How long to give a new Brooks B17
Eric C.
I have an electric bike that I'm riding more now (commute is 10 miles one way) but the saddle was uncomfortable. I bought a Brooks B17 Imperial (cut-out) and I've ridden it three or four commutes now. It's really uncomfortable on the left side, like it feels like a nerve being pinched. I found if I put the saddle level I was sliding forward, so I have the nose up at the moment. That puts me in a stable position, but I'm left wondering if perhaps it's uncomfortable because maybe I'm sitting on part of the rail? How long should I break in a Brooks before I know it's not going to work for me?
Quoted: 2604 Post(s)
Liked 1,933 Times
To answer the direct question, the B-17s that I've put on were never UNcomfortable, but they became more comfortable after 500-1,000 miles.
The asymmetry would concern me. It's possible there's a problem with the saddle, or it may be the rider. :/ I would wonder about a leg length mismatch (that might be corrected with shims), or possibly, if you're using clipless pedals, one cleat is further forward than the cleat on the other shoe.
Quoted: 5224 Post(s)
Liked 3,585 Times
hmmm, errr, mine (B17 regular) was good for me me right out of the box
Quoted: 741 Post(s)
Liked 818 Times
I have 2 B17s and a Brooks Professional. Never had a comfort issue with either of them. Proper padded bike shorts help for any saddle, if you aren't already using them. I ride mine pretty much dead level. Moving it fore and aft along the rails might help to get it dialed in. I've gotten two from Ebay from people who didn't like them, so maybe they are not for everybody, but they work for me. I've been using them since 1964. None of mine have the center cut outs.
Bikes: Fuji Gran Fondo 2.1 and Scott Sportster P45
Quoted: 81 Post(s)
" The nose up at the moment" How much is up? If you keep sliding forward on the saddle I'm guessing either the saddle is at the wrong height or you need to adjust it forward.
Eric C.
tcarl
Bikes: Roark, Waterford 1100, 1987 Schwinn Paramount, Nishiki Professional, Bottecchia, 2 Scattantes, 3 Cannondale touring bikes, mtn. bike, cyclocross, hybrid, 1940's era Schwinn
Quoted: 27 Post(s)
Liked 9 Times
That doesn't look "nose up" to me. That's about how all my leather saddles are.
My B-17 was instantly better than the oem it replaced. Somewhere around mile 400, it simply became unnoticeable, which is about the best you can say about a saddle.
Some people are like a Slinky ... not really good for anything, but you still can't help but smile when you shove them down the stairs.
Quoted: 82 Post(s)
Bikes: Volkscycle, Trek Fx3, Specialized Hard Rock
Quoted: 33 Post(s)
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
I doubt that saddle will ever be comfortable for you. I experience the same frustration. It's a bummer when the holy grail of saddle comfort finds us squirming on short rides. If I were you I'd consider an ISM comfort saddle.
not a good fit?
Other possibilities bars to far away and too low, ..
Need a gel comfort saddle instead, ?
A couple of things. I've used Brooks saddles exclusively since the 1970s- admitting however I fell out of cycling in the 90s and back early 2000s on and off. Mostly off but I'm back baby! Anyway, there are those that say take a 'level' and put it on your seat. Usually there's a sag in the middle but the back and nose rest against the level. This usually results in a saddle that looks like the nose is high, but your butt is centered in the saddle. There are those that say soak your saddle in Neatsfoot Oil to soften and help contour the saddle. Some say that is the worst you can do. The middle ground may not be a bad idea. Wipe Neats on top and bottom a few times- versus soaking. It does darken the leather, but does soften it some. Don't over-do and you may find it helps. A little then stop. A little then stop. Off-center- maybe a little more oil on one side than the other. Or, hand massage the seat HARD! Seriously, push, massage, PUSH OH YEAH! DON'T STOP! I'm now thinking of an uncensored Family Guy video forgive me:
IF YOU WATCH IT'S NOT MY FAULT! DON'T DON'T WATCH!
Bartender!
Bartender!
Most Brooks I've had over the years were comfortable right out of the box but were hard like wood. That's where the break-in period comes in to play. If that Brooks is not comfortable riding now it may never be comfortable. Just FYI.
If you don't peddle a lot, as on an eBike, I would think that it might take longer to break-in? I don't know for sure. I think the act of peddling is what messages and moves the leather. Just sitting on it may take longer. You should start to notice a difference after 300 miles or so...I would think....
Quoted: 1034 Post(s)
Liked 1,292 Times
You also have a lot of drop. You may or may not be able to get the seat to work, but you specific problem doesn't really sound drop related.
Go through the steps on Hogg's site for setting seat setback and height. It should help. https://www.stevehoggbikefitting.com/bikefit/2011/02/seat-height-how-hard-can-it-be/
https://www.stevehoggbikefitting.com...d-can-it-be-2/
Bikes: Trek Domane, Surly Disc Trucker
Quoted: 170 Post(s)
Liked 103 Times
As others have experienced, my B17s felt comfortable for me right out of the box. I have two, one on my road bike and the other on my touring/gravel bike.
Quoted: 913 Post(s)
Liked 515 Times
My B17 remained hard as a rock after 9 years. I would often complain about my saddle to other cyclists and to bike store employees, and was often told to keep at it, and one day the saddle would break in and I would experience saddle nirvana. Sadly, that day never came, and when I finally got rid of my saddle after 9 years, I reckoned that that magical day would come the same day that Elvis astride a pink unicorn would fly out of my ass.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Lower the saddle a wee bit before doing anything drastic.
Occam's Rotor
Liked 2,331 Times
Eric C.
What seat did it replace and how high was it off the rails? If you simply replaced the seat without adjusting the height, it may be too high. The B17 is not very forgiving with respect to a too high seat height. I had issues, similar to yours, and it was too high. I too slid forward, and had pain. Later, as the dimples appeared, they were off center, showing I was dropping one leg to compensate. I have since lowered the seat, using Steve Hogg's methods, and I now can run the seat with the nose almost level, and i do not slide forward at all, I am stable. I have zero pain, and the dimples have now reformed where they should be.
I'm 6'5". So it may look like a lot of drop, but I'm actually fairly upright.
I'll re-do some of the fitting with the suggested site. Thanks again.
Occam's Rotor
Liked 2,331 Times
I had to lower mine a bit more than I would with other saddles, or one side (corresponding to a very slightly shorter leg) hurts.
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times
I bought my Brooks B17 mail-order from a place in North Dakota or somewhere. It was a tad cheaper than from other better-known outlets. Took me a while to realize it was crooked. When the back part is centered, the nose points off to the right by 5 or 10 degrees. I find that centering the back with the nose pointed off to the right is comfortable. Nose appears quite high relative to the back. I have done 50-plus mile rides on this & have no complaints about the saddle. Before setting the nose off to the right and pointing it high, long rides caused horrible hip pain on one side.
Bikes: 2011 Rivendell Sam Hillborne, 2016 Brompton M6R, 2017 Ritchey Timberwolf
Quoted: 14 Post(s)
I’ve had great luck with B17s but had to shift to a sprung Flyer Special when I ride in a more upright position. I found that the more upright I was, the less comfortable my old B17 was. The Flyer provided just enough spring (not much mind you) to dampen vibration and comfort the upright riding style. They do make a Flyer Imperial but it only comes in black.
John
John
