Cone and Axle Sizes
Cone and Axle Sizes
So a while back I picked up an old Schwinn Twinn Deluxe with the atom drum brake. It was in not so great shape cosmetically but the mechanicals all seemed good, and the frame was in good shape.
When I got home with it, I found that the rear axle was busted, I planned on rebuilding it anyway, but now it's time to put it back together and I'm short a rear axle.
So it looks as if the original axle was a 3/8-26 tpi x 7", there is a lot of discussion on the topic from a google search, but the thread gage reads 26 tpi, not 1mm for sure. The size is kind of silly so I was wondering if the cone sizes matter or can I get a standard 3/8-24 axle, maybe even a 10mm? as it seems that there is room in the dropouts. I also find it kind of odd considering that the front axle appears to be 1mm pitch.
Not sure i understand the question, but the cone has to thread onto the axle, so the 3/8 - 24 will need new cones also and it all has to fit the hub. Can't find an axle on eBay or somewhere?
Basically can I just pick up a new axle and cone set or do I need to stick with the oddball one? Difference is ~$20 when new cones are added.
Quoted: 6193 Post(s)
Liked 4,809 Times
If you are buying a complete axle with cones and nuts, then as long as the cones are similar in size to the original cones you can probably use it with the old hub and it's cups. Make sure the major diameter of the axle is as close as you can to the original.
If the cones are shorter, but otherwise roughly the same diameter, then you may have to add some spacers to match your dropout spacing
https://wheelsmfg.com/ might be a place to look..
but even they suggest bringing the wheel into a bike shop..
https://wheelsmfg.com/products/hub-parts/all-cones.html
note some of the many things you will need to measure..
Quoted: 1944 Post(s)
Liked 2,164 Times
Always a tough call where to post, but you might want to ask this in the C&V forum. A 50 year old tandem may not get the same responses as people who live and breathe the old stuff.
John
John
Quoted: 4205 Post(s)
Liked 3,863 Times
I think the OP will find that modern cones will be a class b/c fit at best to the hub's outer races. When Asia came on line to the US market one change was the bearing contact angle that was common. This means that the cone's curve of the bearing surface, the inner diameter of the curve, were different from the (back then) common Normandy/Atom stuff. So I suggest just replacing the axle.
Go to your LBS and ask them to order from QBP part #HU8262 . It is a Wheels (of Boulder as they were know initially) 9.5x26 solid axle of 187mm long. It shows to be in stock.
BTW when I last rebuilt my Atom drum brake tandem hub (I assume it's a tandem, never directly said though) it has different dust covers for the hub shell bearings. The one with the felt insert was for the drum side so to help limit brake shoe dust from getting into that side's bearings. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
