For the love of English 3 speeds...
Quoted: 938 Post(s)
Liked 2,941 Times
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
The All British Cycle Event (ABCE) is this weekend. Gather at Merlin's Rest (Minneapolis) tomorrom morning at 9:AM.
Sunday is the swap meet, Gravity Race and Show and Lie
I plan to bring my '54 Bates, '61 Sports, a nice cheap Superbe anda bunch of parts...
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Barred @ Velocipedesalon
"no date code" sturmey-archer "aw" hub
After some more research and getting advice and insight from BF members, l have determined the year of my "AW" hub. Although some early S-A hubs were without a date code stamped on them, there are a few from the 40's and 50's that were also sans date codes. My particular hub is clearly stamped with "AW", but no date. This model was made only during WW2, 1941-42, and is identifiable by the left side "ball cup" having a factory black painted finish (ensure that it has factory paint, looks almost anodized), the patina will be obvious. Also, it will have a threaded on drive sprocket, not splined! Apparently, there is another group of hubs from the 50's without a date code, but having a silver finish on left cup with a splined sprocket mount. My hub is on a Raleigh Sports Tourist having a serial number (J26399) interpolated to be from 1930-1933, so it is not original to the frame if the frame is indeed from the 30's. If anyone has a 1941-1942 bike with a similar hub I would be interested to know for further confirmation.
I am also still trying to confirm the year(s) of manufacture for the "DYNOHUB" on the same bike. I have yet to see an example of this front hub. If someone has this hub original to their frame, I again would be interested in order to determine my hub's vintage. My hub has no markings in the center portion where the terminal lugs protrude. Markings appear on the "middle" ring, which appears to have been factory painted silver with a black band incorporating silver print and "diamonds". The main hub "shell" is chrome finish with "32" (spoke count) stamped on the left side.
One terminal lug post is broken. Is this repairable? I have not yet dismantled to determine the viability of repairing the hub.
Thanks again for all the help and advice.
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 469 Times
Quoted: 1299 Post(s)
Liked 103 Times
Inflate Hard
Inflate Hard
If you go back a page and check out the 1940 catalog page I posted you'll see an image of the Dynohub in the lower left corner. It matches yours exactly. I never noticed the difference before. So all I can say with certainty is that sometime between 1940 and 1951, they redesigned it. I don't know how to deal with the broken pole. You are not supposed to remove the magnet so there's no way to get at it from behind. Maybe it could be drilled and tapped from the front. Splined cogs on AW hubs started around 1952-3. My 51 has a threaded driver. There's a good rebuild video on youtube for Dynohubs.
https://www.youtube.com/watch?v=2SnEkpU0YeU
Taking a quick look at the men's frame shows it to be a different model; fenders are different, head tube lugs are not "fishtail" cut-out, "bolt-on" seatstays, serial # AD99185, but another no date "AW" hub, no front "dyno". Photos forthcoming.
Liked 103 Times
Thanks again for your help Big Chief, I had not taken a close look at that image of the hub, nor is my viewing device very good for seeing details; not good for taking photos either as apparent by my previous posts. It could very well be that both wheels assy's were replaced at the same time and are of the same vintage. I would still like to see a photo image if someone has one referenced to a known frame/year.
Inflate Hard
Inflate Hard
Quoted: 331 Post(s)
Liked 332 Times
SA hubs in 1933,34 and 35? had no date stamps. Before that they were stamped K. The AW- 3 was introduced in 1936. K went back to before WW1 and up until 1914 they were stamped with an X. It is unlikely (but not impossible) that the hub is older than the frame as frames go forever but hubs require some care to keep going for 80 years. I found the Raleigh frame serial # archive very accurate. Sunbeam as well. Rudge is completely useless but the pictorial catalogue for Rudge is probably the best.
Quoted: 331 Post(s)
Liked 332 Times
Quoted: 1857 Post(s)
Liked 664 Times
Why can’t the AW handle bigger tooth counts? Does this limitation also apply to the FM, FG, and FW?
Quoted: 457 Post(s)
Liked 462 Times
I have a Sprite w/ the 5 speed hub.
I added the double throttle shifters.
I find if the bike sits for awhile w/ both shifters on the "off" position,
i.e both forward, the secondary shifter will not engage easily.
The bike now rests with the primary "off" i.e. in third and the secondary
shifter engaged.
Seems to keep the hub freed up.
shifter engaged.
I can certainly appreciate the stock equipment, but I do much prefer the trigger shifters for functionality. I'm going to go full resto-mod on my sprite build so there will be many parts that are not stock when I'm done, so not having the stock shifters is fine with me.
Quoted: 331 Post(s)
Liked 332 Times
The AW 9 (9 = 1939) are screw on sprocket, so any size is possible. On my 1903 Sunbeam I put on a SA 4 speed, a 3 speed freewheel, a Resilion derailleur and the original 2 speed direct dive. All up 24 speed.
Quoted: 457 Post(s)
Liked 462 Times
Sturmey recommends no lower than a 2:1 ratio, 48/24, but sheldon brown talks about using cassette cogs larger than 24 to get lower gearing. I'm sure you can go lower than 2:1 if you are a lighter guy, I'd bet you can go way lower than 2:1 if you just avoid standing and pedaling in 1st gear on steep hills.
Quoted: 331 Post(s)
Liked 332 Times
shifter engaged.
shifter engaged.
Quoted: 331 Post(s)
Liked 332 Times
112 geared SA
Quoted: 3810 Post(s)
Liked 6,699 Times
I haven't quite gone that over the top, but I did confirm that a 5-speed freewheel fits fine on a threaded driver with a 6 1/4" axle (the longer one to fit in a 120mm-spaced rear end). Didn't see the need to put that in actual use, however.
Quoted: 331 Post(s)
Liked 332 Times
15 speed works in East Anglia
Liked 443 Times
Six Speed Conversion Sh*t Show
What I thought would be a simple project has
been somewhat frustrating but there is a light
at the end of the tunnel....
I set the bike up yesterday and bought a 3/32" 10 speed chain assuming the 1/2" pitch
would be compatible.
It wasn't.
It binds on the chain ring and refused to engage the smaller cog..
I'd had enough and let it be.
Today I added a couple of washers to the derailleur rollers to expand
the width to accept a standard 1/8" chain.
All seemed good.
Until I installed the master link which now
catches on the derailleur cage
I'm not dissuaded. The 3/32" chain was only $15.00 and the
1/8" chain was cobbled together from a couple I had lying around.
Tomorrow's another day......
It wasn't.
All seemed good.
Quoted: 380 Post(s)
Liked 106 Times
If you use to low of gears on a SA AW you can put more power input into the hub than the 4 small planetary gears inside the hub can handle and they break in half. As some one like me who grew up riding 3 speed in the 1960s I got good at replacing them. Roger
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 852 Times
Phillips, Schwinn, and Raleigh 3-speeds.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Likes For SirMike1983:
Liked 103 Times
It wasn't.
All seemed good.
It wasn't.
All seemed good.
Inflate Hard
Inflate Hard
Liked 443 Times
I've done it before....
