Marathon Supreme 700 35mm or 40mm, how good are they?
Quoted: 24 Post(s)
How good would these tires be for my purposes.
They would be on a touring bike.
I am only on good roads and sometimes sidewalks.
These tires would never see a gravel road.
I ride with both heavy loads with Jandd Expedition Panniers and fully unloaded.
I ride at a comfortable pace but I appreciate lower rolling resistance because sometimes I go very far.
Any other recommendations?
Should be fine, in fact more than fine, people rave about marathon tires. They are very puncture resistant, although it should be noted that punctures are still possible. I myself have had bad luck, both pairs I have purchased ended up with quite substantial punctures, the sort no tire would stop.
Quoted: 24 Post(s)
bicycle tourist
I've used Marathon Supreme, Marathon Mondial and Marathon Plus in my current ride through the Americas.
Some comparisons of my experience between these three subtypes:
- Supreme has a thinner sidewall and a smoother tread. Slightly lighter but still a heavy tire.
- Puncture proof is good, but seems slightly less than Marathon Plus.
- Two most recent rear tires lasted ~4000km each before I started to get problems. One got a larger hole in riding surface. I put a boot inside but then that started rubbing tubes in weird ways and causing flats. Second developed a split in the sidewall, perhaps with lower inflation.
For what you describe, Marathon Supreme is likely good and will be just a bit lighter than Plus or Mondial. If you were going off-road through areas with a lot of thorns, I would favor Marathon Plus instead.
I use 26x1.75, but only because the 1.5 (38mm) size needed levers to fit or remove the tire, I'm a little bit lazy The larger size was able to be fitted by hand. Your priorities are likely way different to mine, and I'm not too sure how my 26" experiences translate to the 700c sizes.
My wife and I both use the Marathon Plus on our touring bikes. Thousands of miles with hardly a flat. We change them with about 3,000 miles or so.
I ride with great confidence on the MP tires.
I have Marathon Supremes on three bikes in 26x2.0, 700x35 and 700x40. Great tires for touring and commuting. The 40s have enough volume for decent gravel riding comfort.
hey sid, I dont think you ever mentioned in the other thread how much you weigh, and how much to you "a heavy load" is--30, 50, 100lbs of load?
I could add more of my experiences with Supremes, but will wait until you give more info before chiming in more, as these numbers are a factor.
Quoted: 24 Post(s)
The bike the tires will be going on will never see a dirt road or gravel, it will be hard pavement only. I have another bike at my disposal for dirt and gravel.
I weight 211 right now, I wrestled 190 in college so weight is not out of line for me. Every once in awhile I have carried 100lbs on a bike but that is the exception rather than the rule. Sometimes the touring bikes have been treated like cargo bikes.
they are a good tire that roll along nicely, and are pretty good for puncture resistance, much better than I expected on a 2 month trip I did this year, but Im repeating myself.
I would add that I went with the 50mm ones out of concerns/unknowns about road surfaces, as well as wanting to be easier on my wheelset for my trip.
When I ride 1.5in regular marathons, they do roll along more efficiently than the 2 in supremes, so Im sure 1.6 supremes will be even more efficient than my marathons 1.5, but you have a whackload more weight on your bike and wheels than me....so this comes back to wondering if wider would be better for you.
but hey, if youve used 35-40s before with the same conditions, then at least you know how your wheels holds up,but then thats up to you to know what works and what doesnt with such a heavy weight on your bike if you go with a ton of load.
good luck with your decision.
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 312 Times
I would have thought those tyres are good for much more than3,000 miles, so how much tread is on the tyre when you replace it?
On only one occasion has a Schwalbe been destroyed. A metal object pierced the tire through both sidewalls at the rim. No idea how it happen but we were in an industrial part of Nashville. Otherwise I can only remember one other flat.
Quoted: 671 Post(s)
Liked 49 Times
Switched from Marathon Plus to Supreme which is wider yet lighter. Supreme rolls/handles better too; OTOH I'd guess med-heavy riders would want Plus durability.
Ozark Hillbilly
Bikes: Long Haul Trucker
Quoted: 136 Post(s)
In the 26" size, going from the Plus to Supreme will save about 2 pounds, 1 pound per tire. The Plus is a very heavy tire.
that was one of the appeals to me with trying a set of supremes. A friend with the same bike has plus's on, slightly heavier wheelset, and slightly heavier components and his bike is at least 5lbs heavier than mine.
Bikes: Surly Disc Trucker, Ribble Nero Corsa, Surly Karate Monkey, Surly Ice Cream Truck, Cannondale MT800, Evil Insurgent
Quoted: 186 Post(s)
I just finished a 215k Brevet on the 26x1.5 Supremes. They are great tires. I haven't found anything else in a similar size that is worth looking at so it's all I have run on my 26" bike. If I were you, I'd choose size based on how much climbing you intend to do and how much weight you're going to carry. 40mm for heavier/flatter, 35mm for lighter/steeper terrain. If you can't decide, go 40mm.
Quoted: 671 Post(s)
Liked 49 Times
My favorite thing about 50 mm Supremes vs 38 mm Plus is not the weight-saving but the far safer handling on fast bumpy descents. 50 mm Supremes swallow up road imperfections that caused alarming bounce with narrower higher-pressure tires.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Aye. Mine are the 50mm, and I consider them to be the perfect choice for my area. My local roads are narrow and typically in poor condition. Its just one thing you have to live with in a tax-free state.
My last Marathon Supreme lasted about 4000km before developing a gash in the sidewall. I was in the middle of a tour and replaced it with a cheap Giant tire.
The Left Coast, USA
I've used both the 26 x 2.00 and 700 x 35 Supremes. I have been riding the 26" for many years, on my third set.
I did not adjust well to the 700s on a fast tourer, sold them on eBay. My experience with the 700s Supremes was they were remarkably slow and prone to flatting, I think you could do better.
