No Rim Tape- What to do in a pinch
Quoted: 30 Post(s)
So I royally messed up my rim tape changing a tire and am a few miles from the nearest bike shop... could I temp use electrical tape?
Quoted: 5791 Post(s)
Liked 2,581 Times
Electrical tape lacks the strength of a reinforced tape and will, blow through at higher pressures or when it gets hot outside. But just about any reinforced tape will do, including cloth surgical tape, reinforced packing tape, and so on.
FB
Chain-L site
FB
Chain-L site
Bikes: Trek 7.4 FX (2015), Trek 1500 SLR (2005)
Do you have a sporting goods store nearby? You could try some tennis racket tape.
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
I've used a double layer in a pinch, I had meant to swap it out later but had forgotten until I had to change the tube two years later. I do agree though that I wouldn't trust it, I could see quite a few spots where the spoke nipples had almost broken through.
Quoted: 659 Post(s)
Liked 7 Times
Similar experience here. Used a double layer of electrical tape. Worked ok, but after only two decades and about 100,000 miles one of the spoke holes wore through and caused a flat. Of course by then the rim's brake surface was almost worn through so it was ready for replacement. (Road bike with tires pumped up to about 110 psi.)
screw campy & shimano
I use excess strapping that I've cut from (too long) tie-downs, with a small piece of duct tape to hold the two ends, plus some tape sticky-rim-side down to keep the strap from sliding around during mounting.
Well, OK, this is more than an "in-a-pinch" solution. For me, it's a replacement for rim tape.
Not quite there yet
Bikes: A bunch of old steel bikes + an ICE trike
A few wraps of electrical tape? Sure thing. It will get you home and many miles beyond. I used to use glass reinforced strapping tape routinely for all rims. Functionally it works great, doesn't cost much, and lasts a long time. Nowadays I have more money to spend so I have been using Newbaum's rim tape and recommend it highly when you want to replace the electrical tape
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
Plastic banding material, very easy to find in the dumpster of almost any business that receives palletized freight.
Really?
Another second world problem that would be easily solved with a simple forum/Google search.
You haven't listed your location. One could only assume that you are far enough from Alabama not to instinctively know that duct tape (AKA Alabama Chrome) would be an effective, albeit temp, cure to your dilemma.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
NOT electrical tape. I think first aid tape would be excellent - probably about as good as proper rim tape. Duck tape, well, maybe. In a pinch, for a while. The better grades like gaffer tape or Gorilla tape are probably good. The cheap stuff is garbage. If you live up north and have hockey tape, that'd be perfect.
I'd get them out of there ASAP though - the adhesive turns to gooey soup in a few weeks, especially if they get wet.
Electrical tape will probably work OK if your pressures are not too high (say < 50 PSI).
For that matter, at low pressures the cheap bikes use a rubber strip - if you have an old tube you could use that.
Work: the 8 hours that separates bike rides.
Doesn't work... Need something with non-stretchable reinforcement. Strapping tape might work.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Quoted: 18378 Post(s)
Liked 4,512 Times
What happened to the old tape?
Perhaps use it as a base layer and run electrical tape over the top.
I now have a roll of electrical tape in my seat bag. It comes in handy for many things.
a single wall rim has different requirements, than a double wall rim, and of course the OP fails to say which kind they have.
rim tape is used on only one of these types of rims...
Bikes: sport touring with small front back baskets. 17 mph
i have been through this many times heres the thrifty method that works! clean inside of rim of oil and grease let dry put 1 layer of vinyl electric tape (the cheap stuff) next a layer of medical cloth tape the plastic kind (looks like thin rim tape).
Call your mommy to give you a ride to the bike shop............be sure to take a roll of duct tape in case a water hose blows out and you're a mile from town.
Biking------requires a bit of common sense with a touch of "McGyver" on occasion. Without some of each you'd best stick to riding the ankle express.
Bikes: 96 gary fisher 'utopia' : 99 Softride 'Norwester'(for sale), 1972 Raleigh Twenty. Surly 1x1 converted to 1x8, 96 Turner Burner
Quoted: 9 Post(s)
in a pinch I would use an old inner tube. That's one reason you don't throw them away.
Quoted: 4227 Post(s)
Liked 2,488 Times
I use hockey tape, it makes a perfect rim tape.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
That, and wrapping handlebars. I use a layer of old innertube underneath regular bar tape, and I don't need padded gloves.
Wait, arbitrary length? I can see small ones just by slicing the tube, or super-large ones by going all the way around, but what about in-between? Oh, I guess you can use more and more "diagonal" slices to increase the length rather arbitrarily (up to maybe even many times around the whole tube?) And what about smaller ones? I guess you can cut out a disc of any size, and then cut its insides out to make it a band. Very clever.
CliffordK
Bicycle Mechanics
24
04-26-19 06:41 PM
Barrettscv
Bicycle Mechanics
57
11-02-13 04:02 PM
