Road-side brake pad replacement?
Quoted: 1872 Post(s)
Liked 692 Times
Is this a real thing? It's more and more likely that the Mid South is going to be the Mud South and the only thing that really worries me is losing my brakes. How feasible is road-side replacement?
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 714 Post(s)
Liked 800 Times
It depends on the brakes, but it shouldn't be too hard to do if you know how to change them. You'll have to remove the wheel, use whatever tool necessary to remove the fastener that prevents the pads from falling out, pull out the pads and spring, use a plastic tire tool to push the pistons back(maybe do this with the old pads in place), put in new pads and spring, replace the fastener and put the wheel back on. It won't be fast, but it would be better than trying to finish the ride with no brakes.
I have carried a set of pads with me on wet gravel rides, but have never had to actually replace them during a ride. I did lose my rear brake at a long distance MTB event and that was not fun finishing with only a front brake.
Quoted: 630 Post(s)
Liked 369 Times
This is a really easy replacement especially if they are cable brakes and you probably won't have to remove your wheels unless you need to push the pistons back in.
I'm pretty sure I could swap Ultegra Hydro brake pads in the field if I had to. Just have to be careful not to lose the retention clip... or not install it and trust that the screw retention mechanism won't fail.
Likes For redlude97:
Quoted: 427 Post(s)
Liked 339 Times
Pads generally last thousands of miles. If they are at all questionable before a long or very gritty ride I'd just start with a fresh set before the event. Too many folks think they have to wear them down to nothing before they replace them. You will see many better riders replace then if they are down to half life or less. To be practical, say a new set costs $15 and you replace then when they are half worn. That means you throw away $7.50 for great piece of mind and not having to stop and switch pads 20 miles before the finish... That is a pretty small price.
Quoted: 8 Post(s)
My first Land Run 100 was 2017 the year of the freezing rain and crazy mud. My resin brake pads failed in the first 20 miles. Flintstone braking on downhills was absolutely insane. I was prepared for the weather but not for the brake pad issue so I had no choice but to stop at the half way point. There were many people that had the same issue. 2018 and 2019 I made sure to switch to semi metalic J40C brake pads and keep an extra set in my saddle bag although I didn't need them. This year they'll be in my bag again. One thing I learned in 2017 was to ride in the areas that are wetter. The better line is through a rut that has standing water, what appears more dry is actually peanut butter that weighs 10lbs. I'm doing The Double this year, If I make it through the 50k run on Friday I plan on enjoying every free beer/whiskey/margarita offered on the ride.
Good luck to anyone who is on the starting line.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 1975 Post(s)
Liked 232 Times
Quoted: 427 Post(s)
Liked 339 Times
Yeah, this is why I say start with a new set of pads on a race like that instead of trying to get every last bit out of a set of older pads. There are definitely some rides where you can eat upo a set of organic pads quiclly. I do not feel these rides are the orm however, at least in my poart of the country.
Quoted: 3239 Post(s)
Liked 2,086 Times
Note that on the typical Shimano disc systems I’ve changed pads, there’s a tiny cotter pin that prevents the pad retaining bolt from unscrewing. It’s small and hard to grab and easy to lose especially if you put it down in the grass. I usually use a small set of needle nose pliers, which I don’t carry on a bike. Not going to stop your ride, but means a trip to the LBS for a replacement.
Liked 692 Times
Well my metallic Ultegra hydro pads made it. Many others did not.
2019 Salsa Warbird
2019 Salsa Warbird
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
wait wait wait now.
You rode that course and having nothing more to say other toth- 'my brake pads worked'?!
Pics of that looked awful. You finished which is a win by itself!
So how was the experience overall? Did you do well compared to your expectations?
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I can change my pads (shimano Ultegra) without taking the wheels off (just don't lose that clip!). Do need something to compress that piston back in though. Certainly in the early days of cyclocross, people were going through a set of pads in an hour. Good be cheap insurance to carry a spare set.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Liked 232 Times
I use swissstop sintered, ,model 32 for SRAM HRD https://www.amazon.com/Swiss-Stop-Sw...00EN1UO9O?th=1
