Wheelset Upgrade Suggestions
I ride a 2016 Cervelo R5 and looking to upgrade my stock wheelset Aksiums. I like to climb. I'll try to make this pretty specific in what I'm looking for. Good value, on the lighter side (I weigh 68 kg / 150 lb), rim brake, I prefer aluminum but would consider carbon, would prefer around $700 but for exceptional value situations, I'd be comfortable paying up to $1200.
I know there are a few Campy wheelsets that people seem to love for the value in this price range but interested in other suggestions. Thank you!
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
Hed Ardennes SL.
Likes For MoAlpha:
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 29 Times
HED Belgium Plus (if they can fit your brakes) .... I have 2 sets .... (one for each bike).... not a true climbing rim, but it does everything well and most probably the finest alloy rim on the market IMHO .... these have the aerodynamic equal to FLO 30's ...
here's a good article:
https://novemberbicycles.com/blogs/b...ws-hed-belgium
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Try these out and let us know how it goes :-)
https://www.bike24.com/p2306399.html?q=tune+tsr
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
Consider having a custom set built to your exact specs. Allows you to dial in the perfect balance between weight and speed. Mine are Easton R90SLs with White Industries hubs. Around $900 and weight is mid-1400g for the set. November, Spark and others do this.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
*cough* I know a guy with time in the off season. *cough*
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
IMO, this is great advice. At the price point you posted, you should be able to find a builder who can put something together to match exactly what you need. If you are in the SoCal area I would recommend talking to Chris at SD Wheel Works.
Quoted: 1743 Post(s)
Liked 1,281 Times
I bought a CAAD 12 about 6 months ago and it came with Aksiums. For under $500 I switched to Mavic Ksyrium Elite USTs. They came with tires. Best thing I've done in all the years I've been cycling. And, going into this I was a total skeptic.
Quoted: 451 Post(s)
Liked 364 Times
Not sure where you are located, but I am also upgrading Aksiums and I also would prefer aluminum, as it is very wet and rainy where I live. I finally settled on Neugent Cycling in the US and Hunt in the UK. Both offer high value for the dollar/euro/gbp. Ultimately, I just liked what Neugent had a bit better, though I would have been very happy I am sure with Hunt.
Quoted: 4717 Post(s)
Liked 1,882 Times
Please link the wheelset you are looking at.
I am a Campy guy, so how about neutron wheel looks like under 1500 grams for the set (published weight) should make good climbing wheels
Liked 1,882 Times
Spoke Tension Rear Drive Side: 170-180 KGF (on a Park Tensiometer 18-19 for CX Ray and 22-23 for Laser).
Spoke Tension Rear Non Drive Side: There is no spec for this because it is whatever it is to pull the rim to the center of the wheel. They will always be looser than the drive side spokes and often by quite bit.
His wheels require a high DS tension because the hubs use a sketchy geometry.
Quoted: 451 Post(s)
Liked 364 Times
From his website,
I eat carbide.
Liked 1,306 Times
That would be fabulous.
I eat carbide.
Liked 1,306 Times
From his website,
I vaguely remember him saying he was getting back into wheels after the failure of his last wheel company Nuvation (sp). Speaking as a wheel guy there's a ton of people that feel they have to set themselves apart by having a gimmick. Yet gimmicks don't work long term. Never have and won't start now.
$900 seems hight I didn't spend anywhere near that.
Quoted: 1529 Post(s)
Liked 718 Times
Rims are super light aluminum with carbon laminate for strength, IIRC they're 365g. 16/20h, rear is off centre.
Pretty tight, yo
ETA - as a mechanic, the only problems I've seen with these were either down to abuse or salt air. They'll corrode if you spend a lot of time right on the coast, but that's about it. Shimano might even have fixed that; I've only seen it on the earlier generation.
Oh yeah, another thing to consider is tubulars... I picked up a set of R9000 wheels for AU$700 used. The tubular version is full carbon. Heaps lighter, and there are a few other pros to balance the fact a puncture that sealant won't fix will cost you a tyre...
I just picked up a set of new Roval cl50 rims, they are fast on the flats and climb well. Specialized was offering 25% off so they were close to what your wanting to spend.
