Heat and my Stupidity
Yesterday I left around 7:30 in the morning for a ride to Jones Beach here in NY 30 mile round trip. The forecast was for 90s with humidity. It was 94 out when I was finished. Rode the local bicycle paths & roads to the beach it was a beautiful day. Coming back stopped for ice and a protein bar. About 3/4s thru and I check my pulse and my Garmin was reading 201+!!I didn't feel that bad but really slowed my pace which isn't that quick to begin with. Feel a little drained today. My HR normally averages in the 120- 140s if I am pushing it a little, in retrospect it was that high earlier in the ride. I guess at 65 I proved I am still capable of doing stupid thinks. Enjoyed most of the ride but lesson learned
Quoted: 2604 Post(s)
Liked 1,933 Times
Problem is, when you slow down you don't have that lovely breeze in your face.
When I start suffering I look for someplace air conditioned that I can go inside and cool off. Convenience stores, ice cream parlors, fast food -- buy ice cream, or fries and a drink, and enjoy it slowly.
I have no limits to mine. For some like me, aging doesn't guarantee wisdom.
Yesterday, 104, windy and humid. Started off with two full completely Frozen water bottles on my 26 mile route. Both were unfrozen by turn around and last bottle was Hot!
I definitely left my wisdom at the house yesterday 😄
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
Glad you got back ok.
Were you saying that your Garmin showed your heart rate to be 201+? That sounds way high for your age so I wonder if the Garmin was erroneous. Did you confirm that it was that high with a manual check? If true, you probably should have stopped and called for a ride. Flirting with heat stress is a dangerous game.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Yeah, heat illness causes over a thousand deaths in the USA every year - easy to overestimate your own ability to handle it until it's too late.
But the 201 bpm is probably just an error unless you were on the verge of puking and fainting. I've seen bizarre heart rate readings from going under power lines and other situations.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
My thoughts exactly. I worked in health care for 30 years and can tell you that even medical-grade heart monitors can give erroneous pulse rates. We had a motto: "treat the patient, not the monitor." When you see an anomalous reading like this, take a moment to palpate a manual pulse. Carotid or radial arteries are easy to find and can quickly tell you if the monitor reading is correct.
Yea there's no way that 201bpm is a correct reading.
You don't accidentally hit 200+ when you're 25 years old, much less 65 years old, unless narcotics are involved.
I sat or rather slept it out yesterday & today due to work (nights). While I snoozed yesterday my wife went out & walked 6 miles. We rode 43 somewhat hilly miles Bethpage/Huntington Bay on Saturday and she said the walk was much tougher.
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
Thank you everybody for he quick replies. The Garmin very well could have been in error that has happened only once before as far as I can recall. Besides feeling more tired then usual and feeling a little drained today I feel fine. Lesson learned
Quoted: 1069 Post(s)
Liked 788 Times
A protein bar was not a good selection. Should have had cold and moist for cooling and hydration. The protein bar takes too much blood flow for digestion compared to a soda, sports drink, Slushy.......plain M&M's.......
Quoted: 5224 Post(s)
Liked 3,585 Times
regardless, you still had heat stroke & are lucky to be alive. or maybe it was your conditioning, where a normal novice attempting the same, might have perished
It's MY mountain
Liked 2,981 Times
Heat stroke is immediately threatening to your life - OP's description of his symptoms were nothing like heat stroke.
>just finished my field work safety training.
Liked 3,585 Times
sure, I was guessing. but rapid heart rate is a symptom. so is confusion. since he is self reporting, we can't rule out heat stroke. asking him now to report exact symptoms is pointless, especially if he was confused thinking he felt fine
Bikes: Shmikes
Liked 5,872 Times
“Heat stroke” is often used loosely to refer to stages of milder overheating and fluid and electrolyte problems that precede it. It’s pretty easy to get woozy and exhausted out there in this weather, but yeah, vascular collapse, multi-organ failure, and seizures are dramatic.
Liked 3,585 Times
then there's "heat exhaustion", which I believe is a specific (& separate) diagnosis as well
Bikes: Shmikes
Liked 5,872 Times
Incidentally, my warning of an impending heat plotz was when the sweat rate slowed and I started feeling cold. Happened on long hot runs a few times, never on the bike.
Bikes: 1976 Raleigh,2015 Bianchi Intenso, 2012 Specialized Secteur.
Quoted: 48 Post(s)
I know it's coming for me pretty soon. I've convinced myself that I must participate in an organized ride in early September so there will be plenty of opportunity to over do it this summer.
If its happened before it could be exercise/dehydration induced arrhythmia. Any arrhythmia is potentially deadly. You should bring this up with your physician. Have you had a stress test recently? Ever?
Terex, No Never had a heat related issue before. I have yearly physicals & had a stress test a few times in my life the last one a couple of years ago.Proably because I never had one before I didn’t use good judgment. I should have done the original shorter ride that I planned
Bikes: Shmikes
Liked 5,872 Times
Anyone who can remain upright and conscious, let alone pedal a bicycle, with a ventricular rate of 200 at age 65 is in phenomenal, perhaps superhuman, shape!
dollar-store reject
Heat exhaustion:
Pale, cool, clammy skin
Profuse sweating
Body temp 100 - 104 deg.
Dizzy/lightheaded
Heat stroke
Flushed, hot, dry skin
Not sweating due to dehydration
Body temp 105 deg or more
Confusion/fainting/comatose
Hyperventilation
blood pressure abnormally high, OR, abnormally low.
Source:
https://www.emedicinehealth.com/heat...s_are_the_same
Profuse sweating
Dizzy/lightheaded
Heat stroke
Hyperventilation
Source:
