Beginner questions on brazing equiptment - Part 3, Nozzle Tips
Quoted: 12 Post(s)
Part 3, Torch Tips
Dan
- What range of tips do you use for different frame building jobs? I guess that smaller tips should be used but look forward to hearing what other's think.
Dan
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
You'll want a number of sizes; big ones for bottom bracket shells and fork crowns, medium for lugs, and small for braze-ons. Exactly what types and sizes will depend on the torch and the fuel gas you use (e.g. acetylene or propane).
Quoted: 12 Post(s)
Thanks, John, I guess the larger the mass of the tubes, the larger the tips should be, and if using propane, then even larger end bits should be used. It's going to be a journey to become comfortable with which tips to choose for different projects, especially when connecting tubes of different thicknesses.
Quoted: 4205 Post(s)
Liked 3,863 Times
Tips are usually not referenced with their actual orifice diameters, like so much of a closed community the terms are part of the exclusion. The tip IDs that I use range from .025" to .060". Newbies usually find that a smaller tip is easier to "keep up with" (in that things happen slower) but this adds time to heat up and during brazing, flux has a time at temp aspect that drops off at some point. This is for OA not OP. ndy
AndrewRStewart
AndrewRStewart
Quoted: 12 Post(s)
Liked 3,863 Times
I would search this forum and Velocipede Salon for Doug Fattic's posts about OP. he's done a lot of homework and shared a lot.
My commit about a newbie using a smaller tip is that they don't have the skills to control things as they happen and often react after things get too hot. A smaller flame slows down this and allows their reactions to better keep pace. But the longer the time at heat the more the flux "wears out" and the metal goes through it's changes. This is why good instruction and practice are so important before a real frame is tried. Andy
AndrewRStewart
AndrewRStewart
