Windsor Carrera Special?
Quoted: 195 Post(s)
Liked 207 Times
Bought this for $100. I've always loved the lugs and this one looked a step above the Carrera Sport I've seen from time to time. I've looked through the catalogs and the closest comparison was a Carrera Special. The lugs look bad especially on the drive side but nothing is frozen and the rims have a small hook and high pressure tires. I haven't touched it since buying it but I suspect it'll look great when rebuilt. With the lack of safety levers, centerpull brakes and bar ends I'm a little confused on the model. Obviously it's no Pro or Comp and it maybe just be a late 70'sCarrera Sport but hopefully
there are some Windsor experts out there that wouldn't mind sharing their knowledge.
Likes For Cycle Tourist:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
wow, man. super nice find!! look forward to seeing it cleaned up and refurb'd
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,062 Times
guessing with the components and SunTout GS dropouts it could just be a later edition: any date codes on any of the components? The Calif. bike license date that's visible is 1981.
Quoted: 3813 Post(s)
Liked 3,344 Times
Hello Cycle_Tourist,
suspect this may be a model from ~1974
here is a mfr catalogue page for the Carrera of the early 1970's (~1971) -
here is mfr. catalogue page showing the Super Carrera & and Carrera Special of 1978 -
you should be able to locate date code markings on the cycle's components. here is a guide to the markings -
https://www.vintage-trek.com/component_dates.htm
suggest you first check backside of SR APEX crank arms and then check portion of handlebar stem which is down inside the steerer...
frame's fork crown is Agrati "BRIANZA" pattrern and is item nr. 000.8038
will be interested to hear if your shell is 68mm Italian thread or 68mm BSC thread & and if steerer & stem are .833" or 22.2mm
early steerer/stem size was the .833
Quoted: 195 Post(s)
Liked 207 Times
Date of Manufacture of Bicycle Components can be used to date a bike: component dating
The chrome looks great. Not sure what to do about the paint though. Normally I'd just do a touch up but there's a lot of coverage. I'll clean it up and make a decision. Maybe a little spray touch up. Thoughts?
Quoted: 195 Post(s)
Liked 207 Times
I discovered under the paint on the bb. (wct 78). It's a little strange to have '76 cranks in a '78 bike but possible I guess. It's definitely a "special" but decals are decidedly difficult to find. The Carrera Sport's easy but no Carrera Special. Plus the head and seat tube have a large W, not the WINDSOR decal. I'm probably being too picky. Maybe I should just skip the decals. Figuring out what you have is part of the fun.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Cararra Special and CarerraSport seem to be the same model.
As such, it's a heavy bike, but with Windsor-labeled alloy rims and very upright geometry, 74x74-degrees or thereabouts.
I found a black one being thrown out behind the bike shop, and rode it for a year or so before selling it. I would have kept it, but the seat tube bands were flaking off and at the time I favored a more relaxed geometry. I did somewhat regret selling it as it made for a lively ride up into the foothills.
Liked 3,344 Times
thank you for the additional image and for the latest update
find it interesting that even though it is upmarket from the Carrera Sport it yet exhibits the plate style chainstay bridge
my guess would be that the bridge is likely Agrati since the lugset and crown are from this producer
Agrati did a plate style chainstay bridge which looks identical to the ESGE at a glance
one difference is that the ESGE is marked and the Agrati is not
suspect frame identical to Sport and the difference is in the better kitting
great to see you are moving right along with it!
if you are discussing transfers then reckon you are planning on a respray...
shall look forward to the next update
Quoted: 195 Post(s)
Liked 207 Times
The plate did keep the kickstand from damaging the stays so there's that. While working on the frame I saw a "Carrera Sport" logo on the top tube. The chief difference between the plain jane and the special is the lack of extension levers and the nifty cranks. You are correct. I'm going for a respray. The paints flaky and the decals are barely legible anyway. I touched up the seat lug with a file and sandpaper as it was awfully rough and unfinished and I have some red paint left over from the Super Course Mk II.
While the primer is drying I'm cleaning up the components. Everything is remarkably smoth. Even the adjustment screws in the rear dropout are finger tight. One of the screws snapped on the front derailleur clamp but I overcame that. It's about 28 lbs so it's no lightweight but it's not bad. I'll only fill my water bottle half way! 😜
Liked 3,344 Times
thanks very much for the update!
excellent to see that you now have her well sorted.
fine work
forgot to ask earlier regarding your example's pedals; they look like they may be KKT Top Run
owned a Carrera Sport model from the '73-'74 time which came through with KKT RTSF
your bicycle's chainset, pedals and saddle pillar are upgrades over the Carrera Sport of the early '70's
it's pillar was plain steel
minor tip on rear mech -
Maeda mounting instructions for their rear mechs recommend to adjust the angle screw such that the slant pantograph is parallel to the chainstay for optimal shifting performance
fine work
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
BTW, a very nice score for 100.00, I am not sure that I would spray paint it because it will never be a match, I would repaint the whole frame....clean and wax may be the way to go.
Best, Ben
Edit...I see you did the repaint, looks great!
Voltaire
Voltaire
Quoted: 195 Post(s)
Liked 207 Times
fine work
fine work
Liked 3,344 Times
thanks for the response
in looking at the catalogue page for the two then current 1978 Carrera variants was surprised to read the saddle pillar specification of "Windsor steel" for the Carrera Special model while the Super Carrera is specified with "Windsor alloy"
the combination of a too-short stem and the handlebar end controls can create a problem for some riders of hitting their knees on the shifters when pedaling out of the saddle; probably smart to put a stem of a good extension for you on there...
if you do encounter the knee symptom it can be solved by trimming the bar's trail
mfr's 1978 catalogue page -
