Holes in Disk Rotors
Quoted: 239 Post(s)
Liked 7 Times
Does the number and size of holes in a disk rotor make a difference in braking power?
I know they're for mud clearing, but what about when riding dry?
in dry conditions, would a rotor with fewer/smaller holes (and thus more surface area) have stronger braking?
Dissatisifed with mine and have to wonder if that might be a factor to consider in replacing....
Quoted: 303 Post(s)
Liked 136 Times
Holes are more for heat dissipation than fluid clearance, but do accomplish both. It is a fine art
designing disk rotors that don't warp when hot, and heat is a more consistent problem than
water which is a more likely problem than mud. Holes do help clear the fluids (mud/water) as
well. I doubt you would notice much difference in braking power in reality but yes in theory
more rotor metal would assist braking. I would look elsewhere first before changing rotor just
for perforation amounts, such as pads or a bit larger rotor if possible on your frame.
Non omnino gravis
I would say the first step is to make sure your current rotors/pads aren't contaminated-- wipe the rotors down with some denatured alcohol, lightly re-surface the pads by sanding them on some 400 grit sandpaper laid on a piece of glass (or anything equally flat.) When cold, most any rotor/pad combo should provide adequate stopping power. Also, if your calipers are mechanical, make sure the gap between pad and rotor isn't too large, that will give the levers more travel and make the brakes feel unresponsive.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
I would agree that the rotor and the pad aren't going to be a problem. The caliper, on the other hand, could be. Not all calipers are equivalent and there are some out there that simple don't work that well no matter what pad or rotor you use.
Stuart Black
Stuart Black
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
(I am thinking selfishly with thoughts of my own brakes).
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
I'd like the OP to give more details about why they are not happy and the bike/set-up we're talking about.
I've logged 20,000+ miles over 13 years on three disc brake bikes. I've used these bikes in nearly every environment/conditions imaginable* and the only times I've found my disc brakes less than great is because of maintenance issues.
* I live in Minnesota, so I don't have long descents.
Stopping power is mostly affected by the clamping force of the caliper. It doesnt matter if the rotor is full of holes or solid. Learned this years ago when drilling motorcycle rotors became all the rage.
Next in line is the rotor material. Some are great and some just suck, followed by brake pad material. Using rotors and pads of the same brand should bring a bigger smile over your braking abilities.
-SP
-SP
Louisville UCI Pro CX world championships , the riders , few that were running discs
Could not get the pads to last an Hour.. the elite race length..
So they got some made with out any holes.. flown in overnight..
the sand pit they had to cross every lap left enough sand in the holes
to wear thru the Pad Rapidly.. too Much abrasive Friction.
Quoted: 239 Post(s)
Liked 7 Times
I'm using TRP Spkye mechanical calipers (mtb pull version of Spyre)
Clarke's organic pads
with Yokozuna Reaction compressionless housing
and an old Deore XT M739 series lever
The rotor is the big holey 180mm one from EBC found here
and I am aware of how to set up a lever to grab as my fingers wrap for ergonomics/hand strength
My dissatisfaction, is the inability to lock the front brake and endo.
I'm 190lbs
Reviews of the TRP Spyke/Spyre often claim great modulation, un-spectacular stopping power. Maybe I'm seeing that firsthand. A gradual grab that makes it more useful for bleeding momentum than doing an endo stoppie.
Thanks
I'm 190lbs
Thanks
Liked 4,220 Times
I have Spykes on 3 bikes without any special cabling using 203mm rotors on the front and either 180mm or 160mm on the rear (or v-brake for one bike). My rotors are Avid or Magura Storm or Magura Storm SL. All of them have lots of holes and the Storm SL has more holes than the Storm. I haven't noticed any lack of braking ability and, in fact, the brakes judder now under heavy braking as the fork blades move back and forth. Never noticed any judder when I had Avid BB7s.
But all of my brakes...disc or rim...are run so that the levers are basically locked at about half travel to the handlebars. I think that is the key to having effective brakes. I tried the longer travel method in the past and it lasted exactly one very short ride.
Try pulling the pads in closer.
Stuart Black
Stuart Black
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
Liked 8 Times
Rotors have holes in them to aid in cooling and reduce rotating mass, simple stuff but people often overlook at the pads as part of their braking package.
Good pads are as important as a good rotor because, together, they stop you faster with more control.
If you don't feel secure with your brakes, that might indicate some adjustments are needed but usually, parts need to be replaced or upgraded.
Brake bleeding, fluid levels, rust, "stiction" of the pads and more can really affect the braking performance of a bike.
