Drop bar on a hybrid
Old 06-04-12, 07:37 PM
ChowChow
Was thinking about swapping the flat bar on my 2010 Fuji Absolute 2.0 to a road style drop handlebar. Is there anyway that I can keep the shifters and brakes handles on the flat bar and transfer it to the drop bar? Just wanted to do a little experiment to see if I will enjoy a drop bar and if so. I may keep it that way and change the shifters, brakes etc or maybe one day will purchase a drop bar road bike.
Anything that I need to know about swapping is appreciated.
ChowChow is offline
Old 06-04-12, 08:22 PM
Dunbar
Dunbar's Avatar
Bikes: Roubaix SL4 Expert , Cervelo S2
Quoted: 85 Post(s)
Educated guess here, yes you should be able to get your shifters and brakes on drop bars. I'm not sure why you'd want drop bars without brake hoods to ride on though. Drop bars are fairly narrow FYI so your hands will be in a narrower stance compared to flat bars.
Dunbar is offline
Old 06-04-12, 08:39 PM
giantcfr1
Ha ha ha ha ha
giantcfr1's Avatar
Bikes: 2004 ORBEA Mitis2 Plus Carbon, 2007 Cannondale Bad Boy Si Disc, 2012 Trek Gary Fisher Collection Marlin WSD 29er Aldi Big Box (Polygon) 650b
Quoted: 8 Post(s)
Liked 11 Times in 7 Posts
I've seen it, but I'd suggest once you've decided to keep the drops (if you do) change over to the correct levers etc. Maybe it's a good idea to do it your way first up, before you start spending the big dollars. I've seen on here bar ends to convert to drops. Maybe that's an alternative.
giantcfr1 is offline
Old 06-04-12, 09:04 PM
xenologer
Quoted: 239 Post(s)
Liked 7 Times in 7 Posts
Your old flatbar controls use 22mm clamps
Dropbar will have 24mm grip diameter
not compatible
Look into Soma Sparrow handlebar
allows agressive riding position similar to being in the drops of a dropbar; but lacking hoods position
uses 22mm grip area allowing direct transfer of flatbar controls
xenologer is offline
Old 06-05-12, 11:38 AM
Icculus21
Bikes: 2013 Trek 1.5
Quoted: 14 Post(s)
I'm planning to convert my Giant Rapid 3 to drops, and already purchased the components. I'm just going straight to the full conversion. A friend of mine did the same thing and likes the drops much better. It offers mulitple riding positions, and like Dunbar mentioned, the hoods are key.
Good luck!
Icculus21 is offline
Old 06-09-12, 03:51 AM
giantcfr1
Ha ha ha ha ha
giantcfr1's Avatar
Quoted: 8 Post(s)
This is my friend's FDH / Hybrid converted to a Drop Bar.
Note the road calipers,etc.
Nothing screams1990`s more than Trek Y frame, spinergy wheels and cinelli spinaci bars ....
Old 06-09-12, 07:24 AM
mprelaw
mprelaw's Avatar
Want a cheap alternative? Rent a drop bar bike from a LBS. Try it for a weekend. Then decide if the drops are for you.
mprelaw is offline
Old 06-09-12, 11:54 PM
giantcfr1
Ha ha ha ha ha
giantcfr1's Avatar
Quoted: 8 Post(s)
Not many LBS around here stock Hybrids with drop bars. I think the original poster wants to convert and keep and his hybrid, not buy a road bike with drops.
Likes For giantcfr1:
Old 06-11-12, 03:53 PM
Paul Barnard
For The Fun of It
Paul Barnard's Avatar
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times in 829 Posts
Here's your 20 dollar solution.
https://www.bikewagon.com/origin8-pro...road-ends.html
Here's how they look on my bike and they work GREAT!
Paul Barnard is offline
robbyrocks12345
Hybrid Bicycles
15
12-29-16 09:43 PM
curtiseddie
General Cycling Discussion
5
10-06-15 04:40 PM
eyemkeith
Road Cycling
2
03-10-14 05:31 PM
Thanas
Mountain Biking
3
04-27-13 09:09 PM
Rudz
16
01-12-13 05:55 PM
