked 231 Times in 168 Posts
Don't put upgrade money into this bike.... it is what it is. If you need a better bike, better save up for one.
You could dump $500 into this bike, but it still will be way behind some lower cost newer or used hardtails. literally everything is better on a new $1000 hardtail and much is hardcoded into the frame geometry and wheel standards.
No offense, btw.
HerrKaLeun is offline
Old 07-17-19, 05:52 PM
Joshman380
Originally Posted by HerrKaLeun
No offense, btw.
None taken. I'm just a little concerned about a pre-recall fork that might have me doing a faceplant into the ground or worse.
I'm not, however, someone that's going to throw $1000 or more at a bike, when that money could be used to put a down payment on a newer car, take a trip, etc. So I want just a little nicer...call it personalization.
Old 07-21-19, 12:37 PM
Joshman380
Step 1 of personalization
Now for matching grips, pedals, and saddle.
Old 07-24-19, 07:13 AM
prj71
Quoted: 2975 Post(s)
Liked 1,182 Times in 771 Posts
No offense, btw.
So much this.
I wouldn't take that thing off the pavement on a trail.
prj71 is offline
Old 07-24-19, 09:16 AM
KraneXL
Quoted: 3405 Post(s)
Liked 240 Times in 185 Posts
No.
KraneXL is offline
MBurke
Bicycle Mechanics
14
11-12-17 11:38 AM
jrenz11
Hybrid Bicycles
9
01-09-15 06:01 PM
emanuel_v19
Hybrid Bicycles
17
09-24-14 05:58 AM
cs1
Hybrid Bicycles
30
05-10-14 04:22 PM
Simko
Mountain Biking
3
05-18-11 04:47 AM
