CO2 For Road Bikes
CO2 For Road Bikes
I have never used CO2 Cartridges before. But I understand compared to a pump. I can fill a high pressure tire to 110psi quickly?
How reliable do you all consider them ? Are you confident to just carry a CO2 with you vs a small tire pump if you do a get a flat a long way from home?
What Co2 devices do you recommend most? One that could control the Co2 when filling etc? thanks
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
They are very reliable. It's the operator who screws up the inflation about half the time. If you go that route, practice! I no longer carry them.
Likes For MoAlpha:
Quoted: 2952 Post(s)
Liked 3,106 Times
They're very reliable, if you use them correctly. They are part of my belt and suspenders approach: I carry a CO2 cartridge and a mini pump, a spare tube and a patch kit. First flat gets a new tube and CO2. I can be back on the road in under five minutes. Second (and subsequent) flats get a patch and the pump. (It happens sometimes.)
Likes For caloso:
Bikes: Giant TCR Advanced Pro 0 Disc
Quoted: 105 Post(s)
Liked 69 Times
I don't think you can get to 110psi with a CO2 cartridge, I mean I never have. It's just a temporary solution.
Grab an inflator and learn how to use it properly without wasting precious CO2 air. Everyone has their own fav but I like Giant Control Blast 1 type inflators. I never learned how to operate the kind that releases air as you turn the valve.
Caloso's approach is a wise one tho I don't like the idea of carrying a pump and all. I carry two spare tubes + two cartridges and my final option is taking Uber to the closest shop or home.
I would carry a tire boot too if you get a sidewall cut or something.
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
For road-side tire inflation needs, I haven't carried a pump in decades. My back-pocket tool kit includes one CO2 cartridge and an adapter. If I get in trouble after that, I have a cell phone. On longer rides in more remote areas, I might add another cartridge or 2 to my payload. Filling up a typical 25mm road tire, I don't worry about regulating how much CO2 I'm putting in. It's one cartridge, all-in, and then pull it off quickly so I minimize any losses.
Super Modest
Quoted: 10963 Post(s)
Liked 4,621 Times
I've used CO2 for years and have never borrowed a pump. I guess I must be CO2 proficient.
Keep the chain tight!
Likes For Trsnrtr:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I carry 1 cartridge, a small pump on the frame (Cannondale Airspeed LX), a tube and patches. I usually carry a tire boot also. Unless I head east toward the beach, I ride in mostly rural areas. I really do not have someone that I can call and be sure that he/she can come and get me. Also, cell phone coverage is quite spotty in south coastal Delaware. I have only used the boot once. I probably change tires a bit sooner than really necessary, but most of the flats I get occur with tires that have a fair amount of miles on them. I have no interest in going tubeless.
Fixing flats out on the road gets easier and quicker with practice. In almost 50 years of road riding, I am sure I have called someone to come and get me no more than a half dozen times.
Quoted: 645 Post(s)
Liked 797 Times
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Why would anyone want 110PSI??
In any case CO2 does work ok but you need to practice the technique in your garage. Unless you are in a hurry (like a group ride or triathlon/race) I think it makes more sense to use a small pump.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Likes For Sy Reene:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Quoted: 6196 Post(s)
Liked 4,811 Times
I admire your determination to separate conversations to a very specific point, but this might be going too far.
Tire Pump - To Carry On Rides
My answer for this thread is pretty much the same as in the other thread.
Quoted: 1461 Post(s)
Liked 1,486 Times
CO2 works fine. I've never had a problem inflating a tire with it on the side of the road. One 16g cartridge is enough to inflate a road tire to an acceptable pressure to ride it home (probably not 110psi).
There are some really cheap inflator heads out there that are poorly designed and may not operate the way you expect them to. It's worth spending a few dollars on a decent one, and practicing once in a while at home to make sure the inflator works as expected so you can get the hang of it.
I haven't carried a mini-pump in years, but I do carry a cell phone and am prepared to call an Uber if my roadside tire inflation skills somehow fail me. My flat kit includes two CO2 cartridges, an inflator head, a spare tube, two tire levers, a mini-tool, a patch kit, and now a tubeless tire plug kit. This all fits into a small saddle bag.
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
No CO2 system will ever be as reliable and bottomless as a good pump. Yes, the pump is more work. But...why have I had to loan my pump to more than a few CO2 users?
Hmmm....
Hmmm....
Likes For dmanthree:
2 bikes 250mi/week each together rides. 3 CO2's each, 2 tubes each, patches, boot and one mini pump and 2 inflators. CO2 is great when you have found the problem causing the flat with a quick tube replacement. BUT flats are sometimes multiple for various reasons and I want to get home unassisted. I have had inflators fail especially when they have been used on threaded stems.
If I have learned anything from this thread, it's that if I should have problems with my CO2 setup (which has yet to happen) and someone offers me a pump, they're actually doing it to be a braggart on the internet and should promptly be told to (figuratively) get wrecked
Likes For bahula03:
Quoted: 440 Post(s)
Liked 264 Times
Why carry just one co2 cartridge? They weigh nothing and take up very little space. I carry 2 tubes, 2 co2 cartridges and a small pump. It works for me. Co2 sure beats pumping up a tire.
Likes For Bmach:
Quoted: 24 Post(s)
Liked 42 Times
I have used CO2 cartridges successfully for years but just bought a new Lezyne inflator after I lost my old one. This Lezyne inflate is the best inflator I have ever owned. It works perfect, has a nice dial-in valve and is very well built. I had a flat today and after repairing it on the road and returning home, I checked the pressure in the tire and it was 100 psi. I carry this inflator now with 2 tubes and 2 CO2 cartridges on every ride.
https://www.amazon.com/LEZYNE-1-C2-C.../dp/B019Y7NL8C
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
I carry (2) CO2 cartridges and never had to use the 2nd. I wrap hockey stick tape around them for insulation for my hand. With a 25mm tire I get about 90psi. When you get home you should replace the CO2 and replace with air since the CO2 tends to leak down quicker.
I use a rather small inflation head.
Likes For GlennR:
On Your Left
Liked 2,434 Times
I've been using bulk 16g threaded cartridges from Amazon and a PDW Shiny Object for about a decade without issue. Works well.
