Cooling off with water splashed on body
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I have been commuting all summer, including on the hottest days. I have tried various strategies to stay cool in 90+F high humidity weather and have settled on splashing myself with water. If I splash about a bottle an hour it can almost feel like it's in the 70s on a 90s day. On longer rides I have an iced one liter pack that I put in my back jersey and use that for splashing as it melts. For 2-3 hour rides I can keep pretty cool with that.
One thing I think is key is to have a thin skin-tight jersey, then when the water evaporates the cooling goes directly to the skin. The more there is between the evaporating water and your skin the less cooling you will get. I am using a special Castelli summer jersey for this now which is partly see-through.
If you watch Tadej he is clearly up on this, he is always unloading water on himself. But a lot of pros don't seem to do it much. Also I never see other riders doing it when I am out and I don't get it.
I'm curious peoples opinions on this, and if you do it what the optimal way to splash is. I find anything getting the water on your body (as opposed to bike or ground) is good, I often raise my head way up and pour through helmet cracks. That gets the whole head as well as the upper back with little water loss. Also splashing on the front and shoulders of the jersey works well but with more loss that way.
BTW there are some reports out there that it doesn't really help, it's better to drink the water than splash it on you, but that is BS. Here is an article for example that describes how splashing cools effectively. https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4964991/. Yes you also need to drink but you don't get the cooling gains from just drinking and if you are not careful you can overhydrate. When you are splashing more you sweat less so you also can drink less and use up less of your salts on sweating.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I don't really like to get all wet. If I have sweat building up in my clothes, I think that's a sign that it's already coming on faster than it can evaporate. I sometimes spray a little water on my face and head, but not my body.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Splashing water puts about 5x as much water on as sweating and so you get 5x the evaporative cooling. Your body also saves energy and salts not sweating. Try it on a hot day sometime and you will agree with me after your first ride, the benefits are obvious.
Quoted: 24 Post(s)
Liked 42 Times
It doesn't work as well as drinking it. It your water supply is limited, you shouldn't waste it by dumping it on your head (with half of it going onto the road). It works great though if you have a SAG car handing you bottles.
Likes For jrobe:
Quoted: 4260 Post(s)
Liked 1,364 Times
No, because one might not find the thing you found.
"Help" isn't specific enough.
Here's what your report says:
Is this that unreasonable?
However, despite these indicators, performance in the 5km time trial did not vary significantly from trial to trial. In other words, it didn’t seem to matter (in terms of out and out speed) whether the runners did nothing at all, or poured water on their heads and drank something; their running ability in a short, high intensity bout in the heat was pretty much unaffected.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
I’d personally rather be carrying a bit more weight and feeling like a champ than having a few pounds less and feeling ready to keel over.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I like to drink my water. I usually only carry two bottles, 20 or maybe it's 24 oz. each. On a long ride in hot weather, I might stop to buy a Gatorade along the way. If I ride past some sprinklers, I might let them spray on me. But I will not ride around dumping my bottled water over my head and whole body, then having to stop for frequent refills. That's just one guy's preference; you can do your thing.
Quoted: 2490 Post(s)
Liked 2,961 Times
Thanks for this thread, scottfsmith. I've noticed this summer that, riding during the hottest days, I find myself slowing down, feeling weaker, and becoming more irritable. Reserving one bottle for splashing water on my head and back would probably have helped immensely. I'll try it during my next ride when it's an over-eighty-degree day.
I usually return from a four-hour ride in the heat having drunk all of one 24-ounce bottle of water and a few ounces of another, so I'm probably not drinking enough. But even if I were to use up both bottles by drinking and wetting my helmet and jersey, I could always plot a course that brought me past a convenience store where I could buy another bottle of water before the second bottle is empty.
Quoted: 970 Post(s)
Liked 1,632 Times
I am well known for slowing down and even stopping for those stray streams of the yard sprinkler on a hot day...
Likes For zandoval:
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
In theory, wetting the body with water should help prevent dehydration and the problems inherent in hypotonic fluid replacement, since skin wetting inhibits sweat production. However, I have never seen this proposed as a real-world approach.
Likes For MoAlpha:
Quoted: 1591 Post(s)
Liked 1,020 Times
When playing golf (walking the course) on 95+ degree days I'll drench my visor in cold water at the water stations. Cooling the head seems to provide at least temporary relief.
I like to have a just water bottle to spray on my neck on hot rides, it is refreshing to me. Oh the other hand, make sure not to use the electrolyte replacement with carbs for the brief shower. That is a f'jng mess, l know.
Likes For howsteepisit:
That's a very quick and easy method to stay cool out here. It actually doesn't take much to cool you off, but it evaporates so fast, you could easily go through a large bottle on a relatively short ride in the summer.
I don't know how y'all do it in the high humidity. That crap tries to kill me.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Riders on the pro tour do it all the time... No one likes to be soak wet so unless there is a real and proven benefit, I don't see why the best cyclists in the world would be doing it.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
I have used two of these Platypus bottles on longer rides for 4 liters total, but I have a nice stopping point for rest and water (Veloccino, since you are also in Baltimore maybe you know it) so rarely need more than 3 liters total. Also I start out drenching myself from the yard hose and can re-drench at any refill station.
Quoted: 5224 Post(s)
Liked 3,585 Times
after watching the tour de france one year, I started pouring water on my head, thru the helmet vent holes. I remember liking it very much
Quoted: 970 Post(s)
Liked 1,632 Times
When my back road rides were longer they were plotted according to what water points were available. I do not tolerate thirst well. Dehydration and exhaustion are sneaky sneaky. They will come up on you and put ya down. Even the most experienced have had issues now and then.
Ridding through hot dry terrain is a survival skill...
Quoted: 989 Post(s)
Liked 586 Times
Likes For eduskator:
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
Yep, this is something I have been doing since one hot day when I was overheating and had to stop. A nice young woman stopped and offered me water, but I felt hot, not dry, so I asked her to pour it over me. I felt better instantly. So now on hot days, once my bottles of Hydration Mix are empty, I refill with water, and if I feel hot, I stick the nozzle of one in a hole in my helmet and squeeze. Then I squirt some on my back. Works a treat, IME.
Quoted: 3241 Post(s)
Liked 2,512 Times
I like bike
Quoted: 267 Post(s)
Liked 283 Times
My current favorite method is to find a safe stretch on the ride, look way up, pour a ton through the helmet at the mid-back point, and keep looking up for ten seconds. The excess will then flow on to the back. Too much and it will get all the way to the pockets and too little will wet too little so it takes some practice to get right. There is no water wasted this way. If you don’t look up long enough some excess will drip down in front and get wasted.
I also will spray a small amount on front and shoulders but there is more waste so I don’t use too much there. Of course if a refill station is coming soon, let ‘er rip!
