Explain Like I'm 5: Don't I need a compression plug to oppose the stem bolt forces?
Should Be More Popular
Quoted: 22599 Post(s)
Liked 8,926 Times
My understanding is that star nuts are ok for metal/alloy steerer tubes but no bueno for crabon fiber steerer tubes. Again, I believe this is "conventional wisdom" but have zero "proof." It does make sense because a star nut would possibly cut into carbon while the expansion plug won't.
Liked 8,926 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
If I did that the answer would be something like I'm sure that your father has taken care of that.
Bikes: Shmikes
Quoted: 10171 Post(s)
Liked 5,867 Times
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
I'm guessing a crabon tube that maybe needs a compression plug is heavier than an alooooominum tube with a star nut.
For years I ran a MTB without a top cap or star nut because the steerer tube was stuffed with lighting electronics. Yes, it is perfectly safe, but not idiot proof so maybe the 41 shouldn't go there.
Quoted: 942 Post(s)
Liked 527 Times
No the top cap does not sit flush on top of the steerer. In the video you posted the guy is talking about compression plugs which have a lip that sits on top of the steerer. The cap needs 2-3mm of space to compress the headset to spec. He was just demonstrating how the compression fitting can expand the steerer. He just happened to have the top cap attached in the demo. If it were on the bike there would be 2-3mm of space in order to adjust the headset.
Quoted: 1975 Post(s)
Liked 232 Times
What happened?
Liked 292 Times
As an example, having used computers since TRS-80, I'd say probably.
Likes For Rollfast:
Quoted: 4717 Post(s)
Liked 1,882 Times
The guy that made the video is wanker. He knows what he’s talking about, but he’s marketing a product that he created, to help prevent an issue that isn’t really an issue.
Quoted: 551 Post(s)
Liked 722 Times
I especially like how he totally glossed over the importance of getting the top bolt tension correct.
What happened?
Liked 292 Times
I just hope that's only his ID. Sounds a bit cruel to him.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Quoted: 1248 Post(s)
Liked 1,323 Times
Regarding the need for a compression plug to support the steerer tube. I owned a Colnago C59 which used a wedge type headset which eliminated the need for a top cap to set the preload. Just mounted the stem a flush as possible and the set preload at the headset.
Quoted: 1529 Post(s)
Liked 718 Times
FWIW, none of my carbon steerers poke out of the stem, but I ensure my compression plugs are a good design and are set up properly, and the bottom bolt on my stems is tighter than the top. Seems prudent to remember we're dealing with fibre reinforced plastic...
Funny how this guy says that many manufacturer did not engineer well their factory compression plugs & finds flaws in them (IE, says that Giant should have opted for a straight plug instead). I mean, if the damn product was developed and engineered in a specific way (including shape), I'm confident it's pretty much doing what it should be doing.
That one's utter crap, and there are worse than that.
I guess the risk of your stem popping off your carbon steerer must be pretty minimal if Darwin has allowed these poxy units to continue to be a thing... I like to sail pretty close to the wind, but this is a risk I'm going to mitigate, albeit to less of an extent than the accepted wisdom.
climber has-been
Liked 3,567 Times
There isn't. Stop perpetuating a myth.
Liked 718 Times
Some are so bad they struggle to grip enough to preload the bearings, let alone support the steerer internally (the necessity of which is apparently a matter of controversy), others don't stand a chance of performing the latter despite managing the former, and the one pictured above manages to introduce a new degree of crapness by trying to be clever and integrating the top cap, which turns against the stem as you're preloading the headset, which is plain nasty, and makes it a fiddly hassle for no good reason. The rest of its design is equally nasty.
It's crap, and if you insist on disagreeing, I submit that you lack the discernment to perceive that.
climber has-been
Liked 3,567 Times
I can read a drawing, and there appears to be nothing wrong with the design depicted in the drawing. It looks like so many other designs from so many other manufacturers.
Point to the place in the drawing that shows the claimed design flaw in this compression plug that prevents it from providing a bearing pre-load.
Liked 718 Times
I never said this plug in particular couldn't do that; I said it was crap in its own special way - if you can read a drawing you might be able to see the problem. Unlike plugs from other companies, the top cap is the tension bolt, which in practice, sucks.
Also, from memory, the tapers are a bad angle and it needs to be lubed (something I always do but is otherwise rare) to work at all, and the short length that bears on the inside of the steerer is badly placed; too low IIRC.
I'm reminded of a whole bunch of undercooked me-too internal cable routing in frames that I've come across, which only passed muster because you can't see it. The assumption that a big company employing qualified engineers will necessarily make parts that a bloke on the street couldn't find problems with, is false.
Whether compression plugs have one job that matters or two is a matter of debate. Whether some are absolute crap shouldn't be. I've even seen a rubber sandwich!
