Front-end instability
I just bought a Electra Cruiser 7 , the front end to me seems very unstable is there anything I can do to improve that, I am new at this
Quoted: 1837 Post(s)
Liked 1,711 Times
First thing I would do is to check tire inflation, both front and rear. Next, I would check headset adjustment. A too loose or too tight headset can make a bike difficult to control. Is this a new bike? The dealer should be able to check it over for you
Quoted: 663 Post(s)
Liked 496 Times
When I first got my bike, I found it pulled to the left. After pondering this tendency for a while, I measured the alignment of the wheels using a string from front to back wheels. I found that they were misaligned. Further investigation showed that the front wheel dropouts were not inserted into the forks the same amount. The result of this was to throw the wheel out of plumb so that at the point of contact with the road, the wheel was a cm or so to the left. This was easily fixed by filing the dropout with a round file. The geometry of the wheel is such that if the axle is off by, say one mm, the wheel at the rim will be off by about four mm. It took longer to think about the problem than to fix it.
Bikes: SL8 Pro, TCR beater
Quoted: 1006 Post(s)
Liked 588 Times
What do you mean unstable? Your post requires a little more details...
Improper inflation, loose headset, loose spokes, warped wheel, etc.
Likes For eduskator:
yes it's a new bike and I've been back to the dealer three times the first time the son of the owner told me that is not enough dirt in the bearings yet give it time the owner checked it out for the head being too loose it's okay and he finally told me that he thinks that I'm . Oversteering
Quoted: 8333 Post(s)
Liked 9,160 Times
Maybe it's your fit/position on the bike? Should have your elbows bent, be relaxed, look ahead where you want to go, not where you don't want to go.
Quoted: 608 Post(s)
Liked 352 Times
Your question may be better suited here in Beach Cruisers.
With that said, your description is exactly what I expect that bike to do. Long front end, high handlebars, seat way behind the crank. It is like a motorcycle chopper, the front wheel is going to flop. Hopefully you will get use to it.
You'll most likely get used to, but don't expect to be railing corners anytime soon.
Bikes: Shmikes
Quoted: 10193 Post(s)
Liked 5,900 Times
See above.
Advocatus Diaboli
Quoted: 4759 Post(s)
Liked 1,538 Times
