Torque Wrenches - X-Tools / Venzo
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Hi guys,
I was wondering if some of you owned any of the 2 torque wrenches mentioned above? If so, could you please let me know what are your thoughts? I'm looking to buy one, and have narrowed down my choices to these 2. I don't want/need anything fancy as it's only for periodic maintenance.
X-tools : on CRC - currently on sale for 45$ (MSRP 65$)
Venzo : on Amazon - 70$
Venzo says it has a 4% accuracy, which is OK. Accuracy is not specified for the X-tools.
Let me know,
Thank you.
Let me know,
Thank you.
Quoted: 630 Post(s)
Liked 369 Times
I have the x-tools. It works great but it is not fool proof. You have to shake it back and forth about 20x to distribute the lube every time you use it. You have to be careful not to turn the handle when ratcheting the wrench. You also have to set it back to 2 nm when done.
Quoted: 551 Post(s)
Liked 277 Times
Forget the X-Tools. So disappointing. Venzo is okay. If you can get the Pro Bike Tool torque wrenches, I highly recommend it.
Likes For tagaproject6:
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
Can you guys post links to the specific items being discussed? I'm looking for a torque wrench for my cockpit items and am considering the one from ParktTools.
I hear this one is pretty good for the $
look it up on amazon
Pro Bike Tool 1/4 Inch Drive Click Torque Wrench Set – 2 to 20 Nm – Bicycle Maintenance Kit for Road & Mountain Bikes, Motorcycle Multitool - Includes Allen & Torx Sockets, Extension Bar & Storage Box
TEKTON TRQ21101 1/4-Inch Drive Dual-Direction Click Torque Wrench (10-150 in.-lb./1.1-16.9 Nm)
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
Theres one on amazon for about $23 and change. Just type in 1/4” drive beam torque wrench on amazon search box and it usually the first item that pops up. It goes up to 9 Nm, but you hardly need anything above 7Nm for cockpit items.
Quoted: 241 Post(s)
Liked 232 Times
Quoted: 562 Post(s)
Liked 64 Times
For the cockpit I find the CDI TorqControl works very well and is reasonably priced.
Quoted: 4560 Post(s)
Liked 2,802 Times
This tiny $25 Venzo beam torque wrench is good for up to 10 nm, which covers most cockpit fasteners. Comes with most bits we'd need.
No idea about clicky preset torque wrenches for torquing over 10 nm, still shopping around and reading reviews.
Venzo beam torque wrench for up to 10 nm.
Likes For canklecat:
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
I've been using a Tacklife (what a horrible name) torque wrench purchased from Amazon - https://www.amazon.com/Torque-2-26-2.../dp/B07GJSP7RW
Rated at +/- 4%, comes with a little slip of paper showing the values from calibration check, gets pretty good reviews. I have a Park beam-type also, but the ratcheting is often more convenient; the Park still does get some use as a reference by which to check the Tacklife, though. I think that I've had it for about a year and a half and it hasn't discernibly drifted.
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
I prefer beam-type wrenches, but they take a little bit of skill and knowledge to use.
Lol $300+ still gonna be less accurate than a beam tq wrench after some time.
You don’t need to spend a lot of money nor do you need ultimate accuracy.
https://www.bikeradar.com/features/t...ed_slideshow=0
Sunshine
Quoted: 10970 Post(s)
Liked 7,498 Times
Instead, I bought a $25 beam style wrench from Northern Tool. Its some generic sounding brand, im guessing their house brand. Its simple and inexpensive. All I need it for is 4 bolts on one of my bikes- the plug, the headset, and the stem. And on one of my kid's bikes its 5 bolts.
Out of the all the bolts on 14 bikes, I only need to use the tool for 9 of them, so i dont need anything small and cute or whatever- the beam wrench is used rarely since once built, there isnt much reason to pull stems or whatever.
Its as accurate as I need since it keeps bolts tight enough to not be unsafe and not so tight that damage occurs.
Quoted: 989 Post(s)
Liked 586 Times
Thanks to the others for your prompt responses as well. The Venzo beam torque wrench is supposedly ''prime'', but they charge me import fees and it's 2 weeks of shipping. I don't like to pay for extras when I already pay for a prime membership. How accurate are beam wrenches?
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
Not as small, but this one is the one I mentioned above
https://www.amazon.com/Neiko-03727A-...s%2C122&sr=8-2
Quoted: 241 Post(s)
Liked 232 Times
Okay, so what about this Park Tool. Obviously costs more, but maybe the difference is a higher quality product?
FWIW, CDI Torque Products is SnapOn. I found that the TorqControl wrench was more accurate and IMHO better built than my previous version of the Park wrench you linked to. It is commonly used by gunsmiths and is pretty easy to pickup cheaper than Amazon at gun shows.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I've had it for close to three years, and the carbon bits on my bike have yet to snap or come loose, so it's good enough for me.
Likes For wipekitty:
Liked 2,802 Times
However I can see the convenience of the single torque setting wrenches with long bits for easily reaching some fasteners in positions that would be awkward with a beam torque wrench. Especially for a production line or shop where time is money.
But I'll probably just get a larger beam torque wrench for the rest of the bike. There's usually a way to read the beam pointer graph while working.
Quoted: 989 Post(s)
Liked 586 Times
I ended up buying the Venzo from Amazon mainly because of availability (next day shipping hehe!). Will provide my thoughts on it shortly. I need to flip my stem to raise my bars so the torque wrench will be handy!
Specs says 5.5nm for the stem bolts & 6nm for the faceplate bolt. Not sure if going 6nm on all of them will do any harm, but it might be hard to set up the torque wrench to half a nm. Will see tomorrow.
Quoted: 389 Post(s)
Liked 255 Times
I bought a Kestrel in the box and it came with a similar tool as the Venzo beam wrench above. I also stuck a chart like this:
Torque Conversion Chart Newton Meters to Inch Pounds | AutoDrill
on the wall near my tool chest for my 1/4" clicker wrench. But not trusting either too much, I bought the Park adjustable torque wrench :
https://www.amazon.com/Park-Tool-ATD...63315758&psc=1
that's super handy.
that's super handy.
Quoted: 989 Post(s)
Liked 586 Times
So I tried the Venzo torque wrench yesterday when I installed my parts back after flipping my stem. You need to be careful when tightening the screws - it will not ''click'' if you go too fast & will over tighten. Once you figure that out, everything is OK. The wrench came with a certification of accuracy and looks well built. I have no complaint whatsoever on the quality.
Quoted: 630 Post(s)
Liked 369 Times
I had the venzo at one point and while it worked great, it was a real pain in the butt to see the dials at certain points
https://silca.cc/products/updated-t-...-ti-torque-kit
