Elevation gain software or add on for Google Maps
Quoted: 54 Post(s)
Hello all,
Does anyone have a suggestion to get an "elevation gain" on a route using either gmap or Google Maps? I don't know if these two apps have this option that I'm not turning on or what. I see the option to turn on "elevation" small and large, but that's not what I'm asking for. If there's nothing with these two apps, do you have something you would like to recommend? I would prefer something free and I don't have to install if at all possible. I'll consider anything.
Thanks for reading this and I would appreciate any and all responses.
References,
https://www.gmap-pedometer.com/
https://maps.google.com/
References,
Bikes: Gunnar Crosshairs, Giant Trance, Felt Breed, Marin SS MTB, Felt Pyre BMX bike, oldschool GT trials bike
https://mapmyride.com will also give you elevation gained although I do question its accuracy at times.
Quoted: 54 Post(s)
I tried mapmyride.com and it gives pretty much what the Google maps gives. Actually it's not as good as Google maps, unless I'm not turning something on? I see the option for "elevation", but that's about it. Again, I'm interested in "elevation gain". The other sites are abit of a learning curve on them and in the end I don't know if I'll get what I want or not. And no I don't want to ride the route to get it documented and annualized.
I know for a fact that MapMyRide, BikeRouteToaster, and RideWithGPS will give you the information you want... MapMyRide gives elevation gain on the route summary screens which you can see after saving a route.
sniffin' glue
Bikes: Surly crosscheck ssfg, Custom vintage french racing bike, Bruce Gordon Rock & Road
google cue sheet
https://winthefight.org/cuegle/
very very easy to use....i like it and use it all the time. Don't have to install anything, it is just a link. Create your google map then click on the bookmark. The link above explains how to use it.
Professional Fuss-Budget
I prefer ridewithgps.com -- even ponied up for a subscription.
Free works ok, paid gets you some nice stuff like vastly improved cue sheets.
Quoted: 54 Post(s)
ridewithgps.com looks pretty sweet!!! I signed up with a free acc and I'll bump it up if and when needed.
Thank you all for responding. The others might have worked too, but I'm just not that savvy at this new modern high tech world we have in our midst, but your help is well appreciated.
Fred-ish
google cue sheet
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Here's part of my comment from another thread. Another BF member was deciding about doing a century ride with a big climb. How hard would the climb be?
ridewithgps is really great for getting detailed info on climbs. And, when drawing a route, it's really easy to undo some sections of a route and try an alternate route. Then, when the route is finished, give it a name and save it. Now you can get statistics on individual climbs by selecting that part of the route.
...pasted here from the other thread...
Here's the main part of the climb on ridewithgps. (the lower part is mostly a shallow grade). Even ridewithgps might be off a little on the switchbacks, since they are trying to determine the exact elevation of the road using known elevation points on the mountain slope near the road.
At the top right, pull down the map list and checkmark the Terrain option. Hover your cursor over the elevation graph and see the grade at that spot.
At the 3 mile mark on the graph, drag and highlight from there to the end. Then click the Metrics tab at the right. It shows that part is 1.9 miles at 6.5% and 560 feet. The switchbacks average 8% for a half mile and 175 feet.
Anyway, it's 1200 feet in 5 miles, about three of your usual local climbs. It has some steep spots, but also some shallow grade recovery sections. With your gearing, you can just sit and spin up the steep parts--perfect. There should be some great views along this whole climb.
If you can find a short 10% grade at home, test your gears on it.
Here's the full 10 miles from St Charles. 1670 feet total climbing. It looks like the lower sections have some very small hills mixed with flatter sections.
Quoted: 163 Post(s)
google cue sheet
Bikes: Tour Easy, Linear USS, Lightening Thunderbolt, custom DF, Raleigh hybrid, Felt time trial
sniffin' glue
Bikes: Gunnar Roadie, Gunnar Sport, Surly LHT, Gary Fisher Genesis
google cue sheet
