Alternatives to an air compressor to seat tubeless tyres
Quoted: 800 Post(s)
Liked 512 Times
I do not own an air compressor and would rather not have to purchase one for the couple times a year I need to seat a tubeless tyre. Recently I used a CO2 cartridge and that worked well, but it seems kind of wasteful. If there's an affordable alternative out there, maybe one better for the environment, please let me know.
Then again, maybe for the couple times a year I might need to seat a tyre, CO2 is the way to go. Thanks.
You can buy a tank and inflate it at a gas station or using a bicycle pump
https://www.harborfreight.com/air-to...ank-65594.html
Quoted: 20810 Post(s)
Liked 9,456 Times
You can either get a separate canister to charge with your existing pump or you can buy a new pump with one already integrated. (I have the separate canister from Specialized and don't recommend it, btw - it works about 50% which just isn't good enough. I hear that the Bontrager pump/charger works really well, though)
Quoted: 389 Post(s)
Liked 255 Times
Never tried this with a bicycle tire, so no idea if it might work. When I worked in a tire shop many years ago we would wrap a band around the center of the tread and cinch it up to force the beads out to the rim. Worked for car tubeless.
The compressor is worth it. I paid less for a compressor than I would have for one of those special pumps with a tank.
Liked 9,456 Times
The pumps aren't without their advantages, though - they take up less space (they take up no space if you have a combined unit - you need a track pump, regardless), don't require electricity and they're far more portable. That portability is nice even if you're working on your bike around the house, but the ability to throw it in the car for remote rides is nice, too.
Don't Bug Me
I haven’t had to replace a tubeless tire yet but I have been thinking about this. Would a wrap or two of masking tape around the circumference of the tire work to expand the bead out enough to seal and inflate the tire with a floor pump? Has anyone tried anything like this?
Liked 9,456 Times
The other factor with a home brew method is the pain-in-the-ass quotient. Jiggering something a time or two is one thing, but you'll soon want a smoother, easier, more reliable workflow.
Quoted: 479 Post(s)
Liked 277 Times
I have a 33 gallon compressor and several attachments - the tire chuck, etc. The blow gun works the best - especially with a bit of tape a the tip to better seal in the valve. But - from my experience seating road, gravel and MTB tires - the tubeless inflaters/pumps work better. The key isn't volume and/or pressure. It's speed. You don't need those 33 gallons or the 160 psi. You need just need a fast hit. Those pumps do that better.
https://enduro-mtb.com/en/the-best-t...flator-system/
Bikes: Shmikes
Quoted: 10171 Post(s)
Liked 5,867 Times
I have a Topeak reservoir pump, which works beautifully with a good tire-rim combination. Without that it's a real pain in the triceps and I have had to resort to various means of squashing the tire down, but always got it mounted eventually. A compressor with a small tank would have the same problem, I guess.
Non omnino gravis
While I am a 100% advocate for compressors, and don't understand how people go through life without owning one, the "soda bottle hack" linked by @bluehills3149 is certainly the cheapest, 100% works, and is the best answer to the OP's question.
Liked 9,456 Times
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Quoted: 479 Post(s)
Liked 277 Times
Don't get me wrong, the compressor does work. I just think the inflator pumps do a better job.
Non omnino gravis
I cannot under any circumstances see a reservoir pump outperform a shop compressor at seating a tire. A brass Presta adapter threads right into the tip of a typical blowgun-- I seat my tires in about a second, with just the pressure of one thumb. I haven't pushed a pump handle down in years (when I travel somewhere, there's a Ryobi 18V Cordless Inflator in the car.)
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
If you have the space, buy a compressor. It cheap and works every time.
Likes For redlude97:
Liked 9,456 Times
Likes For noodle soup:
Liked 9,456 Times
This is the cheapest easiest solution out there. I use it to seat all my tubeless tires
https://youtu.be/bxNWiLQKxOs
