Hydraulic brakes, and flying.
Mid Tour!
Bikes: Marin Muirwoods Racked out for this years Tour, Norco Indi 4 racked out from last years tour, Giant Defi II for week-end ripps.
Quoted: 152 Post(s)
Is there a disadvantage to hydraulic brakes when preparing to fly with your tour bike? As in draining the fluids etc?
Thank-you in advance,
-Snuts-
-Snuts-
Mid Tour!
Quoted: 152 Post(s)
Mid Tour!
Quoted: 152 Post(s)
2) Modern disc brake systems should be well-sealed, and not have enough air to matter.
Mountain bikers fly all the time, I've never heard anyone mentioning needing to do a full drain & fill. All disc brakes sets are sold fully filled and bled, and are routinely shipped via air freight.
Ignore the airline, deflate your tires to less than half the max pressure.
Mid Tour!
Quoted: 152 Post(s)
No, but I was seeking those that have flown a bike with hydraulic brakes. As at the end of my tour I may be flying with this bike.
Alan, have you flown a bike with hydraulic brakes? Where there problems encountered with your reservoirs?
-Snuts-
-Snuts-
I have flown with hydros many times. No issues whatsoever. Never heard of anyone having issues. If you find something, please post it up here.
Mid Tour!
Quoted: 152 Post(s)
Quoted: 941 Post(s)
Liked 319 Times
As far as I know cargo holds are pressurized. How do you suppose those pets of passengers survive as well shaving cream. They may have other rationale for the request, but a lack of pressure in the hold is not one of them.
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
The whole point to hydraulic fluid is that it does not expand (or contract) as the pressure, or force, acting on it changes. Even if the cargo compartment were not pressurized, it would have no effect on properly filled hydraulic systems.
Mid Tour!
Quoted: 152 Post(s)
Thank-you, I will be ignoring that point. The only con for not using hydraulic discs on a touring bike in my opinion. I have developed quite an attachment towards hydraulic brakes on a loaded touring bike.
-Snuts-
Mid Tour!
Quoted: 152 Post(s)
Thank-you.
-Snuts-
Even the idea of deflating tires is somewhat half baked. Atmospheric pressure is roughly 1 Bar. If the plane flew in a vacuum the effective pressure on tires would be 1 bar higher than at ground level, an increase which any tire should be able to handle.
Quoted: 5793 Post(s)
Liked 2,584 Times
The airplane is a cylindrical pressure vessel, basically a light weight air tank. If there were a difference in pressure above and below the cabin floor, it wold buckle. Plus it would require that the floor is hermetically sealed o keep cabin pressure from venting down into the hold. So, think, one big air tank, that happens to have a floor stretching across the middle.
BTW - the above was proven in a a very unfortunate event when a cargo door failed, causing the cabin pressure to buckle the floor, leading to a crash.
As to hydraulic lines. If their bled properly there's no air inside to expand and push fluid out. Plus the total volume of fluid is too small to be of concern anyway, so don't sweat this bit of nonsense, and don't go out of your way to tell anyone you have hydraulics on the bike.
FB
Chain-L site
FB
Chain-L site
Bikes: Custom built LHT & Troll
Quoted: 846 Post(s)
Liked 149 Times
The problem is that even if the request makes no practical sense, you may have to deal with personnel that will stick to the letter of the regulation. Deflating tires makes no sense whatsoever, but it is a losing argument.
I would think that draining brake fluid may have more to do with the fact that at least some brake fluids are combustible, which is a definite no-no on a plane.
hydros have leaked on other bags. Get it, they do not want leaking fluids. The fat lady made them pay $250 to replace her sweater. She did that by screaming for 10 hours. the Chicago police could not lift the fat lady and remove her. Some airports want the brakes removed from the bike and put in a sealed container, plastic bag. I have seen a guy with a igh asked to wrap his wheel in plastic and a towel. It makes perfect sence to deflate your tires. Tires have poped at low preasure before. What a scare, loud boom, no one knows what it is. Plane had to land at wrong airport, people were 11 hours late, because some cranky old guy did not want to deflate his tires.
safety first
If you are unable to pump up a tire, why are you flying with a bike.
Learn to fix and remove, replace, your brakes before you go on tour.
safety first
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
It is worth noting the policy doesn't say exactly that
The way I am reading it, the requirement is to pack the bicycle in a box or bag, the justification for the rule is to prevent bike damage or potential leakage. In general, they look like they have fairly favorable bike policies.
Thanks for bringing this up though, I've gotta deal with this later this year, it never even crossed my mind!
Originally Posted by https://www.westjet.com/en-ca/travel-info/baggage/sports
WestJet may refuse carriage of improperly packaged bicycles. A bicycle must be packed flat in a bicycle bag or box. Before flying with your bike, please:
Remove pedals.
Partially deflate your tires.
Fix handlebars sideways.
Pack the bicycle in a box or bag to protect your bike and prevent leakage from bicycles containing hydraulic fluid.
Remove pedals.
Crawler
Quoted: 1074 Post(s)
Liked 295 Times
As long as there are fluids, leaks are possible. Forks and shocks can leak too. Probably more oil in a fork than a brake.
If your bike is shipped wheels off, forgetting to add the pad spacer is a far more common cause of problems.
Liked 2,584 Times
Stupid question for the OP.
Why are you asking NOW. From what I gather from another of your posts, you're already on the road, so it's kind of late to be wondering whether Hydros makes sense for this trip.
Since you're on the road, focus on enjoying the trip and leave the worrying about bleeding the brakes for when it becomes one.
FB
Chain-L site
FB
Chain-L site
Mid Tour!
Quoted: 152 Post(s)
Hey, you be nice.
Has this been asked before?
(only stupid question)
Things I think about when riding. More so, I have been thinking about another thread where the poster is thinking of changing out his hydraulic brakes to mechanical. I love mine, and was wondering if this could be the only real draw back from my experience, and application.
I have no problems doing any mechanical work on my bike to keep it going, or prep for flight should I opt for that.
Well boy's and girls, -Snuts- is about to launch towards Sault St Marie.
-Snuts-
-Snuts-
Likes For Snuts:
